EROARE F03 indesit WISE 107X
Vizitator gigione
Vizitator gigione
Salut,am si eu o nelamurire, masina mea de spalat imi da intruna,aleator, eroare f 03... am verificat NTC, releu comanda rezistenta incalzire schimbat si tot degeaba.Va rog mai dati-mi detalii sau trebuie resoftat eeprom...Cu stima Mihai !
  • Răspunsuri 4
  • c87dak
  • tv1
  • ianc
Indesit FAULT 03
1.Check the efficiency of the connector J8 on the board and on NTC. - Clean the contacts of connector J8 and tighten the connector.
2.Check NTC (the value of resistance is 20 Kohm at a temperature of 20 °C) - Replace NTC.
3.Warm the NTC rubbing it, check if resistance value lowers.- Replace NTC.
4.Check continuity of wiring J8 pin 11 and 12.- Replace wiring.
5.Replace the main board.
REMARK. This fault may occur when the EEPROM is faulty of not programmed. After having checked all, replace the EEPROM if the fault occurs again.
