manolo Postat Aprilie 3, 2017 Partajează Postat Aprilie 3, 2017 Uite aici ,pare un vinzator serios:https://www.aliexpress.com/item/Free-shipping-CHIP-PROGRAMMER-SOCKET-TQFP44-QFP44-PQFP44-TO-DIP40-adapter-socket-support-MCU-51-chip/32280177562.html?spm=2114.01020208.3.10.uSkMLA&ws_ab_test=searchweb0_0,searchweb201602_2_10065_10068_10136_10137_10138_10060_10062_10141_10056_10055_10054_122_10059_10099_10103_10102_10096_10148_10052_10053_10050_10107_10142_10051_10143_10084_10083_10080_10082_10081_10110_10111_10112_10113_10114_10037_10032_10078_10079_10077_10073_10070_10123_10124,searchweb201603_1,afswitch_1,ppcSwitch_5_ppcChannel,single_sort_0_default&btsid=74305f73-225d-4f3c-aab4-533b00f57389&algo_expid=66b9d1b2-adad-4835-a490-4412ece4dddb-0&algo_pvid=66b9d1b2-adad-4835-a490-4412ece4dddb Link spre comentariu
nico_2010 Postat Aprilie 3, 2017 Partajează Postat Aprilie 3, 2017 Mai departe este decizia userului de a-si cumpara ce are nevoie, de unde vrea si cati bani este dispus sa aloce pentru rezolvarea problemei intampinate. Link spre comentariu
Florinel TV Postat Aprilie 6, 2017 Partajează Postat Aprilie 6, 2017 Aici este si schemele de la atmega fusebit doctor cit si adaptoarele sunt si adaptoare smd , daca vrea sa le faca cineva adaptoarele atmega hvpp fusebit doctor archive rar atmega fusebit doctor smd adapter 1 0 rar atmega hvpp fusebit doctor update11 rar Pentru cine mai are nevoie sal construiasca Link spre comentariu
val Postat Aprilie 14, 2017 Partajează Postat Aprilie 14, 2017 http://mightyohm.com/blog/2008/09/arduino-based-avr-high-voltage-programmer/ , l-am folosit pentru a debloca un M328. Link spre comentariu
ionel sm Postat Aprilie 16, 2017 Partajează Postat Aprilie 16, 2017 (editat) Cam asa ar arata un adaptor smd,Rascolind pe google am gasit diverse adaptoare https://www.google.ro/search?q=atmega+fusebit+doctor+smd+adapter&safe=active&rlz=1C2AOHY_deDE727RO739&tbm=isch&tbo=u&source=univ&sa=X&ved=0ahUKEwjJi6Sr-anTAhVDuBQKHfo4DC4QsAQIIA&biw=1366&bih=653#imgrc=_ Editat Aprilie 16, 2017 de ionel1959 Link spre comentariu
kinderu56 Postat Aprilie 20, 2017 Partajează Postat Aprilie 20, 2017 a facut cineva varianta asta de atmega doctor cu FT232RL ce avantaje sau dezavantaje ar fi intre asta si cea fara usb http://www.getchip.net/posts/059-ispravlyaem-avr-fyuzy-pri-pomoshhi-atmega-fusebit-doctor/ Link spre comentariu
nico_2010 Postat Aprilie 20, 2017 Partajează Postat Aprilie 20, 2017 Exista un avantaj (??) al variantei cu FT232 doar in msura in care vrei sa vizualizezi mesajele transmise de doctor pe un monitor. Altfel, ca functionalitate, fac acelasi lucru. Link spre comentariu
kinderu56 Postat Aprilie 20, 2017 Partajează Postat Aprilie 20, 2017 ok multumesc Link spre comentariu
niculae Postat Mai 7, 2017 Partajează Postat Mai 7, 2017 (editat) Asa cum am promis astazi, atasez din nou arhiva cu cele folosite de mine pentru realizatea lui Atmega Fusebit Doctor. Am folosit Firmware pentru Atmega8 , pe asta l-am pus in Doctor ca "inima". Link descarcare: http://fastupload.ro/9df6ee1a6ec96eb2ee035d52d9901f4d.html Buna seara, Spuneti-mi va rog frumos la alimentare doctorului care led ar fi normal sa se aprinda? verde ramas aprins este corect? La apasare sw clipeste rosu de doua ori si verde ramane aprins! Multumesc. Editat Mai 7, 2017 de niculae Link spre comentariu
tepy Postat Mai 28, 2017 Partajează Postat Mai 28, 2017 va rog sa ma ajutati si pe mine,am facut si eu pentru un prieten un atmega fusebit doctor dupa schema de pe siteul oficial,dar dupa ce am montat toate piesele si dupa ce am scris firmware pe un atmega 8a l-am alimentat dar ledul rosu sta tot timpul aprins,daca dau pe butonul start se stinge ledul rosu citeva secunde si cel verde clipeste ff slab,eu dupa cit am vazut prin toate videotutoriale nu asa trebue sa faca,datimi va rog un sfat ce ar putea sa fie vina. Link spre comentariu
nico_2010 Postat Mai 29, 2017 Partajează Postat Mai 29, 2017 Verifica cu lupa sa nu ai "mustati" de PCB intre pinii 25 si 26 sau intre pinul 25 si masa Link spre comentariu
MifTy Postat Mai 29, 2017 Partajează Postat Mai 29, 2017 a facut cineva varianta asta de atmega doctor cu FT232RL ce avantaje sau dezavantaje ar fi intre asta si cea fara usb http://www.getchip.net/posts/059-ispravlyaem-avr-fyuzy-pri-pomoshhi-atmega-fusebit-doctor/ aia fără USB merge să-şi afişeze mesajele trimise pe UARTdoar pe un pc/laptop cu COM clasic, prin intermediul unui convertor de nivel... cea cu USB (nu are importanţă ce convertor USB/TTL e, poate fi orice de la clasicul FT232 la chinezescul CH340) se poate conecta la orice device cu USB şi mesajele se pot vede cu orice soft de terminal. sfat pentru cei care vor să-şi facă un "doctor": există deja un shield pentru asta, pentru Arduino Uno, dar se poate adapta la orice alt Arduino, şi puteţi face rapid şi uşor unul, fără bătăi de cap cu fusebiţii "doctorului"... deşi la ăla NU se umblă la fusebiţi, pentru că nu are nevoie de cine ştie ce precizie în tact! aici: http://mightyohm.com/blog/2008/09/arduino-based-avr-high-voltage-programmer/ Link spre comentariu
tepy Postat Mai 29, 2017 Partajează Postat Mai 29, 2017 am verificat toate traseele si vizual cu lupa si cu aparatul nu imi da nici un scurt si nici circuit intrerupt,dar am incercat sa pun un integrat gol si atunci nu se mai aprind ledurile deloc . Link spre comentariu
The_Reaper Postat Octombrie 31, 2017 Partajează Postat Octombrie 31, 2017 Intrebare, a reusit cineva sa deblocheze vreun atmega cu fusebit doktor, ca eu nu am reusit si s-au strans cateva bucati blocate si as vrea sa le resuscitez. Link spre comentariu
elmar Postat Noiembrie 1, 2017 Partajează Postat Noiembrie 1, 2017 (editat) ”Doctorul” sigur funcționează...am deblocat câteva atmega(8 și 328) !Dar numai dacă s-au blocat accidental prin setarea greșită a fusebits...dacă au(microcontrolerele) probleme hardware și mai ales unul din pinii de programare e defect...nu mai se poate face nimic! Mai sunt cazuri când nu merge deblocat din cauza că unul din traseiele de programare ai doctorului spre microcontroler e întrerupt ...sau nu face contact ferm în soclu ! Mi s-a întâmplat să lipesc un atmega 8 smd pe un adoaptor ...și un singur pin nu făcea contact....nu mergea sub nici o formă .Mereu se aprindea ledul rosu....după lipirea acelui pin...a funcționat din prima! Editat Noiembrie 1, 2017 de elmar Link spre comentariu
