16f628+ds1307+lcd - problema
Mad_Turnip
Salut, am conectat pic-ul cu ds1307, am scris codul :
CMCON=0x07; // disable comparators
TRISA = 0b01100001;
TRISB = 0b00000001;
Lcd_Init(&PORTB);
Lcd_Cmd(LCD_CURSOR_OFF);
Soft_I2C_Config(&PORTA, 0, 7); // Initialize full master mode
Soft_I2C_Start(); // Issue start signal
Soft_I2C_Write(0xD0); // Address DS1307
Soft_I2C_Write(0); // Start from word at address 0
Soft_I2C_Write(0x80); // Write 0x80 (stop counter and zero seconds)
Soft_I2C_Write(0x30); // Write 30 to min
Soft_I2C_Write(0x20); // Write 20 to hrs
Soft_I2C_Write(1); // Write 1 - day of week
Soft_I2C_Write(2); // Write to day of month
Soft_I2C_Write(6); // Write 6 to month
Soft_I2C_Write(9); // Write 9 to year
Soft_I2C_Write(0x10); // SQWE output at 1 Hz
Soft_I2C_Stop(); // Issue stop signal
si nu imi da semnal pe sqw si pe lcd apare ???? .SCL si SDA au fost pull-up cu 10k si acum sunt cu 4,8k, bateria la ds1307 este conectata dar tot nu palpaie led-ul de pe sqw. Vreo solutie ?
  • Răspunsuri 0
  • Mad_Turnip
Zile populare
