Cel mai simplu amplificator SE cu lampi EF98, la 6V .
  • Răspunsuri 127
  • Den
    31
  • +_Florin_+
    11
  • blue
    9
  • mișa
    6
Probabil ca aceste experiente cu tuburi alimentate la tensiuni reduse par interesante, totusi semiconductoarele au performante mai bune in acest caz si daca pierderea de vreme nu este importanta, merita incercata o comparatie :101
Se pare ca in audio conductia in vid de aude mai bine decat conductia in siliciu sau germaniu sau orice alte cristale chiar si la tensiuni reduse.Lasand gluma la o parte incercati un amplif pe lampi la tensiune redusa (schemele de la Elektor, schemele lui B. Kainka, etc...), sigur va va fermeca.Sau si mai bine pentru cei ca "Toma necredinciosul", o schema de final AF cu tubul 12AK5 utilizata in radioreceptoarele auto la 12V de prin anii '50. :daO lista cu tuburi proiectate sa functioneze la 12V:12AC6 remote cutoff pentode12AD6 pentagrid converter12AE6 dual diode, medium mu triode12AE7 dual triode12AF6 remote cutoff pentode12AJ6 dual diode, high mu triode12AL8 medium mu triode, power tetrode12BL6 remote cutoff pentode12CN5 remote cutoff pentode12CX6 remote cutoff pentode12DE8 diode, remote cutoff pentode12DK7 dual diode, power tetrode12DL8 dual diode, power tetrode (diodes have own cathode)12DS7 dual diode, power tetrode12DU7 dual diode, power tetrode12DV8 dual diode, power tetrode (diodes have own cathode)12DY8 medium mu triode, remote cutoff tetrode12DZ6 remote cutoff pentode (curves are in 1963 RCA tube handbook)12EA6 remote cutoff pentode12EC8 medium mu triode, semiremote cutoff pentode12EG6 pentagrid amplifier12EK6 remote cutoff pentode12EL6 dual diode, high mu triode12EM6 diode, power tetrode12F8 dual diode, remote cutoff pentode12FK6 dual diode, low mu triode (triode curves are in 1963 RCA tube handbook)12FM6 dual diode, medium mu triode12FX8 medium mu triode, pentagrid converter12GA6 pentagrid converter12J8 dual diode, power tetrode12K5 power tetrode12U7 twin medium mu triodeAceste lampi au aparut in perioada de tranzitie fiind destinate sa lucreze in echipamente alimentate la tensiune joasa si sa preia functiuni pe care tranzistorii inca nu le puteau realiza cu succes.
Am doua clasa A pe tranzistori,dar totusi,o sa ascult la asta pe lampi de acum inainte,nu e nevoie sa spun mai mult.Cu toate ca lampile cred ca sunt aproape epuizate(sunt recuperate),nici macar nu au aceeasi constructie interna,iar trafurile sunt vai mama lor,eu nu am auzit la semiconductori acest sunet.Si am joase,asa cum nu le-am auzit niciodata pe siliciu.Pe moment ma multumesc si cu putinul care il am.Nu a mai fost nevoie sa alerg dupa trafuri de alimentare ciudate,la fel ca in montajul din elektor,am multiplicat cei 24 de volti disponibili pentru filamente ca sa folosesc o tensiune mai mare anodica,dar nu am observat diferente mari intre 24 si 67 de volti in anod la volum mediu.Parca apar niste distorsiuni la volum mare la 24v pe partea de inalte,dar la 60 de volti anodica e chiar ok.
Exact asta incercam sa-i explic lui @blue; nu trebuie neaparat sa ai sute de volti ca sa functioneze un etaj final pe lampi, sunt scheme si lampi care pot sa se "descurce" si la tensiune redusa. Iar in ceea ce priveste calitatea sunetului este de departe net superioara semiconductoarelor.
:86
Schema final audio cu 12K5:
Posted Image
:aplauze Felicitari pentru realizare.Caracasa e faina, insa sper sa reziste la temperaturi mai mari in zona tubului. De preferat era sa-i montezi soclurile pe textolit (sticlotextolit), pertinax sau chiar bachelita.Am vazut ca l-ai facut in varianta stereo. La 60V ce putere scoate (aproximativ)?
Pai cu trafurile care le am banuiesc ca sare de 1,5w(apar bineinteles si distorsiuni catre maxim) cu catodul pus la masa prin condensator,dar am si cadere de putere in sursa de alimentare,am o rezistenta de 330 pusa acolo cu rol de filtru care se incinge in functionare,urmaresc sa o schimb cu un soc,in poza se vede ca suntam cu o rezistenta de putere de 10r,dar inevitabil imi aparea si brum in auditia pe casti,lucru care nu-mi convine. Tensiunea mea pe filamente e de 22v :ciuda: ,se incing si asa destul de mult tuburile,dar sper sa reziste suportul din plexiglass.
Da este o solutie si cu filamentele subalimentate pentru controlul temperaturii pentodelor dar are legatura directa si cu distorsiunile de care vorbeai mai ales la volum maxim.Am incercat si eu sa alimentez filamentul la 24V, anod/filament cu aceiasi sursa cum spunea si Kainka in articolul publicat in revista elektor, dar se auzea distorsionat la volum maxim.Insa la 27V pe filament a prins viata, scoate un sunet cald melodios, fermecator, si fara distorsiuni.Am sa incerc sa-l alimentez la 27V filament si 60V anodica sa vedem ce putere are. Este de fapt experimentul pe care l-ai realizat. :rzb
La 27v functioneaza lampa iar la 22V anexele, lasind gluma la o parte trebuie sa sti ca o lampa cu filamentul subvoltat duce la schimbarea drastica a parametrilor acesteia, devine necontrolata si se uzeaza prematur in cazul tensiunii anodice normale ( nu este cazul pt tensiunea aleasa ) Daca te uiti pe caracteristica ce arata PSF-ul, vei vedea ca este foarte neliniara in cazul tensiunilor anodice reduse, iar in afara puterii mici debitate si a distorsiunilor mari nu ai nici un avantaj...
Am gasit solutia intre timp.Le am alimentate la 27,4v filamentele.Le am pornite cam de o ora amandoua tuburile pe suporturi .Momentan rezista,nu radiaza multa caldura in jos,catre suporturi,sa vad peste vreo 3 ore cum se prezinta.-96v anodica ar fi maximul care l-as aplica.Ce se aude?
Un Ua= 96v pozitiv incepe sa sune mai bine, se apropie de functionarea in regim liniar cu un curent anodic decent, filamentul alimentat corect, asa da, mai trebuie un transformator de iesire cojones si bun venit in lumea lampilor adevarate :aplauze
Ok.Eu sunt mai incepator in lumea tuburilor,ceva imi spune ca nu mai am voie in acest caz sa suntez rezistenta de 100r din catod cu condensator pentru cresterea puterii..corect?Prevazusem carcasa cu un intrerupator care sa faca acest lucru.Ce utilitate sa mai gasesc eu la intrerupatorul ala?Gaura e data si el fixat :sparge:Uitam de G2..vad ca in majoritatea schemelor se alimenteaza cu maxim 60v.Iar rebobinare traf de alimentare in secundar..Poate ar fi bine sa rupa un moderator in alt topic,pentru ca m-am decis sa trec pl-urile in regimuri mai normale de functionare..
Ok.Uitam de G2..vad ca in majoritatea schemelor se alimenteaza cu maxim 60v.Iar rebobinare traf de alimentare in secundar..
Salut, in catalog Ua este 50V pentru PL504 vezi aicisi 75V pentru PL500 aiciConcluziile cred ca sunt clare.Am cuplat etajul final la un receptor cu PCH200 alimentat din aceiasi sursa la 27V. Se aude destul de puternic oricum mult peste un etaj final cu DL96 alimentat la 90V. DL96 detalii_9SVaicDS3c RAdZU9XyvfE PS:Important este sa se auda bine nedistorsionat si sa fi tu multumit de amplif, cu teoria niciodata n-o scoti la capat; Iar legat de schemele de la elektor poti sa ai incredere deplina, sunt serioase. :da
Un amplificator util alimentat la tensiune redusa este si cel cu tubul final DL96, pe care l-am experimentat cu rezultate excelente. Transformatorul este cel utilizat si in experimentul cu tubul PL504...Schema este extrem de simpla si usor de realizat: :dans: :dans: :dans:
