motoras HDD
bogdan666
bine dar scrie ca e pentru hard drive. dar si hdd-ul tot 3 bobine are ce ar putea sa afecteze ? si mai presus de toate care e diferenta intre stepper si bldc (un link ar fi binevenit)
  • Răspunsuri 21
  • bogdan666
    11
  • Badman
  • Liviu M
  • Stefan
Eu zic sa incerci, wikipedia zice sa motoarele pas cu pas sunt subcategorii ale motoarelor BLCD.
Two subtypes exist: * The stepper motor type may have more poles on the stator (fixed permanent magnet). * The reluctance motor. This may not have permanent magnets, just salient poles that are pulled into alignment by timed stator drive.
De altfel si din definitia de pe wikipedia
A brushless DC motor (BLDC) is a synchronous electric motor which is powered by direct-current electricity (DC) and which has an electronically controlled commutation system, instead of a mechanical commutation system comprisingbrushes and a commutator. In such motors, current and torque, voltage and rpm are linearly related.
reiese ca-s cam acelasi lucru. Nu? :nas:
Pe de alta parte, tot cu 4 fire sunt si stepperele (stiu, la tine e BLDC) bipolare. La astea bobinele sunt separate, fiecare fiind alimentata independent, cu 2 fire. Poti sa masori rezistenta dintre fire, sa vezi daca-s 2 sau 3 bobine.
Uite un site unde lucrurile sunt explicate destul de inteligibil.
