Vizitator razvan cardon Postat Decembrie 14, 2010 Partajează Postat Decembrie 14, 2010 Buna, am intrat in posesia unui Kenwood tk-250 as vrea sa ma ajutati daca se poate sa o pragramez in fregventa pentru radioamatori. Daca se poate si cum? Va multumesc anticipat! Link spre comentariu
Vizitator razvan cardon Postat Ianuarie 8, 2011 Partajează Postat Ianuarie 8, 2011 NU MA POATE AJUTA NIMENI CU UN SFAT MACAR?MAI ASTEPT!VA MULTUMESC SI LA MULTI ANI ! Link spre comentariu
YO9IBC Postat Ianuarie 8, 2011 Partajează Postat Ianuarie 8, 2011 If you have the KPG23D program and a programming cable, you are one step closer...First, you need to startup the program (NOTE:: THE KPG23D PROGRAM WILL NOT RUN UNDER DOS IN WINDOWS XP!!!! YOU WILL NEED TO REBOOT YOUR COMPUTER STRAIGHT TO DOS!!!!)When you have the program started and get to the program screen,1) Press "ALT"2) go to the MODEL menu3) Select the model you have/want...e.g. TK-250 (32 CH), TK-250 (160 CH), TK-350 (32 CH), TK-350 (160 CH).....Keeping in mind the model (250 or 350) you have to program4) hit enter and start writing your program. It will change the software pertaining to the channel capacity when you write to the radio itself.Aveti si softul aici. Link spre comentariu
Vizitator razvan cardon Postat Ianuarie 8, 2011 Partajează Postat Ianuarie 8, 2011 ok. multumim pentru tot ,acum imi ramane sa construiesc sau sa fac rost de cablu.am inteles ca programarea se face in DOS, ,poate nu imi prind urechile pe acolo Link spre comentariu
