Diagnosticarea AUTOMOBILELOR cu ajutorul PC-ului ...
Vizitator balog
Vizitator dorinmf
pun si eu o intrebare mai incomoda:Stie cineva cum pot sa umblu la kilometrajul masinilor?????????????????? eu am un mercedes A 170 ce mi trebuie mai exact sa pot umbla le kilometraj am un program Autodata dar din cate am inteles eu nu se poaate face diagnostic cu elnu stiu ce sa zic mai multe ca sunt incepator in acest domeniu
  • Răspunsuri 116
  • MirceaM
    14
  • Swat Cat
    5
  • niq_ro
    5
  • Cristiano
  • 1 lună mai târziu...
  • 2 săptămâni mai târziu...
am ajuns la concluzia ca elm327 este taticul lor la nr de masini pe care poate sa le citeasca....+ All vehicles regardless of their makes as long as they are OBDII newer than model year 1996. Also include the latest CAN BUS System. Descriptions: It automatically searches for the correct protocol when connected to the vehicle Data Link Connecctor.The main processor chip can automatically detect and convert the most common protocols in use today making this interface capable of working with almost all vehicles. Features: The capabilities of this interface are very much dependent on the selection of software being used.You can perform several operations with this such as: Read diagnostic trouble codes Clear trouble codes and turn off the MIL (?Check Engine? light) Display current sensor data for the following: Enghine RPM Coolant Temperature Fuel System Status Timing Advance Air Flow Rate Vehicle Speed Calculated Load Value Short Term Fuel Trim Long Term Fuel Trim Intake Manifold Pressure Intake Air Pressure Absolute Throttle Position Oxygen Sensor Voltages / associated short term fuel trims Fuel Pressure And a lot more! Software: PCMSCAN ScanMaster-ELM ProScan ScanTool.net v1.10 ScanTool.net v1.1 for ELMScan 5 Digimoto
Ma stresseaza referirea obsesiva la 1996. De obicei fiecare este interesat sa faca ceva (diagnoza) la propriul sau exemplar de masina asa ca invocarea acestei reguli "dupa 1996 este una iar inainte de 1996 cu totul altceva" s-ar putea sa fie mai putin interesanta decat eventuala exceptie.
Este cert ca o schema/solutie/soft pentru diagnoza si care invoca regula de mai sus... este cert ca nu merge pe nici o masina din 1995 sau mai inainte?
Raspunsul meu: nici vorba!!!
Fiecare vrea sa afle daca merge sau nu pe marca si modelul (chiar exemplarul) lui de masina si de obicei exista dificultati si bajbaieli din partea celor care ar trebui sa dea raspunsul (vanzatorii de exemplu).
Deci...
  • 6 luni mai târziu...
Vizitator HORIA C
salut all,am si eu o problema,am si postat la electronica auto,daca are cineva idee la ce service gasesc un tester pentru renault laguna 1 din 96,la service renault pantelimon mi-au spus ca nu au programul,pentru laguna 1,ci doar pentru 2.mie nu-mi mai recunoaste cip-ul de la cheie,cind apas butonul de pe cheie nu functioneaza nici inchiderea,nici sistemul antifurt,nu porneste neam.daca ma poate ajuta cineva,bineinteles,contra cost.....
