Clasa A2
blue
Stimate dl Vali
Va rog sa alegeti un PSF conform "materialului clientului" din atasament pentru 8005 si pentru OT100.
Conform celor anexate in catalog este dat modul de folosire in clasa Apentru pentru un tub deschis aproape de disipatia maxima la anod in clasa A.
Va multumesc!
Posted Image
free picture hosting
Domnule matropower văd că nu înţelegeţi mare lucru(încă ,dovadă concretă) ,acel tub 8005 pentru Ug=-200V este blocat indiferent cât va fi Ua.
Pune dumneata "acel PSF" de care faci vorbire aici(în img de mai jos) să vedem ce ai "înţeles" :
poate vezi(matropower) şi caracteristică Ug=-200V pentru clasaA(A1-A2-A22...Axx...) mai ştii...
Arată-ne matropower şi disipaţia maximă la anod când Ug=-200V fixează tu ce Ua(V)=xxxx doreşti...,dar să foloseşti foaia de catalog! că tare bine o citeşti(matropower) :rade: ...
matropower unde ai vazut tu:
? (ai vazut A-Mod si ai zis ca este clasa A??? )
Continuous Commercial Service (CCS) covers applications involving continuous tube operation in which maximum dependability and long tube life are the primary considerations.
Intermittent Commercial and Amateur Service (ICAS) covers applications in which high tube output is a more important consideration than long tube life. The term "Intermittent Commercial" in this title applies to types of service in which the operating or "on" periods do not exceed 5 minutes each, and are followed by "off" or stand-by periods of the same or greater duration. The term "Amateur Service" covers other applications where operation is infrequent or highly intermittent in nature, as well as the use of tubes in "amateur" transmitters. ICAS ratings generally are considerably higher than CCS ratings. Although the ability of a tube to produce greater output power is usually accompanied by a reduction in tube life, the equipment designer may decide that a small tube operated at its ICAS ratings meets his requirements better than a larger tube operated within CCS ratings.
Ce sublinieri faci domnule Lăzăroiu...semeni confuzie, spune-i clar omului(matropower) că trimeterea lui chenar portocaliu înseamnă clasă C. ,eventual explică dumneata (acestui "domn" matropower) ce înseamnă clasa C ,şi/sau matropower să ne lase cu prostia(să fie mai rezervat... până acumulează ceva).
Domnule Lăzăroiu uită-te încă o dată ce scrie matropower aici (ce doreşte să inducă ? ce ! ,cine...):
mai adaugă matropower ăsta aici si cu roşu(mare "deştept"...)(mare "deştept"...)
Stimate dl Vali
Va multumesc!
Posted Image
Stimate dl Vali
Va multumesc!
Posted Image
Dl-e ,cu tot respectul,eu tocmai am vrut sa clarific lucrurile nu sa creez confuzie, zau asa (!!!)din aceasta cauza am subliniat ca sa se citeasca cu atentie si apoi sa se interpreteze datele unui catalog,dar se pare ca nu se prea intelege...
Am pus o poza mai jos cu ceva explicatii,poate asa va fi mai clar,explicatii pe care eu le vad necesare,dar poate si eu gresesc,nu?!
Rezultă clasa din aceste două sublinieri ? 1. download/file.php?id=28634&mode=view2. download/file.php?id=28635
Din primul rezulta clasa de functionare pentru ca am indicat coloana [CI] din tabel unde se specifica clasa de functionare asa dupa cum am aratat acum cu albastru,iar din al-2-lea rezulta firma ce a fabricat OT100,ca sa nu se fac confuzie cu TUNGSRAM-UNGARIA,bineinteles tot conform cu tabelul din catalog,unde se spune ; Echivalent OT100 TU Cred ca mai intai de toate si nu ma refer la dv. sau la cei cu experienta,cand citim un catalog ar trebui sa fim atenti la toate abrevierile folosite de producatorul catalogului respectiv,cam asta am vrut eu sa subliniez.
O pagină în urmă stă scris de mine clasa B sau clasa C telefonie telegrafie(referitor la abrevieri)...
..., poate aşa o fi dar în ce bază ?(în baza clasei B sau C telefonie telegrafie download/file.php?id=28438&mode=view ...)...
Dar matropower nu poate citi merge pe imaginaţie...
" IN ATENTIA LAMPARILOR-SE FOLOSESTE "MATERIALUL CLIENTULUI""
Nu ati observat d-le Vali ca nimeni nu citeste cu atentie mai nimic ce se posteaza pe aici,sau sunt foarte putini acei ce sunt mai atenti si mai profunzi in a studia???
Aici trebuiesc postate alte chestii pentru a fi luate in seama....,nu vreau sa fiu rautacios acum,ar insemna sa nu mai fiu eu dar vb. lui ; "iar cumparam OLTCHIM ?!?!"
nu are legatura cu nicio televiziune ci cu OT adica transformatoare de iesire,output-trafo
Imi pare rau, eu n-am facut nici-o trimitere directa la un anume post TV, am folosit particula "OT" ca sa sugerez ca nu incepe si nu se termina clasa A2 cu OT100/8005; putem avea clasa A2 (foarte productiva) si la 6P3S, 6S33S si... mai toate...
