ramsesrr Postat August 19, 2011 Partajează Postat August 19, 2011 Incerc sa citesc 8 canale ADC la 16f877a dar canalele se influenteza intre ele,adica daca pun 5V pe o intrare si pe restul le las in aer apare si pe ele 5V . In simulator totul e Ok insa practic nu .Care ar putea fi problema.Codul este urmatorul: // PIC16F877a Sms controller// Hi-Tech C #include <pic.h>#include <htc.h>#include <stdio.h>#include <string.h>#include "stdlib.h"__CONFIG(HS & WDTDIS & PWRTEN & BORDIS & LVPDIS & DUNPROT & WRTEN & DEBUGEN & UNPROTECT);#define _XTAL_FREQ 10000000ULbank1 char ReadBuffer[20]; volatile unsigned int i;void initialize(void) { GIE=1; // enable interrupts PEIE=1; //enable peripheral interrupt INTE = 0; //intrerupere oprita pe RB0 RBIE=0; TMR0IE=0; ADCS1 = 1; //select Fosc/8 ADCS0 = 1; ADCON1=0b10000000; // A/D port configuration 0 ADFM = 1; //right justified result ADON=1; // turn on the AD conversion module }/* return a 10-bit result */unsigned int read_adc(unsigned char channel){ channel&=0x07; // truncate channel to 3 bits ADON = 1; ADCON0&=0xC5; // clear current channel select ADCON0|=(channel<<3); // apply the new channel select __delay_ms(10); ADGO=1; // initiate conversion on the selected channel while(ADGO)continue; ADON = 0; return(((ADRESH&0x03)<<8)+ADRESL); // return the 10-bit result}int temp_lm35(void){ int temp_an, temp, i; temp_an=0; for(i=0; i<4; i++) { temp_an =temp_an+read_adc(0); __delay_ms(5); } temp_an=(temp_an/4); temp = temp_an*(int)((5.0*100.0)/1023.0); return(temp+1);}void InitUSART() //rutina de setare si initializare a modulului USART{ SPBRG=64;//(int)((F_CPU/(baund_rate*16))-1); BRGH=1; //high speed SYNC=0; //modul asincron SPEN=1; //activare port serial TXIE=0; //dezactivare intrerupere USART la transmisie TX9=0; //transmisie pe 8 biti TXEN=1; //activare transmisie RCIE=1; //activare intrerupere USART la receptie RX9=0; //receptie pe 8 biti CREN=1; //activare receptie}void USARTWriteChar(unsigned char c) //Rutina de transmitere a unui octet la portul serial{ while(!TXIF); //asteapta sa se termine transmisia precedenta TXREG=c; //incarca si transmite noua valoare}void TransmitUSARTC(const char* c){ unsigned int i =0; while(c[i]!=0x0 && c[i]!=0xd) { USARTWriteChar(c[i]); i++; } //USARTWriteChar(0xd); //new line}unsigned char ReceiveUSART() //Rutina pt receptia unui octet de la portul serial{ unsigned char c; while(!RCIF); //asteapta pana se incheie receptia c=RCREG; //octetul receptionat este preluat din RCREG return c; }/////////////////////////////////////////////////////////////////////////////////void Wait(unsigned int n){ unsigned int i,temp; temp=n*10; for(i = 0;i < temp ;i++) { __delay_ms(100); }}//////////////////////////////////////////////////////////void interrupt isr(void){ GIE=0; if(RCIF){ ReadBuffer[i++] = RCREG; if(i>78) i = 0; } RCIF = 0; GIE=1;}void Reset_RXBuff(void){ i = 0; memset(ReadBuffer, 0, 75);}void main(void){ int val1,val2,val3,val4; char b [40];volatile unsigned char flag8 = 0; initialize(); PIE1|=(1<<RCIE); __delay_us(20); InitUSART(); TRISA|=(1<<0)|(1<<1)|(1<<2)|(1<<3)|(1<<5); TRISE|=(1<<0)|(1<<1)|(1<<2); TransmitUSARTC("start"); USARTWriteChar('\r');memset(ReadBuffer, 0, 75); //reset bufferi = 0; //reset pointer while(1) {unsigned int adc[8];unsigned int w = 0; for(w = 0;w <=7; w++) { adc[w] = read_adc(w); Wait(1); } for(w = 0;w <=7; w++) { sprintf(b,"valoarea ADC pe canalul %d este : %d ",w,adc[w]); TransmitUSARTC(b); USARTWriteChar('\r'); memset(b,' ', 40); } TransmitUSARTC("#########################################"); USARTWriteChar('\r'); } } Link spre comentariu
Liviu M Postat August 19, 2011 Partajează Postat August 19, 2011 Si ce motiv ar avea celelalte intrari sa faca altceva?Intrarile ADC sunt conectate prin rezistente la condensatorul sample/hold. In momentul in care il incarci pe ala (maqsurand prima intrare), restul intrarilor fiind in aer condensatorul n-are nici un motiv sa se descarce, asa ca atunci cand masori in continuare, regasesti aceeasi valoare pe el. *)Oricum, e bad practice sa lasi intrari in aer, ca nu mai poti controla comportamentul circuitului.*) Ia afirmatiile de mai sus cu putina circumspectie, ca sunt sanse sa fiu "pe langa". Link spre comentariu
XAN77 Postat August 20, 2011 Partajează Postat August 20, 2011 si de ce te surprinde asa tare comportamentul unui pin de date setat intrare care e in gol? Oricum asta nu e modul normal de a folosi un pin care este intrare. Folosestel cum trebuie si daca tot nu face ceea ce te astepti abia atunci iti pui intrebari. Cu un 10k la masa mai citeste AD-ul 5V pe acel pin? Link spre comentariu
ramsesrr Postat August 21, 2011 Autor Partajează Postat August 21, 2011 Multumesc, am rezolvat cu ajutorul vostru Link spre comentariu
