cosmin17 Postat Februarie 15, 2010 Autor Partajează Postat Februarie 15, 2010 aceeasi eroare Link spre comentariu
puiu Postat Februarie 15, 2010 Partajează Postat Februarie 15, 2010 De ce la tine apare 12F629 pic folosit, iar la mine PIC12F675? Link spre comentariu
puiu Postat Februarie 15, 2010 Partajează Postat Februarie 15, 2010 E corect PIC12F629 deorece asa apare in ASM. Eu am folosit PIC12F675 si de aceea imi apareVezi sa nu ai un virus in calculator Link spre comentariu
cosmin17 Postat Februarie 15, 2010 Autor Partajează Postat Februarie 15, 2010 pai pic 12F629 e in fisierul .asmnu am virusi ,ieri am instalat windows-ul si kasperskyarunca o privire in fisierul .asm Link spre comentariu
puiu Postat Februarie 15, 2010 Partajează Postat Februarie 15, 2010 Debug build of project `D:\Lucru\PIC\RX_EL\RX1.mcp' started.Language tool versions: MPASMWIN.exe v5.35, mplink.exe v4.35Preprocessor symbol `__DEBUG' is defined.Sat Jan 16 10:19:48 2010----------------------------------------------------------------------Make: The target "D:\Lucru\PIC\RX_EL\RX_EL.o" is out of date.Executing: "E:\Program Files\Microchip\MPASM Suite\MPASMWIN.exe" /q /p12F675 "RX_EL.asm" /l"RX_EL.lst" /e"RX_EL.err" /d__DEBUG=1Warning[215] D:\LUCRU\PIC\RX_EL\RX_EL.ASM 20 : Processor superseded by command line. Verify processor symbol.Message[301] E:\PROGRAM FILES\MICROCHIP\MPASM SUITE\P12F629.INC 36 : MESSAGE: (Processor-header file mismatch. Verify selected processor.)Message[302] D:\LUCRU\PIC\RX_EL\RX_EL.ASM 54 : Register in operand not in bank 0. Ensure that bank bits are correct.Message[302] D:\LUCRU\PIC\RX_EL\RX_EL.ASM 56 : Register in operand not in bank 0. Ensure that bank bits are correct.Message[302] D:\LUCRU\PIC\RX_EL\RX_EL.ASM 58 : Register in operand not in bank 0. Ensure that bank bits are correct.Make: The target "D:\Lucru\PIC\RX_EL\RX_EL.cof" is out of date.Executing: "E:\Program Files\Microchip\MPASM Suite\mplink.exe" /p12F675 "RX_EL.o" /u_DEBUG /z__MPLAB_BUILD=1 /z__MPLAB_DEBUG=1 /o"RX_EL.cof" /M"RX_EL.map" /W /xMPLINK 4.35, LinkerCopyright © 2009 Microchip Technology Inc.Errors : 0Loaded D:\Lucru\PIC\RX_EL\RX_EL.cof.----------------------------------------------------------------------Debug build of project `D:\Lucru\PIC\RX_EL\RX1.mcp' succeeded.Language tool versions: MPASMWIN.exe v5.35, mplink.exe v4.35Preprocessor symbol `__DEBUG' is defined.Sat Jan 16 10:19:54 2010----------------------------------------------------------------------BUILD SUCCEEDEDAcesta este mesajul care mi-l da Link spre comentariu
cosmin17 Postat Februarie 15, 2010 Autor Partajează Postat Februarie 15, 2010 asm-ul de unde l-ai luat?problema, am impresia ca e de la mesajul asta"Couldn't locate build. Check tool locations"dar nu inteleg cu ce gresesc Link spre comentariu
puiu Postat Februarie 15, 2010 Partajează Postat Februarie 15, 2010 Nu am modificat nimic din ce a trimis sho_gun prima data. Link spre comentariu
cosmin17 Postat Februarie 15, 2010 Autor Partajează Postat Februarie 15, 2010 tu mai setezi ceva sau ai facut exact cum ai descris mai inainte? Link spre comentariu
puiu Postat Februarie 15, 2010 Partajează Postat Februarie 15, 2010 Asa cum am spus acasa l-am si incarcat pe un PIC12F675. Nu am setat nimic in plus, decat ca am inlocuit PIC12F629 cu PIC12F675 Link spre comentariu
cosmin17 Postat Februarie 15, 2010 Autor Partajează Postat Februarie 15, 2010 eu m-am ghidat dupa linkul acesta initial http://picprojects.org.uk/projects/mplab/mplabhowto.htm Link spre comentariu
cosmin17 Postat Februarie 15, 2010 Autor Partajează Postat Februarie 15, 2010 aici ai inlocuit? Link spre comentariu
puiu Postat Februarie 15, 2010 Partajează Postat Februarie 15, 2010 In general pare bine. Eu doua zile nu am achelari si nu pot sa vad detalile. Eu am avut un avantaj ca nestiint limba engleza nu m-am ghidat dupa nici-un site. Am instalat MBLAB 8.43 dupa ce am dezarhivat bibloteca ce am descarct-o de la MICROCHIP. Da am inlocuit numai divece. Link spre comentariu
cosmin17 Postat Februarie 15, 2010 Autor Partajează Postat Februarie 15, 2010 stai putin ..ce biblioteca? eu am instalat doar MPLAB IDE 8.43, mai trebuie si altceva instalat? Link spre comentariu
puiu Postat Februarie 15, 2010 Partajează Postat Februarie 15, 2010 Este vorba de arhiva de la mplam 8.43. Eu intai o descarc, apoi dezarhivez si apoi instalez noua versiune. Fac acest lucru deoarece arhivele le pastrez deoarece sar putea sa nu mearga noua versiune. Nu este vorba de o bibloteca speciala. Link spre comentariu
sho_gun Postat Februarie 15, 2010 Partajează Postat Februarie 15, 2010 Ai instalat MPLAB 8.43 integral ?? Pare ca nu poate apela mplink.exe. Link spre comentariu
