Routere WiFi cu Linux OpenWrt
Guest1
zanga, poti pune orice hdd de laptop,orice capacitate,hdd-urile de laptop(cu adaptor sata>usb) consuma de obicei maxim 500mA(2.5wati)
Nu ai tu alimentare la routerele astea care sa tina inca 2,5W non-stop.
... cea externa trebuie sa fie de minim 2A.
Asa da!Poate!Imi cer scuze,dar in graba mea nu am specificat ca ma refeream la alimentatorul extern :jytuiyu .Si ,daca nu folosesti modemul GPRS, ii poti folosi alimentarea(el o are separat), dar asta implica ceva modficari mai importante pentru un incepator...
Stie cineva care ar fi cel mai mare hdd-extern care as putea sa il pun fara sa fie nevoie de alimentare separata?
Am postat in acest topic cum sa va folositi de alimentarea auxiliara a router-ului, caz in care puteti conecta orice HDD extern si sa-l alimentati din router fara probleme.Tibi
Vizitator zam0d3gykus
Salut,
Am o problema cu instalarea unei placi wifi atheros.
Lucrez cu un topex bazat pe wl500gp la care am facut urmatoarele:
- montat o placa minipci cu atheros 5212
- instalat Backfire 10.03.1-rc4
- opkg update; opkg install kmod-madwifi
Dupa reset, router-ul nu mai porneste.
Ultimele mesaje ce le vad pe consola sunt despre initializarea placii wifi.
ath_hal: module license 'Proprietary' taints kernel.Disabling lock debugging due to kernel taintath_hal: 2009-05-08 (AR5210, AR5211, AR5212, AR5416, RF5111, RF5112,RF2413, RF5413, RF2133, RF2425, REGOPS_FUNC, XR)ath_pci: trunkwlan: trunkwlan: mac acl policy registeredath_rate_minstrel: Minstrel automatic rate control algorithm 1.2 (trunk)ath_rate_minstrel: look around rate set to 10%ath_rate_minstrel: EWMA rolloff level set to 75%ath_rate_minstrel: max segment size in the mrr set to 6000 usPCI: Enabling device 0000:00:02.0 (0000 -> 0002)PCI: Fixing up device 0000:00:02.0Atheros HAL provided by OpenWrt, DD-WRT and MakSat Technologieswifi0: 11a rates: 6Mbps 9Mbps 12Mbps 18Mbps 24Mbps 36Mbps 48Mbps 54Mbpswifi0: 11b rates: 1Mbps 2Mbps 5.5Mbps 11Mbpswifi0: 11g rates: 1Mbps 2Mbps 5.5Mbps 11Mbps 6Mbps 9Mbps 12Mbps 18Mbps24Mbps 36Mbps 48Mbps 54Mbpswifi0: turboA rates: 6Mbps 9Mbps 12Mbps 18Mbps 24Mbps 36Mbps 48Mbps 54Mbpswifi0: turboG rates: 6Mbps 12Mbps 18Mbps 24Mbps 36Mbps 48Mbps 54Mbpswifi0: H/W encryption support: WEP AES AES_CCM TKIPath_pci: wifi0: Atheros 5212: mem=0x40000000, irq=6
Apoi routerul nu mai face nimic.
Nu intoarce promot si ramane inaccesibil prin IP.
M-am gandit ca o fi placa wifi de vina, insa comportarea e identica dac a o schimb.
Am incercat si cu o placa cu atheros 5213, dar acelasi rezultat.
Are cineva vreo sugestie ?
Ce-i de facut ?
Mersi.
  • 4 săptămâni mai târziu...
Vizitator yo3gts
@tvicolas fi interesat de un topex cu gprs-ul functional sa-l folosesc cu o cartela de vodafone ocazional...nu tin neaparat sa aiba openwrt...
Toate au gprs-ul functional si vin cu openwrt.Depinde numai de tine sa-l instalezi si sa-l configurezi.Daca doresti un router customizat te rog sa ma contactezi pe pm sau mail.Tibi
Vizitator yo3gts
salut, nu ai PM-ul activat...trimite-mi te rog pe mail oferta ta pentru unul gata configurat pentru k3765...in afara de openwrt nu mai exista si ceva cu interfata grafica?multumesc
  • 2 săptămâni mai târziu...
Vizitator anduq
Salut, am o mica problema cu un WL500gx:
1. Instalat OpenWRT
2. jucat cateva ore cu tot felul de configuri
3. icon_jook icon_jook
4. pe fondul pasului de mai sus, introdus comanda "mtd erase pmon" in loc de "mtd erase nvram" - nu chiar cea mai inteligenta comanda data de mine vreodata, Wl500gx si-a luat adios de la boot.
Din cate am citit eu pe wl500g.info si forum ddwrt exista posibilitatea legarii la JTAG si rescrierea sectiunii boot a flashului...INSA...implica asa ceva:
Posted Image deoarece spre deosebire de Linksys, Asus nu a binevoit sa instaleze un header pentru pini.
Exista pe aici cineva din Bucuresti care ar fi interesat de o bere (de fapt mai multe :P) si cu ceva timp liber care sa ma ajute? Adica sa lipeasca sarmele, sa aiba un JTAG si ceva timp sa incarce un CFE nou? sau macar sa lipeasca sarmele...
Vizitator bartalisattila
Buna searaAm o problema.Cand connectezi cu winscp pe routerul meu si intru in directorul root scrie ca "error listing directori" si am un file cu nume "unexpected".Cu putty functioneaza totul ok.Cineva stie ceva despre problema?Astept ajutorul vostruMultumesc mult
Salut,Am o problema cu instalarea unei placi wifi atheros.Lucrez cu un topex bazat pe wl500gp la care am facut urmatoarele:- montat o placa minipci cu atheros 5212- instalat Backfire 10.03.1-rc4- opkg update; opkg install kmod-madwifiDupa reset, router-ul nu mai porneste.Ultimele mesaje ce le vad pe consola sunt despre initializarea placii wifi.
Apoi routerul nu mai face nimic.Nu intoarce promot si ramane inaccesibil prin IP.M-am gandit ca o fi placa wifi de vina, insa comportarea e identica dac a o schimb.Am incercat si cu o placa cu atheros 5213, dar acelasi rezultat.Are cineva vreo sugestie ?Ce-i de facut ? Mersi.
Re-flashuire. Faza cu butonul de reset si telnetul... .trx-ul.... vezi ca scrie pe aici pe undeva...
