modificare cod sursa pentru receptor telecomanda
elcomar
se da schema urmatoare: http://elektronica.us/viewtopic.php?f=8&t=696
am realizat montajul si functioneaza numai ca functioneaza in regim bistabil iar eu vreau sa functioneze doar 0,4 secunde pentru a cupla si decupla un motoras actuator auto. Voi folosi doar canalele 1 si 2 deci la 3 nu vreau sa se modifice nimic (sa ramana in mod bistabil). Daca eu voi apasa pe butonul 1 al telecomenzii sa am iesire pe receptor la canalul 1 doar de 0,4 secunde indiferent daca mai din apasat sau nu. La fel si pentru canalul 2.
atasez mai jos codul sursa al RX in speranta ca ma va ajuta cineva:
; THIS IS RX
; PROJECT :3 channel remote control
; CRYSTAL 4 MHz
; RC5 FORMAT @38KHz , 35% duty cycle
; ADDRESS = 0X0B
; ch1 = 0X01
; ch2 = 0X02
; ch3 = 0X03
; NOT USE TOGGLE ALWAY = 0
; 4-JULY-2005
list P=12F629
#include
__config _WDT_OFF & _XT_OSC & _CP_ON & _CPD_OFF & _BODEN_OFF & _MCLRE_OFF & _PWRTE_ON
#DEFINE IR GPIO,3 ; IR LED input with R10K pull-up to vcc
#DEFINE OUT1 GPIO,0 ; Drive output 1
#DEFINE OUT2 GPIO,1 ; Drive output 2
#DEFINE OUT3 GPIO,2 ; Drive output 3
#DEFINE OUT1_M 0x01
#DEFINE OUT2_M 0x02
#DEFINE OUT3_M 0x04
#DEFINE TOG_BIT TOGGLE,0
#DEFINE ADDRS 0X0B ; 0000 1011 ; 0000 1110
#DEFINE CH1_CMD 0X01
#DEFINE CH2_CMD 0X02
#DEFINE CH3_CMD 0X03
CNT1 EQU 20H
CNT2 EQU 21H
CNT3 EQU 22H
CNT4 EQU 23H
TEMP EQU 24H
TOGGLE EQU 25H
ADDR EQU 26H
CMD EQU 27H
ORG 000
;BSF STATUS,RP0
;CALL 0X3FF
;MOVWF OSCCAL
;BCF STATUS,RP0
CALL DEBOUNCE
MOVLW 0X07
MOVWF CMCON ; MAKE ALL GPIO TO DIGITAL I/O
BSF STATUS,RP0
MOVLW 0X01
MOVWF OPTION_REG
MOVLW B'00001000'
MOVWF TRISIO
CLRF IOCB
BCF STATUS,RP0
BCF INTCON,GIE
CLRF GPIO ; turn off all output
MAIN: CALL DELAY3500
CALL GET_RC5
BTFSC STATUS,C
GOTO MAIN
MOVF ADDR,W
XORLW ADDRS
BTFSS STATUS,Z
GOTO MAIN ; ADDRESS ERROR
MOVF CMD,W
ANDLW 0X03 ; MASK 2 LSB
ADDWF PCL,F
GOTO MAIN ; COMMAND 0X00 NOT USE OR COMMAND ERROR
GOTO DO_CH1
GOTO DO_CH2
GOTO DO_CH3
DO_CH1: MOVLW OUT1_M
GOTO CHANGE
DO_CH2: MOVLW OUT2_M
GOTO CHANGE
DO_CH3: MOVLW OUT3_M
CHANGE: XORWF GPIO,F
GOTO MAIN
; READ RC5 Format
; OUTPUT : TOGGLE.7 = TOGGLE BIT
; ADDR = ADDRESS 5 BIT
; CDM = COMMAND 6 BIT
; C = 0 READ OK
; = 1 READ ERROR
GET_RC5:BTFSC IR
GOTO GET_RC5 ; WAIT IR LOW
CLRF TMR0 ; clear timer 0
NOP
BCF INTCON,T0IF ; CLR timer 0 flag
NOP
BTFSC INTCON,T0IF
GOTO ERR1
BTFSS IR
GOTO $-3
MOVF TMR0,W
;MOVLW 0xC8 ; FOR TEST
MOVWF TEMP
MOVLW 0XFF ; 1020 mS = 255*4
SUBWF TEMP,W
BTFSC STATUS,C
GOTO ERR1 ; ERROR IF Time > 1020 uS
MOVLW 0XC8 ; 800 mS
SUBWF TEMP,W
BTFSS STATUS,C
GOTO ERR1 ; ERROR IF Time < 800 uS (C8h * TM0 Prescaler = 800 uS )
BTFSC IR ; Time validate 800uS-1020uS
GOTO $-1 ; WAIT TO LOW (Syn BIT)
CALL DELAY1252 ; DELAY 3/4 BIT LENGHT=1252 uS
BTFSS IR
BCF TOGGLE,7
BTFSC IR
BSF TOGGLE,7
BTFSS IR
GOTO $+4
BTFSC IR
GOTO $-1
GOTO READ
BTFSS IR
GOTO $-1
;====== READ ADDRESS 5 BIT ===========
; READ MSB FIRST
READ: MOVLW 5
MOVWF TEMP ; LOOP COUNTER
CLRF ADDR
READ1: CALL DELAY1252
BTFSS IR
BCF STATUS,C
BTFSC IR
BSF STATUS,C
RLF ADDR,F ; SHIFT LEFT ADDRESS
BTFSS IR
GOTO $+4
BTFSC IR ; WAIT LOW
GOTO $-1
GOTO $+3
BTFSS IR
GOTO $-1
DECFSZ TEMP,F
GOTO READ1
;====== READ COMMAND 6 BIT ===========
; READ MSB FIRST
MOVLW 6
CLRF CMD
CMD1: CALL DELAY1252
BTFSS IR
BCF STATUS,C
BTFSC IR
BSF STATUS,C
RLF CMD,F ; SHIFT LEFT COMMAND
BTFSS IR
GOTO $+4
BTFSC IR
GOTO $-1
GOTO $+3
BTFSS IR
GOTO $-1
DECFSZ TEMP,F
GOTO CMD1
MOVLW 0X3F ; 0011 1111
ANDWF CMD,F
MOVLW 0X1F ; 0001 1111
ANDWF ADDR,F
BCF STATUS,C ; C=0 NO ERROR
RETURN
ERR1: BSF STATUS,C ; C=1 HAVE ERROR
RETURN
; DEBOUNCE SWITCH
; DELAY 15 mS
DEBOUNCE:
MOVLW .1 ; 1
MOVWF CNT1 ; 1
DEL_1: MOVLW .20
MOVWF CNT2 ; 1
DEL_2: CLRF CNT3 ; 1
DEL_3: DECFSZ CNT3,F ; 1/2
GOTO DEL_3 ; 2
DECFSZ CNT2,F ; 1/2
GOTO DEL_2 ; 2
DECFSZ CNT1,F ; 1/2
GOTO DEL_1 ; 2
RETLW 0 ; 2
; DELAY 1.252mS
DELAY1252:
MOVLW .1 ; 1
MOVWF CNT1 ; 1
REP_1: MOVLW .5
MOVWF CNT2 ; 1
REP_2: MOVLW .81
MOVWF CNT3 ; 1
REP_3: DECFSZ CNT3,F ; 1/2
GOTO REP_3 ; 2
DECFSZ CNT2,F ; 1/2
GOTO REP_2 ; 2
DECFSZ CNT1,F ; 1/2
GOTO REP_1 ; 2
GOTO $+1
GOTO $+1
GOTO $+1
GOTO $+1
RETURN ; 2
DELAY3500:
MOVLW .1 ; 1
MOVWF CNT1 ; 1
MOVLW .23
MOVWF CNT2 ; 1
MOVLW .50
MOVWF CNT3
DECFSZ CNT3,F ; 1/2
GOTO $-1 ; 2
DECFSZ CNT2,F ; 1/2
GOTO $-5 ; 2
DECFSZ CNT1,F ; 1/2
GOTO $-9 ; 2
RETLW 0 ; 2
END[attachment=2]rx.gif[/attachment]
  • Răspunsuri 6
  • elcomar
  • francezu
  • MatyC
Asta ar fi o varianta :
;--------------------------; THIS IS RX; PROJECT :3 channel remote control; CRYSTAL 4 MHz; RC5 FORMAT @38KHz , 35% duty cycle; ADDRESS = 0X0B; ch1  = 0X01; ch2  = 0X02; ch3  = 0X03; NOT USE TOGGLE ALWAY = 0; modif. 12.APR.2011;CH1,CH2 monostable;CH3 bistable;--------------------------	list P=12F629	#include <P12F629.INC>	__config _WDT_OFF & _XT_OSC & _CP_ON & _CPD_OFF & _BODEN_OFF & _MCLRE_OFF & _PWRTE_ON	errorlevel -302#DEFINE IR	GPIO,3	; IR LED input with R10K pull-up to vcc#DEFINE OUT1	GPIO,0	; Drive output 1#DEFINE OUT2	GPIO,1	; Drive output 2#DEFINE OUT3	GPIO,2	; Drive output 3#DEFINE OUT1_M	0x01#DEFINE OUT2_M	0x02#DEFINE OUT3_M	0x04#DEFINE TOG_BIT TOGGLE,0#DEFINE ADDRS	0X0B        ; 0000 1011        ; 0000 1110 #DEFINE CH1_CMD	0X01#DEFINE CH2_CMD	0X02#DEFINE CH3_CMD	0X03#DEFINE pulse_width .40CNT1	EQU	20HCNT2	EQU	21HCNT3	EQU	22HCNT4	EQU	23HTEMP	EQU	24HTOGGLE	EQU	25HADDR	EQU	26HCMD	EQU	27Hd1		equ	28hd2		equ	29hpulse_cnt equ 2Ahmask	equ 2Bh	ORG	000	;BSF	STATUS,RP0	;CALL	0X3FF	;MOVWF	OSCCAL	;BCF	STATUS,RP0	;		CALL	DEBOUNCE		MOVLW	0X07	MOVWF	CMCON	; MAKE ALL GPIO TO DIGITAL I/O	BSF	STATUS,RP0	MOVLW	0X01	MOVWF	OPTION_REG 	MOVLW	B'00001000'	MOVWF	TRISIO	CLRF	IOCB	BCF	STATUS,RP0		BCF	INTCON,GIE	CLRF	GPIO	; turn off all output	;	MAIN:	CALL	DELAY3500	CALL	GET_RC5		BTFSC	STATUS,C	GOTO	MAIN	;					MOVF	ADDR,W		XORLW	ADDRS	BTFSS	STATUS,Z	GOTO	MAIN		; ADDRESS ERROR	;		MOVF	CMD,W	ANDLW	0X03		; MASK 2 LSB	ADDWF	PCL,F	GOTO	MAIN		; COMMAND 0X00 NOT USE OR COMMAND ERROR	GOTO	DO_CH1	GOTO	DO_CH2	GOTO	DO_CH3	DO_CH1: 	movlw	OUT1_M	goto	PULSEDO_CH2:	movlw	OUT2_M	goto	PULSEDO_CH3:	MOVLW	OUT3_MCHANGE:	XORWF	GPIO,F		GOTO	MAINPULSE:	movwf	mask	movlw	0XFF		; switch output high	xorwf	GPIO,w	andwf	mask,w	xorwf	GPIO,f				movlw	pulse_width	movwf	pulse_cnt	call	Delay_10	decfsz	pulse_cnt,f	goto	$-2		clrw				; switch output low	xorwf	GPIO,w	andwf	mask,w	xorwf	GPIO,f	GOTO	MAIN;======================================; READ RC5 Format; OUTPUT : TOGGLE.7 = TOGGLE BIT;	       ADDR = ADDRESS 5 BIT ;	        CDM = COMMAND 6 BIT;	          C = 0 READ OK;		    = 1 READ ERROR;======================================GET_RC5:BTFSC	IR	GOTO	GET_RC5		; WAIT IR LOW	CLRF	TMR0		; clear timer 0	NOP	BCF	INTCON,T0IF	; CLR timer 0 flag	NOP	;	BTFSC	INTCON,T0IF     	GOTO	ERR1			;	BTFSS	IR	GOTO	$-3	;		MOVF	TMR0,W			;MOVLW	0xC8		; FOR TEST	MOVWF	TEMP	MOVLW	0XFF		; 1020 mS = 255*4	SUBWF	TEMP,W	BTFSC	STATUS,C	GOTO	ERR1		; ERROR IF Time > 1020 uS	MOVLW	0XC8		; 800 mS	SUBWF	TEMP,W	BTFSS	STATUS,C	GOTO	ERR1		; ERROR IF Time < 800 uS  (C8h * TM0 Prescaler = 800 uS )	;	BTFSC	IR  		; Time validate 800uS-1020uS	GOTO	$-1		; WAIT TO LOW (Syn BIT)	CALL	DELAY1252	; DELAY 3/4 BIT LENGHT=1252 uS	;	BTFSS	IR	BCF	TOGGLE,7		BTFSC	IR	BSF	TOGGLE,7		;			BTFSS	IR	GOTO	$+4	BTFSC	IR	GOTO	$-1	GOTO	READ		;	BTFSS	IR	GOTO	$-1;====== READ ADDRESS 5 BIT ===========; READ MSB FIRST;	READ:	MOVLW	5	MOVWF	TEMP	; LOOP COUNTER	CLRF	ADDR	;	READ1:	CALL	DELAY1252	BTFSS	IR	BCF	STATUS,C	BTFSC	IR	BSF	STATUS,C	RLF	ADDR,F	; SHIFT LEFT ADDRESS	;	BTFSS	IR	GOTO	$+4	BTFSC	IR	; WAIT LOW	GOTO	$-1	GOTO	$+3	;	BTFSS	IR	GOTO	$-1	;	DECFSZ	TEMP,F	GOTO	READ1	;;====== READ COMMAND 6 BIT ===========	; READ MSB FIRST;	MOVLW	6	MOVWF	TEMP	; LOOP COUNTER	CLRF	CMD	;	CMD1:	CALL	DELAY1252	BTFSS	IR	BCF	STATUS,C	BTFSC	IR	BSF	STATUS,C	RLF	CMD,F	; SHIFT LEFT COMMAND	;	BTFSS	IR	GOTO	$+4	BTFSC	IR	GOTO	$-1	GOTO	$+3	;	BTFSS	IR	GOTO	$-1	;	DECFSZ	TEMP,F	GOTO	CMD1	;		MOVLW	0X3F	; 0011 1111	ANDWF	CMD,F	MOVLW	0X1F	; 0001 1111	ANDWF	ADDR,F	BCF	STATUS,C	; C=0 NO ERROR	RETURN	;ERR1:	BSF	STATUS,C	; C=1 HAVE ERROR		RETURN;======================================; DEBOUNCE SWITCH; DELAY 15 mS;======================================DEBOUNCE:	MOVLW	.1		; 1	MOVWF	CNT1		; 1DEL_1:	MOVLW	.20	MOVWF	CNT2		; 1DEL_2:	CLRF	CNT3		; 1DEL_3:	DECFSZ	CNT3,F		; 1/2	GOTO	DEL_3		; 2	DECFSZ	CNT2,F		; 1/2	GOTO	DEL_2		; 2	DECFSZ	CNT1,F		; 1/2	GOTO	DEL_1		; 2	RETLW	0		; 2;======================================; DELAY 1.252mS;======================================DELAY1252: 	MOVLW	.1		; 1	MOVWF	CNT1		; 1REP_1:	MOVLW	.5	MOVWF	CNT2		; 1REP_2:	MOVLW	.81	MOVWF	CNT3		; 1REP_3:	DECFSZ	CNT3,F		; 1/2	GOTO	REP_3	; 2	DECFSZ	CNT2,F		; 1/2	GOTO	REP_2	; 2	DECFSZ	CNT1,F		; 1/2	GOTO	REP_1	; 2	GOTO	$+1		GOTO	$+1		GOTO	$+1		GOTO	$+1		RETURN			; 2DELAY3500:		MOVLW	.1		; 1	MOVWF	CNT1		; 1	MOVLW	.23	MOVWF	CNT2		; 1	MOVLW	.50	MOVWF	CNT3	DECFSZ	CNT3,F		; 1/2	GOTO	$-1		; 2	DECFSZ	CNT2,F		; 1/2	GOTO	$-5		; 2	DECFSZ	CNT1,F		; 1/2	GOTO	$-9		; 2	RETLW	0		; 2Delay_10			;9993 cycles	movlw	0xCE	movwf	d1	movlw	0x08	movwf	d2Delay_0	decfsz	d1, f	goto	$+2	decfsz	d2, f	goto	Delay_0			;3 cycles	goto	$+1	nop			;4 cycles (including call)	return		END
poza cu montajul :da am descoperit o problema la telecomanda: consuma bateria repede pentru ca sursa 78l05 sta conectata pe baterie chiar daca nu se foloseste telecomanda / oare asta sa consume? idei? pana atunci am pus un buton basculant pe alimentare (ce vedeti in poza este doar un model de test, pe viitor vreau sa-l fac mai frumos, pe un cablaj asa cum trebuie)multumesc inca o data pentru ajutor
Masoara mai intai curentul, nu ar trebui sa se consume bateria chiar foarte repede.Totusi 78L05 are un consum propriu tipic de 3mA alimentat la 10V, cam mult zic eu pt alimentarea de la baterie; e si pacat sa consumi curentul asta degeaba mai ales ca PIC-ul intra in sleep cand nu transmite si consumul sau e infim. Poti alimenta PIC-ul direct de la o baterie de 3V, eventual daca e cazul mai micsorezi rezistenta serie cu ledul IR.
