Vizitator alex_spataru80 Postat Ianuarie 3, 2011 Partajează Postat Ianuarie 3, 2011 Vreau sa imi construiesc un subwoofer cu dif. http://www.visaton.com/en/chassis_zubeh ... 00s_8.html ce ziceti e bun de subwoofer ? observ ca are fs. de 23hz Technical Data: Rated power 150 W Maximum power 200 W Nominal impedance Z 8 Ohm Frequency response fu–4200 Hz (fu: Lower cut-off frequency depending on cabinet) . Mean sound pressure level 92 dB (1 W/1 m) Excursion limit +/−14 mm Resonance frequency fs 23 Hz Magnetic induction 1,1 T Magnetic flux 1400 µWb Height of front pole-plate 8 mm Voice coil diameter 50 mm Height of winding 18,5 mm Cutout diameter 280 mm Net weight 4,5 kg D.C. resistance Rdc 6,7 Ohm Mechanical Q factor Qms 1,65 Electrical Q factor Qes 0,42 Total Q factor Qts 0,33 Equivalent volume Vas 340 l Effective piston area Sd 507 cm² Dynamically moved mass Mms 57 g Force factor Bxl 11 Tm Inductance of the voice coil L 1,8 mH detalii la link...(nu fac reclama) si sper sa functioneze linku' .Astept pareri. Link spre comentariu
mircea888 Postat Ianuarie 3, 2011 Partajează Postat Ianuarie 3, 2011 Merge bine pentru subwoofer, vezi ca producatorii recomanda acolo niste incinte si tuburi bass-reflex aferente.Eu as merge pe 70L din motive de spatiu si aspect, altfel nu te impiedica nimeni sa faci de 100L.Daca respecti cotele tuburilor bass-reflex, realizezi o cutie bine ramforsata si pui si ceva fonoabsorbant ar trebui sa ai un subwoofer foarte bun. Link spre comentariu
