Routere WiFi cu Linux OpenWrt
Guest1
Vizitator pvd2010
ce am reusit sa fac eu pana acum: am adaugat un stick usb astfel ca pot instala aplicatiile suplimentare cu optiunea -d: "opkg -d usb install nume_pachet". Samba nu am reusit sa il pornesc desi imi apare "smbd" acolo unde trebuie.Pt torenti m-am descurcat cu Transmission si al lui web-admin, dupa cum se vede mai jos.
Unelte necesare:
Putty (Sau ssh in cazul in care aveti Linux pe desktop)
Winscp (windows)
Flash USB de preferinta USB 2.0
1. Se instaleaza pachetele pentru USB 2.0
opkg update
opkg install kmod-usb2
2. se instaleaza modulele pentru storage
opkg install kmod-usb-storage
3. Verificare incarcare module:
insmod ehci-hcd
insmod scsi_mod
insmod sd_mod
insmod usb-storage
(trebuie sa va apara ceva mesaje cu allready loaded)
puteti introduce un Flash USB
apoi dati c-da.
dmesg
ar trebui sa gasiti ceva de genul:
hub.c: new USB device 01:02.0-2, assigned address 2
usb.c: USB device 2 (vend/prod 0xd7d/0x100) is not claimed by any active driver.
Initializing USB Mass Storage driver...
usb.c: registered new driver usb-storage
scsi0 : SCSI emulation for USB Mass Storage devices
Vendor: Kingston Model: Drive Rev: 1.05
Type: Direct-Access ANSI SCSI revision: 02
Attached scsi removable disk sda at scsi0, channel 0, id 0, lun 0
SCSI device sda: 1024000 512-byte hdwr sectors (981 MB)
sda: Write Protect is off
Partition check:
/dev/scsi/host0/bus0/target0/lun0: p1
WARNING: USB Mass Storage data integrity not assured
USB Mass Storage device found at 2
USB Mass Storage support registered.
4. Se instaleaza pachetul pentru ext3 (eu am preferat sa formatez flash-ul in sistemul nativ de fisiere Linux)
opkg install kmod-fs-ext3
5. Se instaleaza fdisk
opkg install fdisk
6. se instaleaza programul de formatare al flash-ului
opkg install e2fsprogs
7. Se creeaza o partitie de tip ext3
fdisk /dev/scsi/host0/bus0/target0/lun0/disc
8. Se formateaza
mke2fs -j /dev/scsi/host0/bus0/target0/lun0/part1
9. Se creeaza punctul de montare
mkdir /mnt
10. Se monteaza flash-ul
mount -t ext3 /dev/scsi/host0/bus0/target0/lun0/part1 /mnt
11. Se creeaza un folder root in tmp, unde se poate copia continutul squashfs
mkdir /tmp/root
mount -o bind /rom /tmp/root
12. Copiem in /tmp/root continutul
cp /tmp/root/* /mnt -a
13. Demontam /tmp/root si /mnt
umount /tmp/root
umount /mnt
14. Stergem linkul simbolic init
rm /sbin/init
15. Il inlocuim cu scriptul urmator:
!!! AICI este bine sa aveti instalat winscp, este cel mai usor mod de copy/paste
#!/bin/sh
# change this to your boot partition
boot_dev="/dev/scsi/host0/bus0/target0/lun0/part1"
# install needed modules for usb and the ext3 filesystem
# **NOTE** for usb2.0 replace "uhci" with "ehci-hcd"
# **NOTE** for ohci chipsets replace "uhci" with "usb-ohci"
for module in usbcore ehci-hcd scsi_mod sd_mod usb-storage jbd ext3; do {
insmod $module
}; done
# this may need to be higher if your disk is slow to initialize
sleep 4s
# mount the usb stick
mount "$boot_dev" /mnt
# if everything looks ok, do the pivot root
[ -x /mnt/sbin/init ] && {
mount -o move /proc /mnt/proc && \
pivot_root /mnt /mnt/mnt && {
mount -o move /mnt/dev /dev
mount -o move /mnt/tmp /tmp
mount -o move /mnt/jffs2 /jffs2 2>&-
mount -o move /mnt/sys /sys 2>&-
# finally, run the real init (from USB hopefully).
exec /bin/busybox init
16. Se face executabil noul init
chmod a+x /sbin/init
17. Reboot
reboot & exit
Daca Aveti un flash cu led, o sa vedeti ca in timpul procesului de boot acesta se aprinde (deci este accesat)
Dupa boot va reconectati cu putty (sau ssh din Linux) pe router si verificati spatiul disponbil:
df
sau df -h
si trebuie sa vedeti discul ocupat 2-3%.
Inca nu am ajuns acasa (sa incerc si practic), daca ceva nu functioneaza spuneti-mi si o sa repet procedura pe Topex-ul meu, dar in mare asta am facut si functioneaza de ceva timp.
Puteti sa va inspirati si de aici:
http://wiki.openwrt.org/oldwiki/usbstoragehowto
cu doua modificari:
ce apare cu verde (sper) in script
si
scriptul l-am luat de la White Russian si nu de la Kamikaze (cred ca este o greseala a autorului articolului)
AMMMMMMMM REEEEEEEEUUUUUUUUUSIIIIIIIIIIIIIIITTTTTTTTTTTTTTTTTTTTTTT !!!!!!!!!!!!!!!!!!!!BRAVO MIE :))))))))))May 31 10:39:34 OpenWrt daemon.notice pppd[784]: pppd 2.4.3 started by root, uid 0May 31 10:39:35 OpenWrt local2.info chat[791]: abort on (BUSY)May 31 10:39:35 OpenWrt local2.info chat[791]: abort on (NO CARRIER)May 31 10:39:35 OpenWrt local2.info chat[791]: abort on (ERROR)May 31 10:39:35 OpenWrt local2.info chat[791]: report (CONNECT)May 31 10:39:35 OpenWrt local2.info chat[791]: timeout set to 10 secondsMay 31 10:39:35 OpenWrt local2.info chat[791]: send (AT&F^M)May 31 10:39:35 OpenWrt local2.info chat[791]: expect (OK)May 31 10:39:35 OpenWrt local2.info chat[791]: AT&F^M^MMay 31 10:39:35 OpenWrt local2.info chat[791]: OKMay 31 10:39:35 OpenWrt local2.info chat[791]: -- got itMay 31 10:39:35 OpenWrt local2.info chat[791]: send (ATE1^M)May 31 10:39:35 OpenWrt local2.info chat[791]: expect (OK)May 31 10:39:35 OpenWrt local2.info chat[791]: ^MMay 31 10:39:35 OpenWrt local2.info chat[791]: ATE1^M^MMay 31 10:39:35 OpenWrt local2.info chat[791]: OKMay 31 10:39:35 OpenWrt local2.info chat[791]: -- got itMay 31 10:39:35 OpenWrt local2.info chat[791]: send (AT+CGDCONT=1,"IP","internet"^M)May 31 10:39:36 OpenWrt local2.info chat[791]: timeout set to 30 secondsMay 31 10:39:36 OpenWrt local2.info chat[791]: expect (OK)May 31 10:39:36 OpenWrt local2.info chat[791]: ^MMay 31 10:39:36 OpenWrt local2.info chat[791]: AT+CGDCONT=1,"IP","internet"^M^MMay 31 10:39:36 OpenWrt local2.info chat[791]: OKMay 31 10:39:36 OpenWrt local2.info chat[791]: -- got itMay 31 10:39:36 OpenWrt local2.info chat[791]: send (ATD*99***1#^M)May 31 10:39:36 OpenWrt local2.info chat[791]: expect (CONNECT)May 31 10:39:36 OpenWrt local2.info chat[791]: ^MMay 31 10:39:36 OpenWrt local2.info chat[791]: ATD*99***1#^M^MMay 31 10:39:36 OpenWrt local2.info chat[791]: CONNECTMay 31 10:39:36 OpenWrt local2.info chat[791]: -- got itMay 31 10:39:36 OpenWrt local2.info chat[791]: send ( ^M)May 31 10:39:36 OpenWrt daemon.info pppd[784]: Serial connection established.URAAAAAAAAAAAAAAA !!!SCUZATI ENTUZIASMUL DAR MARE NEVOIE AM DE ACEASTA APLICATIE :)
La instalarea modulelor pt hdd, pui si formatele "ntfs" si poate kiar si "ext2 si ext3" (kmod-fs-ntfs, kmod-fs-ext2, kmod-fs-ext3), sa fie just in case.
La ftp inca nu am facut setari. U have to google it.
Pt torenti:
Intri in Luci, system, apoi software, apoi update pack list, apoi cauti "ctorrent", bifezi, apply si uite un scurt tutorial (ii apartine lui torx):
Hope it helps.
Torx
Formatul ntfs il pui degeaba pe kernel 2.4
Foloseste numai kmod-fs-vfat, kmod-fs-ext2, kmod-fs-ext3.
Pentru torrent eu folosesc dctcs peste kamikaze.
Instalarea pe router Topex Deluxe (4MB flash) se face in ordinea: mai intai torrent si pe urma suportul de USB file sistem.
Pe Premium (8MB flash) puteti face instalarea in ce ordine vreti voi. Idem pentru cei care boot-eaza de pe USB sau SD/MMC-card.
Router-ul trebuie sa fie conectat la internet.
Comezile sunt:
opkg update
opkg install http://sites.google.com/site/yodctcs/dc ... mipsel.ipk
Dupa cele de mai sus instalati suportul de USB fs.
Cand ati terminat editati fisierul /etc/dctcs.conf
Mai jos aveti dctcs.conf folosit de mine.
Aveti grija sa va creati directorul /mnt/torrent pe hardisk-ul extern:
mkdir /mnt/torrent
si sa dati drepturi de scriere in acel director
chmod 777 -R /mnt/torrent
Mai jos in loc de:
user=utilizator
password=xxxxxxxxxxxx
Puneti user-ul vostru si parola cu care vreti sa va conectati la interfata grafica.
#sample config file
#change these according to your system
torrent-directory=/mnt/torrent/
download-directory=/mnt/torrent/
#change user name and password
user=utilizator
exit-hours=168
exit-ratio=5.6
cache-size=1
restart-torrents=0
download-limit=0
upload-limit=0
check-interval=0
port=18000
#arbitrary arguments to ctorrent
ctorrent-args=-a
#run command after download complete see ctorrent -X for details
ctorrent-complete=command
#url to prepend in the details box
detail-url=ftp://192.168.1.1/mnt/torrent/
#arbitrary arguments to wget
wget-args=-c
#write-stats=1
ctorrent=/usr/bin/ctorrent
client-host=localhost:15000
htmlroot-directory=/usr/share/dctcs/www/darkside.ctcs.gui/
wget=/usr/bin/wget
Acum trebuie sa porniti serviciul de dctcs
root@OpenWrt:~# /etc/init.d/dctcs enable
root@OpenWrt:~# /etc/init.d/dctcs start
In acest moment puteti accesa interfata grafica la
http://adresaIProuter:18000
Tibi
- conexiune la interent -multumesc lui Neve pentu ajutor
- setare hdd extern pe USB
- setare client de torrent
- setare FTP
Am cautat un tutorial pentru interfata Luci dar se pare ca nu exista.....sau nu am dat eu de el.
Setare hdd extern pe usb s-a mai prezentat.
Clinet de torrent ai mai sus.
Pentru FTP foloseste SFTP. Este mai sigur si se instaleaza din interfata grafica.
openssh-sftp-server
Accesul il faci cu WINSCP.
Tibi
am urmat tutorialul lui tvicol dar m-am oprit la primii pasi ca nu am decat 900k liberi de memorie. Ca sa mai liverez din ea trebuie sa mai sterg anumite chestii dar nu prea stiu ce sa mai sterg din lista astfel incat sa ramana functional route-ul.Acum am instalate: Package name VersionDelete base-files 39-r19932Delete busybox 1.15.3-1Delete dnsmasq 2.52-1Delete dropbear 0.52-4Delete firewall 1-10Delete iptables 1.4.6-1Delete iptables-mod-conntrack 1.4.6-1Delete iptables-mod-nat 1.4.6-1Delete kernel 2.4.37.9-1Delete kmod-brcm-wl 2.4.37.9+4.150.10.5.3-6Delete kmod-diag 2.4.37.9-6Delete kmod-fs-nfs-common 2.4.37.9-1Delete kmod-ipt-conntrack 2.4.37.9-1Delete kmod-ipt-core 2.4.37.9-1Delete kmod-ipt-nat 2.4.37.9-1Delete kmod-ipt-nathelper 2.4.37.9-1Delete kmod-ppp 2.4.37.9-1Delete kmod-pppoe 2.4.37.9-1Delete kmod-scsi-core 2.4.37.9-1Delete kmod-switch 2.4.37.9-2Delete kmod-usb-core 2.4.37.9-1Delete kmod-usb-storage 2.4.37.9-1Delete kmod-usb2 2.4.37.9-1Delete kmod-wlcompat 2.4.37.9+4.150.10.5.3-6Delete libc 0.9.30.1-39Delete libgcc 3.4.6-39Delete libiptc 1.4.6-1Delete liblua 5.1.4-5Delete libuci 0.7.5-1Delete libuci-lua 0.7.5-1Delete libxtables 1.4.6-1Delete lua 5.1.4-5Delete luci-admin-core 0.9+svn5711-1Delete luci-admin-full 0.9+svn5711-1Delete luci-app-firewall 0.9+svn5711-1Delete luci-cbi 0.9+svn5711-1Delete luci-core 0.9+svn5711-1Delete luci-http 0.9+svn5711-1Delete luci-i18n-english 0.9+svn5711-1Delete luci-ipkg 0.9+svn5711-1Delete luci-lmo 0.9+svn5711-1Delete luci-lucid 0.9+svn5711-1Delete luci-nixio 0.9+svn5711-1Delete luci-px5g 0.9+svn5711-1Delete luci-sgi-cgi 0.9+svn5711-1Delete luci-sys 0.9+svn5711-1Delete luci-theme-base 0.9+svn5711-1Delete luci-theme-openwrt 0.9+svn5711-1Delete luci-uci 0.9+svn5711-1Delete luci-uvl 0.9+svn5711-1Delete luci-web 0.9+svn5711-1Delete mtd 11Delete nas 4.150.10.5.3-6Delete nvram 5Delete opkg 513-1Delete ppp 2.4.4-4Delete ppp-mod-pppoe 2.4.4-4Delete uci 0.7.5-1Delete ucitrigger 0.7.5-1Delete wireless-tools 29-4Delete wlc 4.150.10.5.3-6ma puteti ajuta cu catvea sfaturi ce sa sterg ca sa nu il bulesc. multumesc
Poti sa razi tot ce tine de firewall, luci-http. Faci instalarea, dupa care le repui.Sau, in loc de backfire, faci instalarea peste kamikaze.Tibi
si... nu ne spui si noua cum ai reusit? :aplauze
Cum sa nu , doar nu-i secret de stat precum vad ca se practica pe alocuri , unde mai pui ca-i si usor atunci cand esti motivat :aut:
Asadar dupa tutorialul de A I C I instalarea se face usor mie luandu-mi muuuuult mai mult decat trebuia din motive de neconcentrare.
Important este sa dezactivezi optiunea de stick a modemului cum a spus -radu2000v- :
Ptr. a folosi ZTE MF100 pe Linux trebuie configurat ZTE MF100 un pic altfel.
Mai intai conectezi ZTE MF100 pe un comp. cu Windows, el se instaleaza (din partea detectata ca si mass storage).
Te uiti in Device Manager pe ce port sa instalat.
Deschizi un hyperterminal (pe portul gasit in Device Manager) cu setarile:
Speed: 115200
Data bits: 8
Parity: None
Stop bits: 1
Flow Control: None
Introduci comanda: AT+ZCDRUN=8
asta va dezactiva mass storage din MF100.
Acum ar trebui sa fie detectat ca si modem in Linux.
Atentie copiati undeva fisierele care apar la introducerea modemului (in windows) pentru a le putea instala si pe alte calculatoare.
Pentru revenire la stadiul initial (reactivare mass storage), din hyperterminal se introduce AT+ZCDRUN=9.
Odata facuta operatia ai sa vezi ca modemul este detectat ca : 0x19d2/0x16 ceea ce trebuie introduci conform tutorialului mai sus mentionat.
Apoi problema cea mai mare pe care am avut-o a fost punerea caii catre modem in optiunea de wan (am pus wan nu 3g) adica :
/dev/usb/tts/2 la mine . Ei eu in loc de /dev/usb/tts/2 am tot insistat pe /dev/usb/tts/0 si /dev/usb/tts/1 :ras:
Odata facute aceste operatii treaba a fost MIiiiiiNUuuuuuuuuNAaaaaaaaaTAaaaaa !
Acum nu reusesc in fel si chip sa intalez o camera web :bataie conform ACESTUI tutorial.
Nu reusesc sa instalez spca5xx si sa-l pornesc :jytuiyu
Ma ajuta cineva ?
Vizitator anzi
Referitor la montarea HDD pe USB, cateva observatii;
- Hdd sa aiba alimentare externa (pe ASUS original a functionat fara probleme un HDD de laptop alimentat direct din USB, fata de Topex care necesita alimentare externa) si partitiile sa fie primare!
- Se pot folosi avantajele partitionarii HDD-ului (memorie swap, pachetele instalate pe o alta partitie, datele partajate sau de alta natura, pe alta partitie,...) daca va inspirati din :
http://wl500g.info/showthread.php?t=10307 (tutorial pentru Oleg, dar perfect adaptabil si la openWRT)
http://wiki.openwrt.org/oldwiki/usbstoragehowto (utilizare mediu extern de date pe usb)
Documentatie utila mai gasiti si aici:
http://www.macsat.com/oldguides/ (tutoriale de interes general)
