BASCOM
yo9hnf
@nico_2010Inca nu mi-a iesit...codul ar fi asta :
$regfile "m32def.dat"$crystal = 16000000'6 mhz crstal$hwstack = 32 ' default use 32 for the hardware stack$swstack = 8Dim Once_a_sec As BitDim Clock_word As WordDim Hours As Byte , Minutes As Byte , Seconds As ByteDim Red As Byte , Green As ByteDim Count As Byte , X As Byte , Segment As ByteDim Number As Byte , Digit_select As ByteDim Del As Byte , Diagdelay As ByteDim Large As WordDel = 1' delay variable in milliseconds' all ports 0Portc = 0 'P0'redPortd = 255 'portd'yellow all high for sw inputsPortb = 0 'portb'green'P3 = 0'blue not usedConfig Debounce = 30' key debounce time in milli secondsConfig Timer0 = Timer , Prescale = 8'Timer0 use timer 0'Gate = Internal no external interrupt'Mode = 2 8 bit auto reload'Gosub Diag' diagnostic routine' set t0 internal interruptOn Timer0 Timer_0_intTimer0 = 250'Priority Set Timer0Enable InterruptsEnable Timer0Start Timer0Hours = 0Minutes = 0Seconds = 0Clock_word = 0Do' yellow port-1 key inputs for settingDebounce Pind.0 , 0 , Hup , SubDebounce Pind.1 , 0 , Hdown , SubDebounce Pind.2 , 0 , Mup , SubDebounce Pind.3 , 0 , Mdown , SubDebounce Pind.4 , 0 , Zero , SubIf Once_a_sec = 1 Then' once_a_sec=calculation every secondOnce_a_sec = 0'update hh mm ssIncr SecondsIf Seconds = 60 ThenSeconds = 0Incr MinutesIf Minutes = 60 ThenMinutes = 0Incr HoursIf Hours = 24 ThenHours = 0End IfEnd IfEnd IfEnd If' display time constantly' hoursNumber = Hours / 10Portb = 31Gosub DispWaitms DelPortc = 0'-------Number = Hours Mod 10Portb = 47Gosub DispWaitms DelPortc = 0'-------'minutesNumber = Minutes / 10Portb = 55Gosub DispWaitms DelPortc = 0'-------Number = Minutes Mod 10Portb = 59Gosub DispWaitms DelPortc = 0'-------'SECONDSNumber = Seconds / 10Portb = 61Gosub DispWaitms DelPortc = 0'-------Number = Seconds Mod 10Portb = 62Gosub DispWaitms DelPortc = 0'-------Loop' - - - - - - - - - - - - - - - - - -' set keys belowHup:Incr HoursIf Hours >= 24 ThenHours = 0End IfReturnHdown:Decr HoursIf Hours = 255 ThenHours = 23End IfReturnMup:Incr MinutesIf Minutes >= 60 ThenMinutes = 0End IfReturnMdown:Decr MinutesIf Minutes = 255 ThenMinutes = 59End IfReturnZero:Hours = 0 : Minutes = 0 : Seconds = 0Return' - - - - - - - - -- - - - - - - -- - - - - -Diag:'diagnostics'if zero button pressed then goto zero label and returnDiagdelay = 121For Seconds = 1 To 5Diagdelay = Diagdelay - 20Portb = 1For Green = 0 To 5Portc = 1For Red = 0 To 7Debounce Pind.4 , 0 , Zero , SubWaitms DiagdelayRotate Portc , LeftNext RedRotate Portb , LeftNext GreenNext Seconds' next diag show 000000 to 999999 on all digits' - - - - - - - -- - - - - -- - - - - - - -- - - -For Number = 0 To 9Portb = 1For Large = 1 To 50' approx 1 second time loop with 200 in largeFor Green = 0 To 5Debounce Pind.4 , 0 , Zero , SubGosub DispWaitms DelRotate Portb , LeftNext GreenNext LargeNext NumberReturn'Displaying routineDisp:Restore Tabela' scan 7-seg table to get byte for the digit to displayFor X = 0 To 9Read SegmentIf X = Number Then'if X = value to displayPortc = Segment'then set this value to Port0-redExit For'and exit FOR loopEnd IfNextReturn' int subroutine -----------------Timer_0_int:Incr Clock_wordIf Clock_word > 2000 ThenClock_word = 0Once_a_sec = 1End IfReturn'---- data for 7-seg LED display ------Tabela:Data &H3F , &H06 , &H5B , &H4F , &H66 , &H6D , &H7C , &H07 , &H7F , &H67' end of program
PS : Nu-i vorba inca de ajustarea Timer0 inca...problema e ca nu pot afisa nimic pe Anod Comun.
Din curiozitate intreb: comanda afisoarelor cum o faci?
Ai o interfata, gen ULN2803 sau 2003 si catozii conectati la portul uC?
Asta este schema partii de afisare de pe placa de evaluare.
Posted Image
Sigur ai respectat corespondenta conexiunilor cu specificatiile din program?Tranzistoarele le-ai conectat la portul corespunzator si pe primii 6 pini ai portului cu pricina (PORTB) - in cazul tau primii 4, respectiv PORTB.0 - PORTB.3?
Am respectat totul...-PORTB.0-PORTB.3 - digiti-PORTC.0-PORTC.6 - segmentele-PORTD.0-PORTD.4-butoane.
Pune un osciloscop pe portul de digiti si vezi daca ai semnal si, la fel, si pe cel de segmente.Daca nu ai asa ceva, schimba fusebitul de oscilator al uC pe ceas intern 8 MHz si vezi cum se comporta.Asta pentru ca, pe simulator, programul functioneaza partial, respectiv nu ia comenzi de setare a orelor si minutelor, insa functioneaza secundele!
Salut. Faptul ca nu indica nimic nu mi se pare nici mie ok. Alta problema. In tabela ptr "0" avem 63, unde segmrentul A este D0 si G este D6 ptr catod comun. Pentru anod comun negat ar trebui sa fie 192 sau punind D7 in 0 ar fi 64. Cred eu ca tabela aia atasata este pe invers, dar este adevarat ca nici YO9HNF nu a aratat in desen ordinea cum a conectat pini la integrat. Putina atentie nu strica...poate gresesc si eu.
Salut ywar2!Din schema atasata am presupus ca segmentul a va fi conectat la PORTC.6 si descendent, segmentul g la PORTC.0, iar punctul zecimal (care nu este folosit in schema) a fost alocat ipoteticului PORTC.7 (disponibil numai in varianta TQFP).In consecinta, tabela a fost redactata avand la baza rationamentul de mai sus.Totusi, nu inteleg de ce la YO9HNF nu functioneaza?
Salut. Ptr YO9HNF, m-am uitat pe codul tau si cred ca ar trebui ca sa declari porturile ca fiind intrari si iesiri, iar eu nu am vazut asta la tine. Uite un cod:
Config Portc = OutputPortc = 0                                                   'P0'redConfig Portd = InputPortd = &B11111111Portd = 255                                                 'portd'yellow all high for sw inputsConfig Portb = OutputPortb = 0 'portb'green
Deasemenea, valorile din tabela ar trebui sa fie cele date de tine in al doi-lea exemplu de la inceputul acestui subiect.
Value_table:
Data &H40 , &H79 , &H24 , &H30 , &H19 , &H12 , &H02 , &H78, &H00 , &H10
---73!---
salut tuturor!
Intr-adevar, a sesizat bine ywar2 lipsa configurarii porturilor din program, insa cam asta e totul.
Dupa verificari practice, programul de mai jos functioneaza cu afisoare cu anod comun si "bate secunda" relativ exact!!
Tabela pentru segmentele afisoarelor a avut ca logica de redactare conectarea segmentului "A" la PORTD.6 si segmentul "G" la PORTD.0
PORTC.0 este digitul de secunde, PORTC.1 cel de zeci de secunde s.a.m.d.
De asemenea, setarea prescalerului TIMER0 la 64, iar a variabilei "Clock_word" (din subrutina de intrerupere) la 748 si nu 2000 (ca in programul original) a fost impusa de "precizia" (!?) secundei.
$regfile "m8def.dat"
$crystal = 12000000
'6 mhz crstal
$swstack = 8
Dim Large As Word
Del = 1
' all ports 0
Config Portd = Output
Config Portb = Input
Portd = 255 'P0
'red
Portb = 255 'portd
Portc = 255 'portb
'green
'P3 = 0
'blue not used
Config Timer0 = Timer , Prescale = 64
'Timer0 use timer 0
'Gosub Diag
Timer0 = 100
Enable Interrupts
Enable Timer0
'Start Timer0
Hours = 0
Minutes = 0
Seconds = 0
Clock_word = 0
Do
Debounce Pinb.0 , 0 , Hup , Sub
Debounce Pinb.1 , 0 , Hdown , Sub
Debounce Pinb.2 , 0 , Mup , Sub
Debounce Pinb.3 , 0 , Mdown , Sub
Debounce Pinb.4 , 0 , Zero , Sub
Once_a_sec = 0
'update hh mm ss
Incr Seconds
Seconds = 0
Incr Minutes
Minutes = 0
Incr Hours
If Hours = 24 Then
Hours = 0
End If
End If
End If
End If
' hours
Number = Hours / 10
Portc = 31
Gosub Disp
Waitms Del
Portc = 0
Portc = 47
Gosub Disp
Waitms Del
Portc = 0
'minutes
Portc = 55
Gosub Disp
Waitms Del
Portc = 0
Portc = 59
Gosub Disp
Waitms Del
Portc = 0
'SECONDS
Portc = 61
Gosub Disp
Waitms Del
Portc = 0
Portc = 62
Gosub Disp
Waitms Del
Portc = 0
Loop
' set keys below
Hup:
Incr Hours
If Hours >= 24 Then
Hours = 0
End If
Return
Hdown:
Decr Hours
If Hours = 255 Then
Hours = 23
End If
Return
Mup:
Incr Minutes
Minutes = 0
End If
Return
Mdown:
Decr Minutes
Minutes = 59
End If
Return
Zero:
Return
Diag:
'diagnostics
Diagdelay = 121
Portd = 1
For Green = 0 To 5
Portc = 1
For Red = 0 To 7
Waitms Diagdelay
Rotate Portd , Left
Next Red
Rotate Portc , Left
Next Green
Next Seconds
For Number = 0 To 9
Portc = 1
For Large = 1 To 50
For Green = 0 To 5
Gosub Disp
Waitms Del
Rotate Portc , Left
Next Green
Next Large
Next Number
Return
'Displaying routine
Disp:
Restore Tabela
For X = 0 To 9
Read Segment
If X = Number Then
Portd = Segment
Exit For
'and exit FOR loop
End If
Next
Return
Timer_0_int:
Incr Clock_word
If Clock_word > 748 Then
Clock_word = 0
Once_a_sec = 1
End If
Return
Tabela:
Data &H01 , &H4F , &H12 , &H06 , &H4C , &H24 , &H60 , &H0F , &H00 , &H0C
YO9HNF, daca ai timp, poti verifica acest program si daca totusi ai probleme spune-ne si noua
Putin mai tarziu:
O constatare: se pare ca zecile de minute ale lor nu sunt la fel cu ale noastre
Daca incerci sa scazi minutele din butonul aferent zecilor de minute se constata ca valoarea afisata incepe de la 9 !?
