mitokadona Postat August 11, 2014 Partajează Postat August 11, 2014 bine ca @overseas a reusit sa incarce schemele, deoarece eu an incercat trei zile consecutiv sa le incarc dar nu am reusit. eu am incercat sa le incarc de pe telefon dar nu se incarcau, nu am avut acces la calculator deoatece placa de retea era arsa. Link spre comentariu
Vizitator overseas Postat August 13, 2014 Partajează Postat August 13, 2014 Un radioreceptor cu PCH200 folosind difuzorul de 750Ohmi in locul trafului de iesire. Link spre comentariu
Vizitator overseas Postat August 13, 2014 Partajează Postat August 13, 2014 (editat) Prezint schema unui Radio DRM cu lampa PCH200, cu iesire pentru placa de sunet PC echipat cu soft DREAM. Programul in V2.1.1 se poate descarca de pe ...http://sourceforge.net/projects/drm/files/dream/2.1.1/ Editat August 13, 2014 de overseas Link spre comentariu
Vizitator overseas Postat August 13, 2014 Partajează Postat August 13, 2014 Un receptor VLF... Receptor VLF : https://www.youtube.com/watch?v=vPRRVUyhl90 Software VLF Receiver https://www.youtube.com/watch?v=TDxRhQYg7lQ Submarine transmissions received in Norway at LA3EQ on VLF : https://www.youtube.com/watch?v=Fzg-YgrvTcM Russian Alfa signal 9-15kHz on LF in Stavanger, Norway LA3EQ : https://www.youtube.com/watch?v=6VkODuzZHkk VLF AURORAL CHORUS : https://www.youtube.com/watch?v=FQdrcDyYRiQ Link spre comentariu
Vizitator overseas Postat August 14, 2014 Partajează Postat August 14, 2014 Un receptor VLF... Radio VLF cu tubul PCH200.jpg Receptor VLF : https://www.youtube.com/watch?v=vPRRVUyhl90 Software VLF Receiver https://www.youtube.com/watch?v=TDxRhQYg7lQSubmarine transmissions received in Norway at LA3EQ on VLF : https://www.youtube.com/watch?v=Fzg-YgrvTcM Russian Alfa signal 9-15kHz on LF in Stavanger, Norway LA3EQ : https://www.youtube.com/watch?v=6VkODuzZHkk VLF AURORAL CHORUS : https://www.youtube.com/watch?v=FQdrcDyYRiQ Software de analiza pentru receptorul VLF: http://www.qsl.net/dl4yhf/spectra1.html Notes on Domestic VLF Reception Experimente reusite! Link spre comentariu
Vizitator overseas Postat August 14, 2014 Partajează Postat August 14, 2014 (editat) Un radioreceptor cu PCH200 folosind difuzorul de 750Ohmi in locul trafului de iesire. Radio cu PCH200.pdf SDC15942.JPG Cautand prin arhiva am gasit si schema cu ECH84, in loc de PCH200, tot cu iesire AF direct pe difuzor; aparatul radio functioneaza la 4 baterii de 1,5V sau 5 acumulatori de 1.2V/ 2800mA/h. Editat August 14, 2014 de overseas Link spre comentariu
puriu Postat August 14, 2014 Partajează Postat August 14, 2014 Cea mai frumoasa e schema de radio DRM. Condensatoarele din anodul heptodei trebuie schimbate intre ele. Link spre comentariu
feri.visky Postat August 14, 2014 Partajează Postat August 14, 2014 Ar fi bine sa expuneti principiul DRM.... Link spre comentariu
Vizitator overseas Postat August 16, 2014 Partajează Postat August 16, 2014 Ar fi bine sa expuneti principiul DRM.... Am sa incerc sa fiu cat mai scurt si concis. In principiu DRM inseamna "digital radio mondiale"; aparatul receptioneaza pe o frecventa din US un post care emite in DRM, de exemplu RTL 2 (5990Khz). Din diferenta frecventei oscilatorului 6Mhz cu postul receptionat (infradina) rezulta pe iesire 10Khz aplicati pe intrarea audio a placii de sunet PC echipat cu software DREAM care demoduleaza folosind procesorul. Se considera ca receptia este net superioara in DRM fata de cea clasica si se apropie ca si calitate de FM. Succesul receptiei US DRM este conditionat de stabilitatea oscilatorului si de nivelul semnalului de intrare (de antena)...In schema cu PCH200 am optat pentru un oscilator cu cuart iar ca antena este necesara o antena exterioara longwire. Tensiunea de alimentare trebuie sa fie neaparat stabilizata si bine filtrata. Mai sunt si alte proiecte de receptoare DRM cu tuburi pe net, am gasit un montaj hibrid cu oscilator pilotat de cuart cu tranzistor: http://projectcircuit4u.blogspot.ro/2011/07/drm-direct-mixer-ef956ak5.html Lampa 6AK5 se poate inlocui cu 6J1P Link spre comentariu
Vizitator overseas Postat August 16, 2014 Partajează Postat August 16, 2014 Un exemplu de Decoding DRM (Digital Radio Mondiale): https://www.youtube.com/watch?v=_mCAEAH4wIw Link spre comentariu
feri.visky Postat August 18, 2014 Partajează Postat August 18, 2014 Din locatia ta reusesti sa "prinzi" ceva DRM, chiar si pe cele experimentale de la noi? Link spre comentariu
Vizitator overseas Postat August 19, 2014 Partajează Postat August 19, 2014 (editat) Din locatia ta reusesti sa "prinzi" ceva DRM, chiar si pe cele experimentale de la noi? Mi-ati dat o idee sa caut un post digital romanesc si se pare ca este, conform tabelului actualizat la 18.08.2014. 5910Khz >> trebuie sa gasesc un cuart de 5920 pentru infradina sau 5900Khz pentru supradina... RTL 2 emite doar in zona WEu este dificil de receptionat in EEu. Editat August 19, 2014 de overseas Link spre comentariu
puriu Postat August 19, 2014 Partajează Postat August 19, 2014 Un VFO cu sintetizor nu mai e asa greu de facut ca pe vremuri. Mai usor decat sa gasim cuarturi din 10 in 10 kHz. Link spre comentariu
feri.visky Postat August 21, 2014 Partajează Postat August 21, 2014 ...chiar asa... eu am experimentat asa ceva... : http://dh8hha.darc.de/DRM%20Super%20Elektor.JPG... Link spre comentariu
Vizitator overseas Postat August 22, 2014 Partajează Postat August 22, 2014 ...chiar asa... eu am experimentat asa ceva... : http://dh8hha.darc.de/DRM%20Super%20Elektor.JPG... nu se deschide link-ul la mine... Link spre comentariu
