tea5767 radio tunner i2c atmega si bascom
script22
am un tuner micut cu tea5767
http://www.rockbox.org/wiki/pub/Main/Da ... 5767-8.pdf
Posted Image
Posted Image
Posted Image
se intampla chestii ciudate cu el in sensu ca nu se schimba mereu postu
imediat dupa ce il alimentez merge sa schimb dupa nu mai vrea sau o ia dupa multe incercari
la aldoilea cod cu bargraphu ledurile se schimnba in functie de text primesc si pe serial numele
postu ramane acelasi ,poate dupa multe ikncercari o ia
'default template for script devboard atmega 16'_____________________________________________'setup$regfile = "m16def.dat"$crystal = 8000000$baud = 19200$lib "mcsbyte.lbx"'Config Portb.3 = Input                                      ' ir receiverConfig Rc5 = Pinb.3Config Porta = Input                                        ' pina.4.....7 push butons'Config Portc = Output                                       ' led bargraphConfig Scl = Portc.0                                        'i2c sclConfig Sda = Portc.1                                        'i2c sdaConfig I2cdelay = 10                                        ' i2c delayPorta.4 = 1                                                 ' enable pull up resistor buton 1Porta.5 = 1                                                 ' enable pull up resistor buton 2Porta.6 = 1                                                 ' enable pull up resistor buton 3Porta.6 = 1                                                 ' enable pull up resistor buton 4'_____________________________________________'configDim Address As Byte , Command As Byte                       'RC5 ir variableDim Pll As SingleDim Fset As WordDim Freq As Single                                          ' set freqDim 1st As ByteDim 2nd As ByteDim 3rd As ByteDim 4st As ByteDim 5th As ByteConst Fref = 32.768                                         ' cristal freq radio moduleConst Fg = 250I2cinit'_____________________________________________'main programDoGetrc5(address , Command)                                   'read if we have remote ir command  If Address = 10 Then     Command = Command And &B01111111  End IfIf Command = 1 ThenFreq = 100.2Portc = &B100000Print "radio 21"End IfIf Command = 2 ThenFreq = 92.1Portc = &B010000Print "VIbe FM"End IfIf Command = 3 ThenFreq = 106.7Portc = &B001000Print "europa fm"End IfIf Command = 4 ThenFreq = 90.8Portc = &B000100Print "magic fm"End IfIf Command = 5 ThenFreq = 96.1Portc = &B000010Print "kiss fm"End If'If Pina.4 = 0 Then'Waitms 3'fi = fi + 0.1'End If'If Pina.5 = 0 Then'Waitms 3'fi = fi - 0.1'End IfPll = Freq * 1000Pll = Pll + FgPll = Pll * 4Pll = Pll / FrefFset = Int(pll)1st = High(fset)Reset 1st.7                                                 'not muteReset 1st.6                                                 'not search2nd = Low(fset)3rd = &B00010000If Command = 0 ThenSet 3rd.4                                                   ' output is monoPrint "mono"End IfIf Command = 8 ThenReset 3rd.4                                                 ' output is stereoPrint "stereo"End If4st = &B000100105th = &B00000000I2cstartI2cwbyte &HC0                                               'adresa icI2cwbyte 1stI2cwbyte 2ndI2cwbyte 3rdI2cwbyte 4stI2cwbyte 5thI2cstopLoopEnd
am postat 2 modele de cod , am incercat mai multe aceleasi rezultate
'default template for script devboard atmega 16'_____________________________________________'setup$regfile = "m16def.dat"$crystal = 8000000$baud = 19200$lib "mcsbyte.lbx"'Config Portb.3 = Input                                      ' ir receiverConfig Rc5 = Pinb.3Config Porta = Input                                        ' led bargraphConfig Portc = Output                                       ' pinc.4.....7 push butons'Config Scl = Portc.0                                        'i2c sclConfig Sda = Portc.1                                        'i2c sdaConfig I2cdelay = 10                                        ' i2c delayPorta.4 = 1                                                 ' enable pull up resistor buton 1Porta.5 = 1                                                 ' enable pull up resistor buton 2Porta.6 = 1                                                 ' enable pull up resistor buton 3Porta.6 = 1                                                 ' enable pull up resistor buton 4'_____________________________________________'configDim Address As Byte , Command As Byte                       'RC5 ir variableDim Pll As SingleDim Fset As WordDim Freq As Single                                          ' set freqDim 1st As ByteDim 2nd As ByteDim 3rd As ByteDim 4st As ByteDim 5th As ByteConst Fref = 32.768                                         ' cristal freq radio moduleConst Fg = 250I2cinit'_____________________________________________'main programDoDebounce Pina.4 , 0 , Ch1 , SubDebounce Pina.5 , 0 , Ch2 , SubDebounce Pina.6 , 0 , Up , SubDebounce Pina.7 , 0 , Down , SubCh1:Freq = 106.7Ch2:Freq = 100.2Up:Freq = Freq + 0.1Down:Freq = Freq - 0.1Pll = Freq * 1000Pll = Pll + FgPll = Pll * 4Pll = Pll / FrefFset = Int(pll)1st = High(fset)Reset 1st.7                                                 'not muteReset 1st.6                                                 'not search2nd = Low(fset)3rd = &B000100004st = &B000100105th = &B00000000I2cstartI2cwbyte &HC0I2cwbyte 1stI2cwbyte 2ndI2cwbyte 3rdI2cwbyte 4stI2cwbyte 5thI2cstopLoopEnd
APPENDIX E: COMMUNICATION: WRITE MODE
Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0
Data byte 1 mute Search mode PLL13 PLL12 PLL11 PLL10 PLL9 PLL8
Data byte 2 PLL7 PLL6 PLL5 PLL4 PLL3 PLL2 PLL1 PLL0
Data byte 3 Search up/down Search stop level HiLo side injection Mono/stereo Mute left Mute right SW port1
Data byte 4 SW port 2 Stand-by Band limits xtal Soft-mute HCC SNC Search indicator
Data byte 5 PLL ref Deemph Not used Not used Not used Not used Not used Not used
Data Description
Mute 1: L-, R-audio muted
0: Audio not muted
Search node 1: search mode
0: not in search mode
PLL13..PLL0 Setting of the synthesizer programmable counter
Search up/down 1: search up
0: search down
Search stop level See table 4 (page 29)
High/low side injection 1: high side LO injection
0: low side LO injection
Mono/stereo 1: forced mono
0: stereo on
Mute left 1: left audio muted and forced mono
0: not muted
Right mute 1: Right audio muted and forced mono
0: not muted
SW port 1 & SW port 2 1: Port high
0: Port low
Stand-by 1: tuner in stand-by
0: not in stand-by
Band limits (BL) 1: japan FM band
US/Europe FM band
Xtal 1: Fxtal is 32.768kHz
0: Fxtal is 13MHz
Soft_mute 1: On
0: Off
HCC 1: On
0: Off
SNC 1: On
0: Off
Search indicator 1: pin 14 is output for the ready flag
0: pin 14 is SW port 1
PLL ref 1: 6.5MHz reference for PLL enabled
0: 6.5MHz reference not enabled
Deemph 1: deemphasis time constant is 75us
0: deemphasis time constant is 50us
4.2 PLL word calculation
To tune the radio to a wanted frequency, the corresponding PLL word must first be calculated. This is a 14 bits
word, which will be sent to the programmable divider.
To do this a distinction will be made between high and low side injection.
4.2.1 High side injection tuning
In high side injection mode the PLL word is calculated with the following formula:
REFS
RF if
DEC F
F F
N
4 *( + )
≡ with:
NDEC = Decimal value of PLL word
FRF = the wanted tuning frequency [Hz}
Fif = the Intermediate Frequency [Hz]
FREFS = the reference frequency [Hz}
In the PC control software this is implemented in the following way:
Application Note
AN10133
Philips Semiconductors
DRAFT 22
Low voltage FM stereo radio with TEA5767/68
PLL = NDEC = Decimal value of PLL word
TunedFrequency is the wanted tuning frequency in MHz,
Fif is the Intermediate Frequency of 225 kHz,
REF[XTAL] is the reference frequency in kHz, which depends on the selection of the oscillator
frequency as shown in the table below:
XTAL PLL REF Reference frequency Crystal frequency
0 0 50000 Hz 13 MHz
0 1 50000 Hz 6.5 MHz
1 0 32768 Hz 32.768 kHz
1 1 32768 Hz 32.768 kHz
Table 2: VCO reference frequency versus the crystal frequency
Now that The PLL word has been calculated in decimal, it must be converted to Hex decimal before sending in
to the tuning system.
If the receiver has to be tuned to a FM frequency of 100MHz, the PLL word will be calculated as follow:
Figure 12 gives an example of frequency tuning with high side injection.
FVCO=200.45MHz
High Side Injection
Fwanted=100MHz FLO=100.225MH Fimage=100.5MHz
:2
Figure 12: Example of PLL frequency calculation: high side injection
1000
4*( *1000 )
REF XTAL
TunedFrequency F
PLL ROUND if
1 52
  • Răspunsuri 6
  • script22
    5
  • Liviu M
  • yo9hnf
In ambele coduri initializezi de doua ori porta.6 si niciodata porta.7. E typo?
'default template for script devboard atmega 16Porta.6 = 1                                                 ' enable pull up resistor buton 3Porta.6 = 1                                                 ' enable pull up resistor buton 4
ms nu era asta problema
sa rezolvat de dupa deva experimente
cand trimit o comanda pinu 3 de la modul tre tinut la +
si aici noul cod cu butoane si telecomanda
'default template for script devboard atmega 16'_____________________________________________'setup$regfile = "m16def.dat"$crystal = 8000000$baud = 19200$lib "mcsbyte.lbx"'Config Portb.3 = Input                                      ' ir receiverConfig Rc5 = Pinb.3Config Porta =&B00001000                                        ' pina.4.....7 push butons'Config Portc = Output                                       ' led bargraphConfig Scl = Portc.0                                        'i2c sclConfig Sda = Portc.1                                        'i2c sdaConfig I2cdelay = 10                                        ' i2c delayPorta.4 = 1                                                 ' enable pull up resistor buton 1Porta.5 = 1                                                 ' enable pull up resistor buton 2Porta.6 = 1                                                 ' enable pull up resistor buton 3Porta.7 = 1                                                 ' enable pull up resistor buton 4'_____________________________________________'configDim Address As Byte , Command As Byte                       'RC5 ir variableDim Pll As SingleDim Fset As WordDim Freq As Single                                          ' set freqDim 1st As ByteDim 2nd As ByteDim 3rd As ByteDim 4st As ByteDim 5th As ByteConst Fref = 32.768                                         ' cristal freq radio moduleConst Fg = 250I2cinitEnable Interrupts'_____________________________________________'main programDo Getrc5(address , Command)                                  'read if we have remote ir command  If Address = 10 Then     Command = Command And &B01111111  End IfIf Pina.4 = 0 ThenWaitms 3Command = 1End IfIf Pina.5 = 0 ThenWaitms 3Command = 2End IfIf Pina.6 = 0 ThenWaitms 3Command = 3End IfIf Pina.7 = 0 ThenWaitms 4Command = 4End IfSelect Case CommandCase 1Set Porta.3Freq = 100.2Print "Radio 21"Portc = &B10000000Case 2Set Porta.3Freq = 92.1Print "Vibe FM"Portc = &B01000000Case 3Set Porta.3Freq = 90.8Print "Magic FM"Portc = &B00100000Case 4Set Porta.3Freq = 106.7Print "Europa FM"Portc = &B00010000End SelectPll = Freq * 1000Pll = Pll + FgPll = Pll * 4Pll = Pll / FrefFset = Int(pll)1st = High(fset)Reset 1st.7                                                 'not muteReset 1st.6                                                 'not search2nd = Low(fset)3rd = &B00010000If Command = 0 ThenSet 3rd.4                                                   ' output is monoPrint "mono"End IfIf Command = 8 ThenReset 3rd.4                                                 ' output is stereoPrint "stereo"End If4st = &B000100105th = &B00000000I2cstartI2cwbyte &HC0                                               'adresa icI2cwbyte 1stI2cwbyte 2ndI2cwbyte 3rdI2cwbyte 4stI2cwbyte 5thI2cstopReset Porta.3LoopEnd
  • 1 lună mai târziu...
