RAM-i ( care-s mai buni ?)
Vizitator ronix4000
Vizitator ronix4000
sal.am si eu nevoie de ajutor de la cine se pricepe mai bine.Vreau sa-mi cumpar un kit dual channel (2*256 DDR 400) pentru o placa de baza ASUS A7V880 si am de ales intre GEIL (2,5 8-4-4) si GSKILL (2 3-3-6).Spuneti-mi si mie pls care-s mai buni !!!!
  • Răspunsuri 5
Vizitator mister_rf
Acum se pare ca nu sunt prea mari diferente intre acestea...Din ceea ce citim aici:http://www.ap0calypse.com/showthread.php?t=1872
Over the past several months the name GSkill has become synonymous with some of the best performing memory on the market. GSkill?s TCCD based memory is highly sought after for the outrageous speeds and tight timings it is able to achieve. Well what happens if you can not afford this premium memory but are still looking for some decent performance? Enter the new GSkill 2-3-3-6 memory! This may look like your average ?value? RAM, but GSkill makes some pretty big claims, saying ?It is capable of achieving outrageous speeds of up to 433MHZ [at 2-3-3-6] OR DDR480 above at CL 2.5-4-4-8??. DDR480 from a low priced set of PC3200 memory is nothing to turn your nose up at.
Iar un review pentru GEIL la gasim aici:http://www.ocworkbench.com/2003/geil/pc ... 4200-1.htm
Although we are able to run it well beyond 280MHz at CAS 3, 8-4-4, we are unable to even POST at CAS 2, 5-2-2 (6-2-2) above 200MHz FSB at all. In fact, we also tested CAS 2.5, 6-3-3, it POSTED at 200MHz FSB but anything above it, it wouldn't even POST at all. Looks like it could be a BIOS limitation of P4P800S-E ver 1003.
Cred ca GSkill sunt mai bune...
Vizitator ronix4000
dar din punct de vedere al " timingurilor " care-s mai bune..ca nu ma pricep deloc la ram-i....adica intre 2,5 8-4-4 si 2 3-3-6 care-s mai buni? poate poti sa-mi zici si mie pe scurt care-i treaba cu timimgurile astea...
