Ce aparate de radio, produse dupa `90, detineti ?
doru3160
  • 2 săptămâni mai târziu...
RC JVC RC -S5L (Tokyo)
Videoclip:
Country:  Japan
Manufacturer / Brand:  JVC - Victor Company of Japan, Ltd.; Yokohama
Year: 1979 Category: Broadcast Receiver - or past WW2 Tuner
Semiconductors (the count is only for transistors) Semiconductors present.
Main principle Super-Heterodyne (Super in general)
Wave bands Broadcast, Short Wave plus FM or UHF.
Details Cassette-Recorder or -Player
Power type and voltage Line plus power jack, mostly with battery or storage battery / 50/60Hz, 120/220/240; 6 x 1,5; Car Volt
Loudspeaker 2 Loudspeakers / Ø 3.25 inch = 8.3 cm
Power out 2 W (undistorted)
from Radiomuseum.org Model: Compact Stereo Radio Cassette Recorder RC-S5JW - JVC - Victor Company of Japan,
Material Modern plastics (no Bakelite or Catalin)
Shape Portable set > 8 inch (also usable without mains)
Dimensions (WHD) 310 x 152 x 64 mm / 12.2 x 6 x 2.5 inch
Notes
JVC FM/MW/SW Compact Biphonic/Stereo Radio Cassette Recorder Model RC-S5JW.
Slim Line Design
1.0 Watt per channel min. RMS 200 - 10000Hz, 3,2 Ohms, 10% THD
3.2 Watts max
Built in Biphonic Processor
one-Button recording
Auto Stop
External Speaker
Telescopic antenna
Carrying Handle
World Radioreceiver Sony ICF990L 4 Bands LW/MW/SW/FM
Videoclip pe SW:
Country:  Japan
Manufacturer / Brand:  Sony Corporation; Tokyo
Year: 1995 ? Category: Broadcast Receiver - or past WW2 Tuner
Semiconductors (the count is only for transistors) Semiconductors present. TA7358 CXA1019S
Main principle ZF/IF 455/10700 kHz
Wave bands Broadcast, Long Wave, Short Wave plus FM or UHF.
Details
Power type and voltage Line / Batteries (any type) / 220/ 4 × 1,5 Volt
Loudspeaker Permanent Magnet Dynamic (PDyn) Loudspeaker (moving coil) / Ø 10 cm = 3.9 inch
Power out 0.43 W (unknown quality)
Dimensions (WHD) 258 x 133 x 65 mm / 10.2 x 5.2 x 2.6 inch
Notes 3 FM presets.
SW: 5.95 - 18 MHz
AC power cord supplied
Net weight (2.2 lb = 1 kg) 1.8 kg / 3 lb 15.4 oz (3.965 lb)
Editat de Cristian74
  • 3 săptămâni mai târziu...
Sony 3 Bands Receiver ICF 750L:
Videoclip:
Country:  Japan
Year: 1989 Category: Broadcast Receiver - or past WW2 Tuner
Wave bands Broadcast, Long Wave and FM or UHF.
Details
Power type and voltage Line / Batteries (any type) / 220 / 4 x 1,5 Volt
Loudspeaker Permanent Magnet Dynamic (PDyn) Loudspeaker (moving coil) / Ø 8.5 cm = 3.3 inch
Power out 0.5 W (unknown quality)
from Radiomuseum.org Model: ICF-750L - Sony Corporation; Tokyo
Dimensions (WHD) 253 x 122 x 56.5 mm / 10 x 4.8 x 2.2 inch
Notes
Tragegriff in die Rückwand einklappbar, Made in Malaysia
Un circuit intégré Sony CXA1019M.
Prise Casque ou Ecouteur.
Consommation : 4 Watt en mode Secteur.
Net weight (2.2 lb = 1 kg) 0.756 kg / 1 lb 10.6 oz (1.665 lb)
Radioreceiver Sony 3 Bands ICF 403L:
Videoclip:
Country:  Japan
Year: 1999 Category: Broadcast Receiver - or past WW2 Tuner
Semiconductors (the count is only for transistors) 1:
Details
Power type and voltage Dry Batteries / 3 × 1,5 Volt
Loudspeaker Permanent Magnet Dynamic (PDyn) Loudspeaker (moving coil) / Ø 7 cm = 2.8 inch
Power out
from Radiomuseum.org Model: ICF-403 L - Sony Corporation; Tokyo
Shape Very small Portable or Pocket-Set (Handheld) < 8 inch.
Dimensions (WHD) 195 x 100 x 40 mm / 7.7 x 3.9 x 1.6 inch
Source of data - - Data from my own collection
Radioreceiver Panasonic GX500 :
Videoclip:
Poze;
Caracteristici:
- Radio portabil, panou mare pentru cautare usoara
- Scala separata pentru FM / AM / LW / SW si indicator cu led;
- Difuzor mare de 10 cm si antena din ferita pentru sunet mai bun si cautare usoara.
- Buton de acord rotativ proeminent.
Radioreceptorul Panasonic GX30 :
videoclip:
Poze:
Pays:  Japon
Fabricant / Marque:  Panasonic, Matsushita, National ナショナル (also tubes); Osaka
Année: 1985 ?? Catégorie: Radio - ou tuner d'après la guerre 1939-45
Semi-conducteurs (seuls les transistors sont comptés) Semi-conducteurs présents
Principe général Super hétérodyne (en général)
Gammes d'ondes OM (PO), OC et FM (MF).
Particularités
Tension / type courant Secteur et Piles (tous types). / 240; 4 x 1,5 Volt
Haut-parleur HP dynamique à aimant permanent (bobine mobile)
Puissance de sortie
De Radiomuseum.org Modèle: GX-30 RF-1630J - Panasonic, Matsushita,
Matière Plastique moderne (pas de bakélite, ni de catalin)
Forme Portative > 20 cm (sans la nécessité d'un réseau)
Dimensions (LHP) 228 x 130 x 57 mm / 9 x 5.1 x 2.2 inch
Remarques National RF-1630J, FM-MW-SW 3-Band Receiver, High Sensitivity;
SW: 6 - 18 MHz, 4 W power consumption, made in Singapore.
Sa ne mai descretim fruntile, cu o prezentare in aer liber intr-o zi frumoasa de 10 martie.
Sangean RP25 un model rar pe la noi in Romania:
Videoclipuri !
Receptie FM/MW :
Receptie la DX pe MW (530KHz in CW):
Poze :
Country:  Taiwan
Manufacturer / Brand:  Sangean;
Year: 2002 ?? Category: Broadcast Receiver - or past WW2 Tuner
Wave bands Broadcast (BC) and FM or UHF.
Details
Power type and voltage Storage and/or dry batteries / 2 × 1,5 Volt
Power out 0.12 W (unknown quality)
from Radiomuseum.org Model: FM/AM Portable Radio SR-25 - Sangean;
Dimensions (WHD) 70 x 123 x 30 mm / 2.8 x 4.8 x 1.2 inch
0.158 kg / 0 lb 5.6 oz (0.348 lb)
SSB Trans World Receiver SIEMENS RK770
Videoclip receptie SSB 80m/40m/ 20m
Poze:
Year: 1993 Category: Broadcast Receiver
Main principle Superhet, double/triple conversion; ZF/IF 49995/450 kHz
Power type and voltage Line / Batteries (any type) / 220/4x1,5 Volt
Loudspeaker Permanent Magnet Dynamic (PDyn) Loudspeaker (moving coil) - elliptical
Power out 2 W (unknown quality)
Dimensions (WHD) 300 x 190 x 70 mm / 11.8 x 7.5 x 2.8 inch
Notes Nachfolger des RK 670. Wurde auch vom eigentlichen Hersteller SANGEAN unter der Modellbezeichnung ATS-818CS vertrieben.
Net weight (2.2 lb = 1 kg) 2 kg / 4 lb 6.5 oz (4.405 lb)
Price in first year of sale 499.00 DM
  • 4 săptămâni mai târziu...
Si pentru ca ne "chinuim" uneori sa prindem la DX programe FM via Turcia, am facut un videoclip la ei acasa cu programele FM pe un scan de frecventa 88Mhz -108Mhz.:rade:
Am utilizat un Radio Philips AJ3270, din colectie:
Incitare la Radiolență :
Radio Sanyo RP8260UM :
videoclip
Country:  Japan
Manufacturer / Brand:  Sanyo Electric Co. Ltd.; Moriguchi (Osaka)
Year: 1979 ? Category: Broadcast Receiver - or past WW2 Tuner
Semiconductors (the count is only for transistors) 11: 2SC1417 2SC1417 2SC1417 2SC1417 2SC1417 2SC1417 CS9014 CS9014 CS9014 CS5609 CS5609
Main principle Super-Heterodyne (Super in general); ZF/IF 455/10700 kHz; 3 AF stage(s)
Tuned circuits 5 AM circuit(s)     8 FM circuit(s)
Details
Power type and voltage Line / Batteries (any type) / 120; 220 / 3 × 1,5 Volt
Loudspeaker Permanent Magnet Dynamic (PDyn) Loudspeaker (moving coil) / Ø 9.2 cm = 3.6 inch
Power out 1.5 W (max.)
from Radiomuseum.org Model: RP-8260UM - Sanyo Electric Co. Ltd.;
Dimensions (WHD) 242 x 155 x 67 mm / 9.5 x 6.1 x 2.6 inch
Notes
Tuning and battery indicator.
Das Gerät enthält ein Anzeigeinstrument mit dem Feldstärke und Betriebsspannung angezeigt wird.
Im FM-Zf-Teil ist ein Piezofilter eingebaut.
Net weight (2.2 lb = 1 kg) 1.150 kg / 2 lb 8.5 oz (2.533 lb)
