8051
Vizitator montan
Vizitator montan
As vrea sa stiu si eu daca a intampinat cineva warning-ul "WARNING L2: REFERENCE MADE TO UNRESOLVED EXTERNAL". Am incercat mai multe versiuni de compilatoare si tot asa. Folosesc Silabs IDE, toate headerele sunt incluse.Multumesc
  • Răspunsuri 3
Vizitator montan
BL51 BANKED LINKER/LOCATER V6.15 - SN: K1REC-7FH5RPCOPYRIGHT KEIL ELEKTRONIK GmbH 1987 - 2008D:\zigbee\Coordonator\apps\main.obj,D:\zigbee\Coordonator\apps\coordonator.obj,D:\ZIGBEE\Coordonator\lib\hal_int0_isr.OBJ,D:\ZIGBEE\Coordonator\lib\hal_pca0_isr.OBJ TO D:\zigbee\Coordonator\apps\coordonator RS(256) PL(68) PW(78) *** WARNING L1: UNRESOLVED EXTERNAL SYMBOL SYMBOL: NLMECONFIRM MODULE: D:\ZIGBEE\COORDONATOR\APPS\COORDONATOR.OBJ (COORDONATOR)*** WARNING L1: UNRESOLVED EXTERNAL SYMBOL SYMBOL: _NLMENETWORKFORMATIONREQUEST MODULE: D:\ZIGBEE\COORDONATOR\APPS\COORDONATOR.OBJ (COORDONATOR)*** WARNING L1: UNRESOLVED EXTERNAL SYMBOL SYMBOL: ?_NLMENETWORKFORMATIONREQUEST?BYTE MODULE: D:\ZIGBEE\COORDONATOR\APPS\COORDONATOR.OBJ (COORDONATOR)*** WARNING L1: UNRESOLVED EXTERNAL SYMBOL SYMBOL: _NLMEPERMITJOININGREQUEST MODULE: D:\ZIGBEE\COORDONATOR\APPS\COORDONATOR.OBJ (COORDONATOR)*** WARNING L1: UNRESOLVED EXTERNAL SYMBOL SYMBOL: NWKCCOORDINATORCAPABLE MODULE: D:\ZIGBEE\COORDONATOR\APPS\COORDONATOR.OBJ (COORDONATOR)*** WARNING L2: REFERENCE MADE TO UNRESOLVED EXTERNAL SYMBOL: NWKCCOORDINATORCAPABLE MODULE: D:\ZIGBEE\COORDONATOR\APPS\COORDONATOR.OBJ (COORDONATOR) ADDRESS: 0008H*** WARNING L2: REFERENCE MADE TO UNRESOLVED EXTERNAL SYMBOL: ?_NLMENETWORKFORMATIONREQUEST?BYTE MODULE: D:\ZIGBEE\COORDONATOR\APPS\COORDONATOR.OBJ (COORDONATOR) ADDRESS: 000CH*** WARNING L2: REFERENCE MADE TO UNRESOLVED EXTERNAL SYMBOL: _NLMENETWORKFORMATIONREQUEST MODULE: D:\ZIGBEE\COORDONATOR\APPS\COORDONATOR.OBJ (COORDONATOR) ADDRESS: 0027H*** WARNING L2: REFERENCE MADE TO UNRESOLVED EXTERNAL SYMBOL: _NLMEPERMITJOININGREQUEST MODULE: D:\ZIGBEE\COORDONATOR\APPS\COORDONATOR.OBJ (COORDONATOR) ADDRESS: 0032H*** WARNING L2: REFERENCE MADE TO UNRESOLVED EXTERNAL SYMBOL: NLMECONFIRM MODULE: D:\ZIGBEE\COORDONATOR\APPS\COORDONATOR.OBJ (COORDONATOR) ADDRESS: 0193H*** WARNING L2: REFERENCE MADE TO UNRESOLVED EXTERNAL SYMBOL: NLMECONFIRM MODULE: D:\ZIGBEE\COORDONATOR\APPS\COORDONATOR.OBJ (COORDONATOR) ADDRESS: 0195H*** WARNING L1: UNRESOLVED EXTERNAL SYMBOL SYMBOL: RX_FIFOP_ISR MODULE: D:\ZIGBEE\COORDONATOR\LIB\HAL_INT0_ISR.OBJ (HAL_INT0_ISR)*** WARNING L1: UNRESOLVED EXTERNAL SYMBOL SYMBOL: STOP_RX_FIFOP_INT MODULE: D:\ZIGBEE\COORDONATOR\LIB\HAL_INT0_ISR.OBJ (HAL_INT0_ISR)*** WARNING L2: REFERENCE MADE TO UNRESOLVED EXTERNAL SYMBOL: STOP_RX_FIFOP_INT MODULE: D:\ZIGBEE\COORDONATOR\LIB\HAL_INT0_ISR.OBJ (HAL_INT0_ISR) ADDRESS: 014EH*** WARNING L2: REFERENCE MADE TO UNRESOLVED EXTERNAL SYMBOL: RX_FIFOP_ISR MODULE: D:\ZIGBEE\COORDONATOR\LIB\HAL_INT0_ISR.OBJ (HAL_INT0_ISR) ADDRESS: 0154H*** WARNING L1: UNRESOLVED EXTERNAL SYMBOL SYMBOL: PCA0_MOD0_ISR MODULE: D:\ZIGBEE\COORDONATOR\LIB\HAL_PCA0_ISR.OBJ (HAL_PCA0_ISR)*** WARNING L1: UNRESOLVED EXTERNAL SYMBOL SYMBOL: PCA0_MOD1_ISR MODULE: D:\ZIGBEE\COORDONATOR\LIB\HAL_PCA0_ISR.OBJ (HAL_PCA0_ISR)*** WARNING L1: UNRESOLVED EXTERNAL SYMBOL SYMBOL: PCA0_MOD2_ISR MODULE: D:\ZIGBEE\COORDONATOR\LIB\HAL_PCA0_ISR.OBJ (HAL_PCA0_ISR)*** WARNING L2: REFERENCE MADE TO UNRESOLVED EXTERNAL SYMBOL: PCA0_MOD0_ISR MODULE: D:\ZIGBEE\COORDONATOR\LIB\HAL_PCA0_ISR.OBJ (HAL_PCA0_ISR) ADDRESS: 009AH#include #include #include "D:/zigbee/Coordonator/include/hal/c8051f120.h"#include "D:/zigbee/Coordonator/include/hal/hal_F121DB.h"//#include "../../include/hal/hal_cc2420.h"#include "D:/zigbee/Coordonator/include/hal/hal_init_f121.h"#include "D:/zigbee/Coordonator/include/Hs_net/HS_Net.h"#include "coordonator.h"..............................void CreateZigbeeCoordinator(void){ nwkcCoordinatorCapable = COORDINATOR_TYPE; if(0 == nlmeNetworkFormationRequest(ScanareCanal, 5, 15, 15, 0x0002,FALSE)){ LED6_ON(); nlmePermitJoiningRequest(0xFF); SET_TASK_CURENT(TASK_JOIN_SUCCESS_ID);.......
  • 4 săptămâni mai târziu...
Vizitator ciociano
as dori sa realizez un circuit cu un senzor de temperatura de pe care sa pot citi datele de care am nevoie pe un pc...din ce am mai intrebat pe altii, am inteles ca am nevoie de 8051 care sa imi transforme datele de la senzor in binar, care sa poata fi citite de calculator...daca poate cineva sa ma ajute cu niste sugestii... sau linkuri... as avea si niste intrebari... cum introduk softul in 8051?
