Cod pentru BLAUPUNKT
TITY.A
Salut,Am un cass auto BLAUPUNKT AUGSBURG CR 24 la care nu stiu codul.Pe cass e marcata urmatoarea serie:BP 3759 R 2668398.Daca stiti cumva codul ptr.acest aparat va rog sa ma ajutati.De fapt orice solutie care ma ajuta sa decodez acest cass e binevenita. Va multumesc anticipat.
  • Răspunsuri 2
  • TITY.A
  • dragostalpau
Zile populare
A mers cu 0072.Multumesc, mult si raman dator.Pentru cei ce au un astfel de aparat si vor sa-l decodeze postez aici pasii care trebuie sa-i urmeze:Equipment switch on. In the display Cod becomes; indicated. Station key 1, it becomes 000 briefly presses; indicated. Code number enter: With the station key 1 only 0 can; or 1 are selected. The first 0 one does not indicate. Example: Code number is 0521 - station key 1 press, to in the display 000 stands, - 5 x station key 2 press, 500 in the display, - 2 x station key 3 press, 520 in the display, -, 521 press 1 x station key 4 in the display. Code number confirm: Jack above ^ press. The car radio is ready for use. However again if three lines should appear, you entered a wrong code number. Now absolutely enter after the waiting period (Cod in the display) the correct code number. If the equipment is switched off during one waiting period, then the waiting period begins after restarting new. The waiting period amounts to after the first 3 attempts 10 seconds, after further attempts 1 hour. After 19 unsuccessful attempts OFF becomes; indicated. They cannot take the car radio to no more in enterprise.
