vumetru: ce zice acolo?
Vizitator Fenex
  • Răspunsuri 3
  • Stefan
  • adimoscaty
Zile populare
Cu acelasi circuit am facut si eu un vumetruAm realizat schema de la typical applicationNu ai nevoie decat de 3 rezistenteSchema e alimentata de la 12VIn locul triungiului acela e semireglabilul de 5k
@Fenex ce bine era daca respectai putin forumul asta, puteai posta aici -> viewtopic.php?f=35&t=4603&start=270
pe site-ul esp audio spune asa:
Note: The total supply voltage must be greater than the reference voltage, but the circuit will work perfectly with supply voltage down to 5V for a reference voltage of 4V or less. If a low voltage supply is used, RDC and DC+ may simply be joined together. The use of raw DC is only a requirement with supply voltages above around 12V to keep the dissipation of the LM3915 within ratings.
Posted Image
Vizitator Fenex
ahaaa, eci asa merge... ok, ms@adimoscaty ai vazut ca este mai in jos in fisieru .pdf unu vumetru cu 20 de leduri? cred ca pe ala ma bag :freaza: acum am unu de 5...merge si asta da vreau mai mare
