vasy_gsm Postat Septembrie 17, 2005 Partajează Postat Septembrie 17, 2005 Mai Baieti,ce sa fac cu calculatorul meu ca de azi dupa ce am iesit de pe net,nu mai pot sa intru in Task manager,deci cu cele 3 taste: Alt,Ctrl+Del,cand vreau sa intru zice: <>. Link spre comentariu
Vizitator mister_rf Postat Septembrie 17, 2005 Partajează Postat Septembrie 17, 2005 Uite ceva indicatii aici:http://windowsxp.mvps.org/Taskmanager_error.htm Method 1Click Start, Run and type this command exactly as given below:REG add HKCU\Software\Microsoft\Windows\CurrentVersion\Policies\System /v DisableTaskMgr /t REG_DWORD /d 0 /fMethod 2Download and run this REG fix and double-click it:http://windowsxp.mvps.org/reg/EnableTM.regMethod 3Open Registry Editor (Regedit.exe) and navigate to: HKCU \ Software \ Microsoft \ Windows \ CurrentVersion \ Policies\ SystemIn the right-pane, double-click DisableTaskMgr and set it's data to 0 Method 4: Using Group Policy Editor - for Windows XP ProfessionalClick Start, Run, type gpedit.msc and click OK. Navigate to this path User Configuration=> Administrative Templates==> System===> Ctrl+Alt+Delete Options====> Remove Task ManagerDouble-click the Remove Task Manager option. Set the policy to Not Configured. Link spre comentariu
vasy_gsm Postat Septembrie 18, 2005 Autor Partajează Postat Septembrie 18, 2005 Merci mult... Link spre comentariu
