tmr0 16f877
sz3bbylA
Cand dai un sfat, e indicat sa-l si motivezi (ca sa-l inteleaga si cel caruia il adresezi, ca altfel il ia de woodoo). Asa ca te rog sa si explici de ce e nevoie de volatile.
Ce stiu eu despre volatile asta e ce-am citit prin manualul de la picc.
Extras din manualul PICC9.80a
3.3.10.2 VOLATILE TYPE QUALIFIER
The volatile type qualifier is used to tell the compiler that an object cannot be guaranteed
to retain its value between successive accesses. This prevents the optimizer
from eliminating apparently redundant references to objects declared volatile
because it may alter the behavior of the program to do so.
Any SFR which can be modified by hardware or which drives hardware is qualified as
volatile, and any variables which may be modified by interrupt routines should use
this qualifier as well. For example:
volatile static unsigned int TACTL @ 0x160;
The volatile qualifier does not guarantee that any access will be atomic, which is
often not the case with the PIC10/12/16 architecture, which can only access a maximum
of 1 byte of data per instruction.
The code produced by the compiler to access volatile objects may be different to
that to access ordinary variables, and typically the code will be longer and slower for
volatile objects, so only use this qualifier if it is necessary. However failure to use
this qualifier when it is required may lead to code failure.
  • Răspunsuri 15
  • Liviu M
    6
  • sz3bbylA
    6
  • ramsesrr
  • MatyC
