Motorola Radio Interface Box ( RIB )
Vizitator daniborca
Vizitator daniborca
Pentru programat statii motorola. 100LEI Se trimite oriunde in tara cu posta romana, 10 lei.
Tel.0730434123
[email protected]
Timisoara
Radio Interface Box for Motorola Radio's ( RIB )
This is a substitute for the Motorola programming Radio Interface Box (RIB). It is not a clone of their RIB. tested at time of manufacture to be free of defects. This unit does not include any manuals or instructions for use. Therefore, it will be assumed that the purchaser is knowledgeable in using the RIB for the applications it is designed for. Software is not included with this item.
With the correct software and programming lead this will allow the programming of a minimum of the following hand portables & mobiles including:
Astro Saber, CDM1250, CDM1550, CDM1550-LS, CDM1550LS Plus, CDM750, CM140, CM160, CM200, CM300, CM340, CM360, CP040, CP140, CP150, CP160, CP180, CP200, CT150, CT250, CT450, CT450-LS, DeskTrac, EM200, EM400, EP450, EX500, EX600, EX600-XLS, GL2000, GM1280, GM140, GM160, GM300, GM3188, GM338, GM340, GM350, GM360, GM3688, GM380, GM600, GM640, GM640, GM660, GM900, GM950, GP1200, GP1280, GP2000, GP2100, GP238, GP280, GP300, GP318, GP320, GP328, GP328 Plus, GP338, GP338 Plus, GP340, GP344, GP350, GP360, GP380, GP388, GP600, GP620, GP640, GP660, GP680, GP88, GP900, GR300, GR400, GR500, GTX LTR Portable, GTX Mobile, GTX Portable, GTX Privacy Plus Portable, HT600, HT600E, HT800, HT1000, HT1250, HT1250-LS, HT1250-LS Plus, HT1550, HT1550-XLS, HT600, HT600E, HT750, HT800, JT1000, LCS2000, LTS2000, LTS2000, M10, M100, M120, M1225, M130, M200, M400, MaraTrac, MaxTrac, MCX1000, MCX600, MCX760, MCX780, MOF230, MT1000, MT2000, MT2100, MTS2000, MTX-LS, MTX800, MTX8000, MTX810, MTX820, MTX8250, MTX8250-LS, MTX838, MTX850, MTX850-LS, MTX888, MTX900, MTX9000, MTX9250, MTX950, MX1000, MX2000, MX3000, P040, P080, P110, P200, P210, P500, PM400, PR400, PR860, PRO2150, PRO3100, PRO3150, PRO5100, PRO5150, PRO5350, PRO5450, PRO5550, PRO5750, PRO7100, PRO7150, PRO7350, PRO7450, PRO7550, PRO7750, PRO9150, PTX1200, PTX600, Saber Si, SM120, SM50, Spectra High Power, Spectra Low Power, Sportbase, Systems Saber, Visar, VL130, XTS3000, XTS3500 and all other Motorola radios compatible with the original Motorola RIB.
The RIB box comes with 3 ft serial port cable. It features an on/off switch, red data transfer LED to show active communication with the radio and white LED to show power ON status. The unit has a DC 9V internal battery compartment and an external DC 9V jack to use with an optional power supply. Dimensions: 100 x 60 x 28mm. Weight:180g.
  • Răspunsuri 0
Zile populare
