neve Postat Aprilie 2, 2011 Partajează Postat Aprilie 2, 2011 Salut,Cum se pot instala pachete fara legatura la net? De exemplu am downloadat paketele pe laptop si vreau sa le instalez pe openwrt, se poate? Sunt chiar pachetele esentiale pt a putea avea net prin modem rds (zte).Multumesc anticipat, Link spre comentariu
Vizitator pvd2010 Postat Aprilie 4, 2011 Partajează Postat Aprilie 4, 2011 Cel mai simplu răspuns vine chiar de la OpenWRT. opkg must have one sub-command argument usage: opkg [options...] sub-command [arguments...] where sub-command is one of: Package Manipulation: update Update list of available packages upgrade Upgrade package(s) install Install package(s) configure Configure unpacked package(s) remove Remove package(s) flag Flag package(s) =hold|noprune|user|ok|installed|unpacked (one per invocation) Force Options: --force-depends Install/remove despite failed dependences --force-maintainer Overwrite preexisting config files --force-reinstall Reinstall package(s) --force-overwrite Overwrite files from other package(s) --force-downgrade Allow opkg to downgrade packages --force-space Disable free space checks --noaction No action -- test only --download-only No action -- download only --nodeps Do not follow dependences --force-removal-of-dependent-packages Remove package and all dependencies --autoremove Remove packages that were installed automatically to satisfy dependencies -t Specify tmp-dir. --tmp-dir Specify tmp-dir. ------------------------------------------------------------------------------------------------------------------ Am ingrosat zona unde sa citesti. Poate te chinui cu vreo două dependinţe dar asta e. Link spre comentariu
neve Postat Aprilie 5, 2011 Partajează Postat Aprilie 5, 2011 Multumesc Pvd2010 si Simmy! Pana la urma am gasit o teava de net si am reinstalat. Dar va fi de ajutor sa stiu cum se instl si fara net. Ma puteti ajuta cu o problema....?! Am instalat modemul usb de la digi (mf 110 sau ceva de genu), il vede pe usb, il vede la categoria umts, imi spune si ce semnal are, totul e frumos (am pus x-wrt, kamikaze 8). Problema e ca daca ii dau comanda prin consola "ifup ppp0" i9mi spune ca ppp0 nu e suportat. Daca pun aceleasi setari la "wan" si dau ifup wan, imi zice ca nu poate seta PIN-ul. Evident am incercat mai multe variante, pe net unii spun intr-un fel, altii altfel. In ultima instanta nu pot sa ma conectez cu sticku usb la net. Vreo recomandare din partea celor care au facut asta, chiar si pe alt model de modem/usb?!? Va multumesc anticipat! Poti proceda in felul urmator, sa zicem ca pachetul se cheama x.ipk si ip-ul routerul-ui este 192.168.1.1 Deschizi un terminal si navighezi in directorul cu pachetul(sau ca sa nu mai navighezi in acel director, in loc de x.ipk ii pui calea completa, gen /home/user/x.ipk) si: 1) scp x.ipk [email protected]:/ 2) ssh [email protected] , bagi parola 3) opkg install /x.ipk Daca are dependinte si crapa, le cauti si procedezi la fel. Dupa ce ai instalat pachetul il poti sterge sa nu ocupe memorie degeaba rm x.ipk @Mindware 2592x1944 Link spre comentariu
neve Postat Aprilie 6, 2011 Partajează Postat Aprilie 6, 2011 Poti proceda in felul urmator, sa zicem ca pachetul se cheama x.ipk si ip-ul routerul-ui este 192.168.1.1 Deschizi un terminal si navighezi in directorul cu pachetul(sau ca sa nu mai navighezi in acel director, in loc de x.ipk ii pui calea completa, gen /home/user/x.ipk) si: 1) scp x.ipk [email protected]:/ 2) ssh [email protected] , bagi parola 3) opkg install /x.ipk Daca are dependinte si crapa, le cauti si procedezi la fel. Dupa ce ai instalat pachetul il poti sterge sa nu ocupe memorie degeaba rm x.ipk @Mindware 2592x1944 Apropos de modem digi net - merge partial (il vede, pot da ping la siteuri si pot instala pakete pe router, deci el are acces la net) dar nu pot intra pe net de pe laptop /wifi/si nici de pe cablu/lan. Am crezut ca e de la firewall. Nu cred ca e cazul. In schimb, am modificat fisierul /etc/config/network pt a putea conecta modemul la net, dar in interfata grafica (x-wrt) imi arata la wan disabled. daca dau enable, imi baga si alte setari pe care nu le vreau. Vreo solutie? Pot schimba x-wrt cu openwrt, fara sa pierd paketele si setarile? Stiu ca setarile se pot mentine, dar vreau sa fiu sigur. Altfel, iara tre sa incep de la inceput cu instalarea. Link spre comentariu
neve Postat Aprilie 6, 2011 Partajează Postat Aprilie 6, 2011 Dupa inca o resoftare "pe uscat", adica fara net, carat paket cu paket pe router - ms simmy si pvd-, chiar a fost de ajutor..... am reusit sa fac sa mearga prostia asta de modem pe topex. Parca nu mai ajungeam sa vad ziua....Cine vrea detalii, cu cea mai mare placere, just say the word.... Link spre comentariu
Ashky Postat Aprilie 13, 2011 Partajează Postat Aprilie 13, 2011 Am si eu niste intrebari. Deoarece am instalat si configurat multe pe acest router, as dori sa-i fac un back-up integral (nvram, flash). Cum se face asta? Este corect ce am scris mai jos? Se salveaza tot?(inclusiv nvram-ul?) Fisierul generat poate fi bagat si in alt router identic? mkdir /mnt/backupmount -o remount,ro /dev/mtdblock/4 /jffsdd if=/dev/mtdblock/1 > /mnt/backup/wrt-backup.trx Link spre comentariu
Vizitator Keffr3n Postat Aprilie 18, 2011 Partajează Postat Aprilie 18, 2011 Ok... today is not a good day for science... Ma tot chinui de vreo luna sa-l fac sa mearga, a crapat prima data cand am vrut sa-i fac upgrade la openwrt, apoi dupa vreo sapt de chin am reusit sa-l repun pe picioare cu scurt pe pinu 9 de la flash si apoi cu backfire, la primul restart iar a crapat.Situatia actuala arata asa:- la pronire se aprind toate ledurile o secunda si se sting- daca ii bag un cablu de retea pe orice port, se aprinde ledul portului respectiv- merge ca switch/hubNu merge faza cu pornit cu reset apasat si incarcat firmware prin tftpNu merg alte metode gasite pe forumuriMi-am facut un cablu serial dintr-un cablu de nokia dku5, (3,3V) si nu transmite nimic pe seriala (UART0/1)Are cineva vreo idee despre ce as putea sa mai incerc?? Link spre comentariu
wwwglro Postat Aprilie 21, 2011 Partajează Postat Aprilie 21, 2011 Dupa inca o resoftare "pe uscat", adica fara net, carat paket cu paket pe router - ms simmy si pvd-, chiar a fost de ajutor..... am reusit sa fac sa mearga prostia asta de modem pe topex. Parca nu mai ajungeam sa vad ziua....Cine vrea detalii, cu cea mai mare placere, just say the word....Daca ai timp, as fi interesat.Merci. Link spre comentariu
neve Postat Aprilie 26, 2011 Partajează Postat Aprilie 26, 2011 Dupa inca o resoftare "pe uscat", adica fara net, carat paket cu paket pe router - ms simmy si pvd-, chiar a fost de ajutor..... am reusit sa fac sa mearga prostia asta de modem pe topex. Parca nu mai ajungeam sa vad ziua....Cine vrea detalii, cu cea mai mare placere, just say the word....Daca ai timp, as fi interesat.Merci.Sal.Cam pe seara o sa postez pasii. Nu e mare lucru, eu m-am incurcat singur cu o setare aiurea....in schimb am alte probleme, ca se blokeaza netu prin stick, si inca nu imi dau seama de ce, din cauza routerului/modemului, sau din cauza conexiunii (am doar 2 liniute semnal). Are momente cand se incurca, dar nu stiu ce le provoaca. Uneori merge 1 zi si o noapte fara prob, alteori se impiedica in aceeasi zi de mai multe ori. Link spre comentariu
Ashky Postat Aprilie 26, 2011 Partajează Postat Aprilie 26, 2011 Si mie mi se deconecta dupa circa 3 , 4 ore si am facut asa: cat>/sbin/reconnect echo "0" > /proc/diag/led/power /bin/sleep 5if ! ifconfig | grep ppp0 > /dev/null; then echo "f" > /proc/diag/led/power date >> /tmp/tmp3g echo "reconectare" >> /tmp/tmp3g /usr/bin/killall pppd /bin/sleep 10 /usr/bin/usb_modeswitch /sbin/ifup wanelse date >> /tmp/tmp3g echo "modemul este conectat" >> /tmp/tmp3gfi echo "1" > /proc/diag/led/power ctrl+d chmod +x /sbin/reconnect vi /etc/ppp/ip-down #!/bin/shdate >> /tmp/tmp3gecho "modem deconectat" >> /tmp/tmp3gsh /sbin/reconnect shift+zz reboot un log poate fi vazut cu: cat /tmp/tmp3g La mine merge asa cu o mica exceptie.Uneori (destul de rar), la reconectare nu-si ia dns-urile, in loc de 193.231.... in log am 10.11.12.13.Aici nu mai stiu sa automatizez treaba.Cand vad becu aprins la modem dar nu merge netu ii dau in cli "/sbin/reconnect" si merge. O idee de verificare a dns-urilor ar fi binevenita. Link spre comentariu
neve Postat Aprilie 27, 2011 Partajează Postat Aprilie 27, 2011 Si mie mi se deconecta dupa circa 3 , 4 ore si am facut asa:cat>/sbin/reconnect echo "0" > /proc/diag/led/power /bin/sleep 5if ! ifconfig | grep ppp0 > /dev/null; then echo "f" > /proc/diag/led/power date >> /tmp/tmp3g echo "reconectare" >> /tmp/tmp3g /usr/bin/killall pppd /bin/sleep 10 /usr/bin/usb_modeswitch /sbin/ifup wanelse date >> /tmp/tmp3g echo "modemul este conectat" >> /tmp/tmp3gfi echo "1" > /proc/diag/led/powerctrl+dchmod +x /sbin/reconnectvi /etc/ppp/ip-down#!/bin/shdate >> /tmp/tmp3gecho "modem deconectat" >> /tmp/tmp3gsh /sbin/reconnectshift+zzrebootun log poate fi vazut cu:cat /tmp/tmp3gLa mine merge asa cu o mica exceptie.Uneori (destul de rar), la reconectare nu-si ia dns-urile, in loc de 193.231.... in log am 10.11.12.13.Aici nu mai stiu sa automatizez treaba.Cand vad becu aprins la modem dar nu merge netu ii dau in cli "/sbin/reconnect" si merge.O idee de verificare a dns-urilor ar fi binevenita.Multumesc mult. O sa incerc. Sper ca diseara sa ajung sa postez pasii pt setare modem. E un "cover" dupa altii, dar stiu macar ca ala merge. :P Link spre comentariu
neve Postat Aprilie 27, 2011 Partajează Postat Aprilie 27, 2011 Dupa inca o resoftare "pe uscat", adica fara net, carat paket cu paket pe router - ms simmy si pvd-, chiar a fost de ajutor..... am reusit sa fac sa mearga prostia asta de modem pe topex. Parca nu mai ajungeam sa vad ziua....Cine vrea detalii, cu cea mai mare placere, just say the word....Daca ai timp, as fi interesat.Merci.Pai dupa cum am zis, e un cover, asa ca trec la detalii: (e posibil ca unele comenzi sa fie in plus, dar eu le-am facut de dragu de a fi, asa ca dk urmati pasii, o sa fie ok)in CLI:Inainte de a folosi sitcku rds/digi net trebuie sa ii deazactivati optiunea de autorun cd. O puteti face din windows prin hyperterminal, sau prin option din control panel la modemuri, ii adugati comanda "AT+ZCDRUN=8" "Run this one to enable it again: AT+ZCDRUN=9 "Google: AT command at ZTE modem will help you"1. opkg update2. opkg install kmod-usb-serial kmod-usb2 kmod-usb-ohci kmod-usb-storage (ultimu e suplimentar, dar dk nu il aveti pe viitor poate fi util)3. cat>/etc/modules.d/60-usb-serialapoi4. usbserial vendor=0x19d2 product=0x0016 maxSize=4096ctrl+d, bisapoi 5. reboot6. opkg install huaweiaktbboapoi7. cat>/etc/init.d/huaweiAktBbo#!/bin/sh /etc/rc.common# Written by Simon Josefsson 2009-03-05. Released into the public domain.START=70start() { huaweiAktBbo}ctrl+d, bis8. chmod +x /etc/init.d/huaweiAktBbo9. /etc/init.d/huaweiAktBbo enable10. opkg install comgt11. vi /etc/config/networkconfig interface wan option ifname ppp0 option proto 3g option device /dev/usb/tts/2 (si asta e un mic dracusor, ca in tutorialu dupa care m-am luat si multi l-au recomandat, e trecut tts/0, ceea ce nu va merge) option apn internet option service umts option ifname ppp0(aici e un mic skepsis, la unii pe net mai apare si pincode 1234 ca "option", dar la sticku meu RDS nu a fost necesar, asa ca dk nu merge fara, incercati sa adaugati si optiunea "option pincode 1234" - sau care pin stiti ca aveti)shift+zzbon, cam asta e. dk nu merge din prima dati un reboot. dk dupa reboot nu merge, intrati in CLI si dati "ifup wan". Asteptati, si ar trebui sa mearga.Bafta! Link spre comentariu
wwwglro Postat Aprilie 29, 2011 Partajează Postat Aprilie 29, 2011 Merci pentru tutorial.Nu ai spus pe ce kernel l-ai instalat....(eu as vrea pe 2.6 - sa mearga si webcam-ul)Merci Link spre comentariu
Guest1 Postat Aprilie 29, 2011 Autor Partajează Postat Aprilie 29, 2011 Daca aveti probleme cu conectarea/stabilitatea 3G va rog sa aplicati modding-ul de mai jos. Daca vreti sa folositi modemul 3G la tara, sau in zone in care acoperirea GSM este la limita si semnalul gsm este foarte slab, o sa observati ca modemul 3G refuza sa se conecteze. Acest lucru se intampla din cauza ca modem-ul 3G este un mare mancator de curent, iar sursa de 5V a router-ului nu va face fata. Topex a prevazut acest lucru si a dotat router-ul cu doua surse cu stabilizatoare in comutatie LM2596. O sursa fixa de 5V pentru router si una ajustabila pentru modemul intern. Sursa interna de 5V am lasat-o nemodificata. In schimb am modificat sursa ajustabila. Pentru a scoate 5V, R22 si R21 trebuiesc eliminate si in locul lor montati un rezistor de 4k7. Scurt intre pinul 3 si pinul 5 de la LM2596adj pentru a trece stabilizatorul pe ON. Pentru ca eu imi doream sa ma asociez 3G, am eliminat modemul Voxon si am conectat un Huawei 1552 pe unul dintre cele doua usb-uri interne, alimentat din sursa modificata. Cu un cablu usb suficient de lung puteti aseza modemul intr-o pozitie cu semnal maxim. Tibi Link spre comentariu
Vizitator blastwind Postat Mai 11, 2011 Partajează Postat Mai 11, 2011 Buna seara tuturor!In urma discutiei telefonice avute cu dl. Vicol, voi prezenta aici problema intalnita.Am achizitionat de la dl. Vicol 2 aparate WL500 Premium. La primul dintre ele am reusit sa instalez cu succes o placa de retea 300M Atheros iar al doilea l-am tinut de rezerva.Ieri am facut rost de o placa de retea identica si cand sa o instalez pe al doilea, urmand exact aceeasi pasi din tutorialul prezentat de dvs pe net, nu am reusit.Am rescris cu tftp imaginea specifica de backfire, am trecut datele de la WAN, am pus o parola pt root si am dat comanda de erase nvram. S-a sters si cand i-am dat commit mi-a zis ca nu se poate gasi etc. Am mers mai departe si dupa reboot am dat update la pachete, lucru care s-a intamplat, aparand ath-9k si madwifi in lista. Eh, aici apare problema, cand dau sa le instaleze, routerul se blocheaza si nu mai da nici IP prin DHCP nimic, nu ma mai pot loga in el. Am incercat si prin comanda in putty si direct din interfata si tot nimic. Singura solutie este un nou tftp etc etc. Am incercat si cu prima placa de pe routerul care l-am facut cu bine acum o luna si la fel patesc. Am repetat procedura de peste 10 ori cred si tot nu vrea.Va rog frumos sa imi spuneti care ar fi problema. Am urmat exact aceeasi pasi din tutorialul dvs, dar nu reusesc pe al doilea router. Este tot model Premium, luat de la un coleg de-al dvs din Pipera impreuna cu primul.Multumesc. Link spre comentariu
