dem3ntor Postat August 18, 2010 Partajează Postat August 18, 2010 stie cineva cum se reseteaza eroarea c0500 la un konica bizhub163?Mltumesc! Link spre comentariu
tv1 Postat August 18, 2010 Partajează Postat August 18, 2010 Cauta in service manual.Service manual Konica Minolta Bizhub 163 ( 14 parti;download toate partile si dezarhivare cu WinRar ) http://www.eserviceinfo.com/downloadsm/ ... 20163.html part01 http://www.eserviceinfo.com/downloadsm/ ... 20163.html part02 http://www.eserviceinfo.com/downloadsm/ ... 20163.html part03 http://www.eserviceinfo.com/downloadsm/ ... 20163.html part04 http://www.eserviceinfo.com/downloadsm/ ... 20163.html part05 http://www.eserviceinfo.com/downloadsm/ ... 20163.html part06 http://www.eserviceinfo.com/downloadsm/ ... 20163.html part07 http://www.eserviceinfo.com/downloadsm/ ... 20163.html part08 http://www.eserviceinfo.com/downloadsm/ ... 20163.html part09 http://www.eserviceinfo.com/downloadsm/ ... 20163.html part10 http://www.eserviceinfo.com/downloadsm/ ... 20163.html part11 http://www.eserviceinfo.com/downloadsm/ ... 20163.html part12 http://www.eserviceinfo.com/downloadsm/ ... 20163.html part13 http://www.eserviceinfo.com/downloadsm/ ... 20163.html part14 Link spre comentariu
tv1 Postat August 19, 2010 Partajează Postat August 19, 2010 stie cineva cum se reseteaza eroarea c0500 la un konica bizhub163? Multumesc! Din manualul de service :C0500 error = Warm-up failure. Descriere:The surface temperature of the fusing roller does not reach a given level even after the lapse of a given period of time during a warm-up cycle. Resetare:Turn ON the power switch with the Stop key held down. Link spre comentariu
dem3ntor Postat August 19, 2010 Autor Partajează Postat August 19, 2010 asa am facut si eroarea a disparut, dar a aparut alta problema:c0f32: faulty TCR sensor :(este senzorul de pe drum. daca il desfac si il curat merge cam 5-6 pagini, dupa care iar da eroare. nu stiu ce sa ii fac :(oare daca desfac bucati si curat drum unit de toner si il asamblez sunt sanse sa isi revina?in manual scrie doar replacing tcr sensor, nu scrie nimic de curatare.Multumesc! Link spre comentariu
