Ajutor incepator 16f690 (pickit 2)
Vizitator sorinpetrila
Am inceput si eu cu greu . Am pornit de la lectiile prezentate la pickit2 si le-am modificat vrand sa obtin cate ceva. Acum stau de o zi intreaga si ma intreb ce am gresit.Programul original care functioneaza:
#include __config (_INTRC_OSC_NOCLKOUT & _WDT_OFF & _PWRTE_OFF & _MCLRE_OFF & _CP_OFF & _BOR_OFF & _IESO_OFF & _FCMEN_OFF) cblock 0x20Delay1 ; Define two file registers for theDelay2 ; delay loop endc org 0Start: bsf STATUS,RP0 ; select Register Page 1 bcf TRISC,0 ; make IO Pin B.0 an output bcf STATUS,RP0 ; back to Register Page 0MainLoop: bsf PORTC,0 ; turn on LED C0OndelayLoop: decfsz Delay1,f ; Waste time. goto OndelayLoop ; The Inner loop takes 3 instructions per loop * 256 loopss = 768 instructions decfsz Delay2,f ; The outer loop takes and additional 3 instructions per lap * 256 loops goto OndelayLoop ; (768+3) * 256 = 197376 instructions / 1M instructions per second = 0.197 sec. ; call it a two-tenths of a second. bcf PORTC,0 ; Turn off LED C0OffDelayLoop: decfsz Delay1,f ; same delay as above goto OffDelayLoop decfsz Delay2,f goto OffDelayLoop goto MainLoop ; Do it again... end
Am incercat sa maresc delay-ul pentru a mentine ledul aprins mai mult:
#include __config (_INTRC_OSC_NOCLKOUT & _WDT_OFF & _PWRTE_OFF & _MCLRE_OFF & _CP_OFF & _BOR_OFF & _IESO_OFF & _FCMEN_OFF) cblock 0x20Delay1 ; Define two file registers for theDelay2Delay3 ; delay loop endc org 0Start: bsf STATUS,RP0 ; select Register Page 1 bcf TRISC,0 ; make IO Pin B.0 an output bcf STATUS,RP0 ; back to Register Page 0MainLoop: bsf PORTC,0 ; turn on LED C0OndelayLoop: decfsz Delay1,f ; Waste time. goto OndelayLoop ; The Inner loop takes 3 instructions per loop * 256 loopss = 768 instructions decfsz Delay2,f ; The outer loop takes and additional 3 instructions per lap * 256 loops goto OndelayLoop decfsz Delay3,f ; Waste time. goto OndelayLoop ; The Inner loop takes 3 instructions per loop * 256 loopss = 768 instructions ; call it a two-tenths of a second. bcf PORTC,0 ; Turn off LED C0OffDelayLoop: decfsz Delay1,f ; same delay as above goto OffDelayLoop decfsz Delay2,f goto OffDelayLoop decfsz Delay3,f goto OffDelayLoop goto MainLoop ; Do it again... end
Ledul ramane doar aprins :sparge: Unde am gresit? Merci anticipat pentru ajutor.
  • Răspunsuri 8
  • sofian
  • izua
Zile populare
Ledul clipește, dar suficient de repede cât să treacă de limita de remanență vizuală a ochiului. Mărește delay-ul.
In primul program exista doar delay 1 si 2...apoi am adaugat delay3 si la on si la off....ledul sta aprins
Mărește valoarea delay-ului. Defapt, inițializeaz-o la ceva înainte să o mărești. Tu acolo ai delay[x], dar valorile lor inițiale sunt ce s-o nimeri prin ram (valori complet aleatoare), nu ceva cunoscut. Dacă valorile alea sunt 0 nici nu vei avea delay.
Poți calcula valorile folosind utilitarul ăsta.
Am pus 2 secunde in urmatorul program......se aprinde, se stinge si asa ramane
#include <p16F690.inc>    __config (_INTRC_OSC_NOCLKOUT & _WDT_OFF & _PWRTE_OFF & _MCLRE_OFF & _CP_OFF & _BOR_OFF & _IESO_OFF & _FCMEN_OFF)    cblock 0x20Delay1                   ; Define two file registers for theDelay2Delay3                   ; delay loop     endc           org 0Start:     bsf       STATUS,RP0          ; select Register Page 1     bcf       TRISC,0             ; make IO Pin B.0 an output     bcf       STATUS,RP0          ; back to Register Page 0	movlw	0x11	movwf	Delay1	movlw	0x5D	movwf	Delay2	movlw	0x05	movwf	Delay3MainLoop:     bsf       PORTC,0             ; turn on LED C0OndelayLoop:     decfsz    Delay1,f            ; Waste time.       goto      OndelayLoop         ; The Inner loop takes 3 instructions per loop * 256 loopss = 768 instructions     decfsz    Delay2,f            ; The outer loop takes and additional 3 instructions per lap * 256 loops     goto      OndelayLoop              decfsz    Delay3,f            ; Waste time.       goto      OndelayLoop         ; The Inner loop takes 3 instructions per loop * 256 loopss = 768 instructions                                   ; call it a two-tenths of a second.           bcf       PORTC,0             ; Turn off LED C0OffDelayLoop:     decfsz    Delay1,f            ; same delay as above     goto      OffDelayLoop     decfsz    Delay2,f     goto      OffDelayLoop     decfsz    Delay3,f     goto      OffDelayLoop     goto      MainLoop            ; Do it again...     end
trebuie sa initialiezi din nou valorile delay1,2,3 dupa ce se stinge ledul altfel o sa ai delay maxim
cum fac asta? care e comanda? (scuze...chiar sunt incepator)Multumesc.
Prima data incarci valorile ptr delay si dupa aceea apelezi delay
     org 0Start:     bsf       STATUS,RP0          ; select Register Page 1     bcf       TRISC,0             ; make IO Pin B.0 an output     bcf       STATUS,RP0          ; back to Register Page 0MainLoop:	bsf       PORTC,0             ; turn on LED C0	call Load_Delay	call Delay	bcf       PORTC,0             ; Turn off LED C0	call Load_Delay	call Delay	goto MainLoopLoad_Delay:	movlw   0x11	movwf   Delay1	movlw   0x5D	movwf   Delay2	movlw   0x05	movwf   Delay3	returnOndelayLoop:	decfsz    Delay1,f	goto      OndelayLoop	decfsz    Delay2,f	goto      OndelayLoop	decfsz    Delay3,f	goto      OndelayLoop	return
Merci ...am prins ideea
