ag81sri Postat Martie 27, 2011 Partajează Postat Martie 27, 2011 Vand statie militara HF (100 Khz - 30Mhz - Banda continua), SSB, MA, CW, 5/20 W putere OUT, in perfecta stare de functionare. 200 euro. telef. 0745 908228.Poza este la anuntul anterior din data de 12 -07.2009, numai ca este o alta statie.Caracteristici :- operation frequencies range: 1 .5 - 30 MHz- channels number: 28500 (100 Hz channels spacing between two near by channels) - transmitter's output power: min. 20 (full power); 5 W?3 dB (reduced)- transmitter's harmonics attenuation: min. 40 dB (1.5-12 MHz)min. 33 dB (12 - 30 MHz)- transmitter's spurious emission attenuation: min. 50 dB- automatic tuning period: max. 3 seconds- consumption: max. 7.5 A in full power telegraphy- operation set's weight: max. 15 kg (accumulator battery included)- dimensions: 390 x 230 x 390 mm-]- operation temperatures range: - 35oC ... + 50oC Link spre comentariu
Rx-Tx Postat Martie 27, 2011 Partajează Postat Martie 27, 2011 totusi niste poze? sau un link ceva ? Link spre comentariu
hpavictor Postat Martie 27, 2011 Partajează Postat Martie 27, 2011 http://iemi.bertys.ro/produse/radio/R39 ... _R3931.htm Link spre comentariu
