Vizitator seryfull Postat August 21, 2004 Partajează Postat August 21, 2004 Rated power 80 Watt Maximum power 120 Watt Nominal impedance 4 Ohm Frequency response (-10 dB) fu - 7500 Hz (fu: Lower cut-off frequency depending on cabinet) . Mean sound pressure level 87 dB (1W/1m) Maximum cone displacement 20 mm Resonance frequency fs 43 Hz Magnetic induction 1 Tesla Magnetic flux 660 µ Weber Height of front pole-plate 6 mm Voice coil diameter 3,5 cm Height of winding 1,2 cm Cutout diameter 18,3 cm Net weight 1,2 kg D.C. resistance Rdc 3,6 Ohm Mechanical Q factor Qms 3,51 Electrical Q factor Qes 0,69 Total Q factor Qts 0,58 Equivalent volume Vas 49 l Effective piston area Sd 211 cm2 Dynamically moved mass Mms 18 g Force factor Bxl 4,98 T · m Inductance of the voice coil L 0,55 mH acest difuzor+tweeter PIEZO tip goarna (pana-n 100W) va merge bine??Si numai daca vrei sau daca ai timp imi poti spune si mie o mica idee la Incinta???multumesc!!! Link spre comentariu
Vizitator Vasile Postat August 21, 2004 Partajează Postat August 21, 2004 Am sa-ti fac un mic proiect :)Dar mai ai rabdare cam pana maine :P Link spre comentariu
Vizitator seryfull Postat August 21, 2004 Partajează Postat August 21, 2004 iti multumes!!! Link spre comentariu
Vizitator Vasile Postat August 21, 2004 Partajează Postat August 21, 2004 Visatonu asta merge bine intro incinta inchisa de vro 30 litri Cauta proiectul in folderul meu de pe [email protected] ca l-am pus acolo Link spre comentariu
Vizitator seryfull Postat August 21, 2004 Partajează Postat August 21, 2004 da selectez acel proiect si nu merge Link spre comentariu
Vizitator Vasile Postat August 21, 2004 Partajează Postat August 21, 2004 Ce nu merge ? Este un Pdf perfect functional, chiar l-am incercat sa vad daca nu cumva este defect :P http://www.izatech.as.ro/vasile/T%20200.pdf Link spre comentariu
Vizitator seryfull Postat August 21, 2004 Partajează Postat August 21, 2004 il accesez dar mi-apare sa trimit un mesaj!! Link spre comentariu
Vizitator Vasile Postat August 21, 2004 Partajează Postat August 21, 2004 Vezi-l aici si mai sus in in postul meu :wink: Link spre comentariu
Vizitator seryfull Postat August 21, 2004 Partajează Postat August 21, 2004 multumesc f. mult iti raman dator cu o 'bere' pe net!!!)))) Link spre comentariu
