Vizitator danielmx Postat Martie 12, 2011 Partajează Postat Martie 12, 2011 vreau sa citesc acest sensorhttp://www.pololu.com/catalog/product/961 pe portulB la pic16f876a... cand este pozitionat deasupra unei linii negre ar trebui sa am "1" pe pinul respectiv iar cand am alb...ar trebui "0". Problema mea este ca nu reusesc sa citesc acest sensor "digital .." asta este codul meu de citire in care am urmat pasii din datasheet: [list=]The typical sequence for reading a sensor is: 1.Turn on IR LEDs (optional) 2.Set the I/O line to an output and drive it high 3.Allow at least 10 us for the 10 nF capacitor to charge 4.Make the I/O line an input (high impedance) 5.Measure the time for the capacitor to discharge by waiting for the I/O line to go low 6.Turn off IR LEDs (optional) These steps can typically be executed in parallel on multiple I/O lines. >citsenz: bsf STATUS,RP0 movlw b'00000000' movwf TRISB ; 1) setare portb iesire bcf STATUS,RP0 movlw b'11111111' ; drive it high pt incarcarea condens movwf PORTB call delay10us ;asteapta ~10us sa se incarce cond bsf STATUS,RP0 movlw b'11111111' ;portb = intrare movwf TRISB bcf STATUS,RP0 call delay1ms call delay1ms movf PORTB,0 ;citire senzor paralel cu pastrarea rezultatului in "citiresenzor" movwf citiresenzor Link spre comentariu
