Probleme de incepatori
ole
Vizitator bogdan-97
Am rezolvat problema , nici nu mi-a trecut prin cap ca acei pini sunt oarecum inversati . Acum am dat de alta problema : nu poate vedea semnatura device-ului si cand incerc sa-i fac upgrade , cum ii cere "No AVR Tool connected"
Vizitator AEMelectronic
ce parere aveti de codurile mele ? :d
receptor
$regfile "Attiny2313.dat"
Config Portb.0 = Output
Config Portb.1 = Output
Config Portb.2 = Output
Config Portb.3 = Output
Config Portb.4 = Output
Config Portb.5 = Output
Config Portb.6 = Output
Config Portb.7 = Output
Dim A As Byte
Do
If Ischarwaiting() = 1 Then
A = Waitkey()
If A = "A" Then Set Portb.0
If A = "B" Then Reset Portb.0
If A = "C" Then Set Portb.1
If A = "D" Then Reset Portb.1
If A = "E" Then Set Portb.2
If A = "F" Then Reset Portb.2
If A = "G" Then Set Portb.3
If A = "H" Then Reset Portb.3
If A = "I" Then Set Portb.4
If A = "J" Then Reset Portb.4
If A = "K" Then Set Portb.5
If A = "L" Then Reset Portb.5
If A = "M" Then Set Portb.6
If A = "N" Then Reset Portb.6
If A = "O" Then Set Portb.7
If A = "P" Then Reset Portb.7
End If
Waitms 100
Loop
emitator
Config Portb.0 = Input
Config Portb.1 = Input
Config Portb.2 = Input
Config Portb.3 = Input
Config Portb.4 = Input
Config Portb.5 = Input
Config Portb.6 = Input
Config Portb.7 = Input
Do
If Pinb.0 = 1 Then Print "A" 'inainte
If Pinb.0 = 0 Then Print "B" 'stop inainte
If Pinb.1 = 1 Then Print "C" 'inapoi
If Pinb.1 = 0 Then Print "D" 'stop inapoi
If Pinb.2 = 1 Then Print "E" 'stanga
If Pinb.2 = 0 Then Print "F" 'stop stanga
If Pinb.3 = 1 Then Print "G" 'dreapta
If Pinb.3 = 0 Then Print "H" 'stop dreapta
If Pinb.4 = 1 Then Print "I" 'basculare
If Pinb.4 = 0 Then Print "J" 'stop basculare
If Pinb.5 = 1 Then Print "K" 'lumini
If Pinb.5 = 0 Then Print "L" 'stop lumini
If Pinb.6 = 1 Then Print "M" 'rezerva
If Pinb.6 = 0 Then Print "N" 'stop revzerva
If Pinb.7 = 1 Then Print "O" 'rezerva2
If Pinb.7 = 0 Then Print "P" 'stop rezerva2
Waitms 100
Loop
cand imi vor ajunge modulele voi face si proba practica
pana atunci comand uC si fac testul prin legarea pinilor RX-TX
  • 2 săptămâni mai târziu...
Vizitator FocusSAN
Salut! Sunt foarte nou in domeniul microcontrolelor si as vrea sa invat cate ceva despre ele.Tin sa mentionez ca nu am absolut nici cea mai mica idee despre ele. Am un programator, am microcontroler, am fire pentru a-l lega de programator, dar nu stiu cum sa il leg. Daca m-ati putea sa fac primii pasi in acest domeniu (cu sfaturi, link-uri, cu recomandari de carti si alte surse de informare) v-as fi mai mult decat recunoscator.Pentru inceput, cred ca legarea la programator ar fi suficienta :d
Vizitator FocusSAN
Mai sunt interesat, dar am fost putin plecat.
Este vorba de Attiny13 si de ATMEL AVR USBASP ( http://www.elforum.info/viewtopic.php?f=59&t=139992 )
Am reusit cu Extreme Burner sa scriu de cateva ori un cod in el, insa cu mare chin (imi da de foarte multe ori eroare la scriere) si nu am reusit sa aprind nici macar un LED.
Am testat codul in AVR Studio si ar fi trebuit sa functioneze perfect, insa practic nu se intampla nimic. Nu stiu daca trebuie pornit cumva controler-ul (in afara de alimentare).
Ah, si va rog sa imi spuneti daca am conectat controlerul la programator. In afara de vcc, ground, miso, mosi, reset si sck mai este un fir pe care scrie NC. Acel fir trebuie conectat la controler si daca da, unde anume se conecteaza?
Multumesc mult de tot pentru raspunsuri. Sper sa reusesc sa aprind macar un led :da
Vizitator FocusSAN
Este 13A. Asta nu a fost dificil, insa programatul nu imi iese deloc si anume ca nu reusesc sa il scriu. De sters il sterge, il identifica, totul in regula pana la scris. La scris imi spune "Mismatch at location: 0x00000000" invariabil si nu stiu daca e programatorul de vina, programul de scris sau altceva :jytuiyu
Am o intrebare cam "ciudata" Se pot lega doua atmega8 in paralel pe aclasi LCD 16*2? dar fiecare atmega sa indeplineasca diferite functi si ca sa nu se intercaleze afisajul, sa se apreasca doar alimentarea celui "nefolositor" in acel moment.(Am vrut sa incerc cu proteus o simulare dar acesta alimenteaza automat pini),Va afecta cu ceva celalalt atmega? teoretic bagand tensiune pe pini acestuia...P.S. Nu veniti cu sugesti gen exista atmega16/32, etc...pe mine ma intereseaza doar daca merge aceasta configuratie daca DA e bine daca NU de ce?
Ok,ma-m doumentat itre timp si am vazut ac este posibil cu diode pe iesii catre LCD si ceva rezistente, pentru mine este mai usor sa intrerup alimentarea, deaorece nu pot face modificari in toate softurile...Multumesc.
Se pot cupla la acelasi LCD doua sau mai multe CIP-uri (Device-uri). Conditia este ca sa se cupleze terminalele de date si de comanda cu diode de comutatie rapida (1N4148) de la fiecare cip in parte spre LCD. deasemenea ca sa comute diodele trebuie sa fie "incarcate" pe sarcina de 1K la masa. Vezi foto.P.S. Dupa ce am postat am vazut ca te-ai documentat. Oricum las poza sa o vada cei interesati.
