Vizitator Postat Decembrie 19, 2009 Partajează Postat Decembrie 19, 2009 Buba stii care e ?!.ACELASI TRANSFORMATOR-ACELASI DEFAZOR-ACEASI ALIMENTARE(ma rog ceva mai mic g2 in cazul EL500)-ACEASI SARCINA,Asadar...ca nu mai vreau sa intru in dispute infinite... Link spre comentariu
Depanatoru Postat Decembrie 19, 2009 Partajează Postat Decembrie 19, 2009 Ceva nu s-a potrivit , dar in grilele1 sigur era dreptunghiul corect ?Sa zicem ca admit ca e mai "pretentioasa" 6P3S , dar nu ca nu e hi-fi . Mai trebuie testat ... Link spre comentariu
Vizitator Postat Decembrie 19, 2009 Partajează Postat Decembrie 19, 2009 Pai nu se subintelege daca am spus acelasi defazor si fara reactie negativa-sigur semnalul din g1 finale era la fel in ambele cazuri.Testati !... Link spre comentariu
Depanatoru Postat Decembrie 19, 2009 Partajează Postat Decembrie 19, 2009 Tot trebuie verificat , cum capacitatile g1-catod si g1-anod sunt diferite cine stie ... si rezistenta de grila spre masa conteaza - sarcina defazorului impreuna cu capacitatile . Link spre comentariu
zal Postat Decembrie 19, 2009 Partajează Postat Decembrie 19, 2009 Un Quad II cu steroizi: http://www.quad-hifi.co.uk/downloads/quad_qc24_240audition.pdf ------------------------------------------------------------------------- ?i o problem? la condensatori: Coupling Capacitors C2 and C3 As I remark on the redrawn schematic C2 and C3 are "bolted" to the chassis and provide a small capacitance to ground that ? in conjunction with the high load resistors R5 and R6 ? control the frequency response and stability of the amplifier with feedback The frequency response between 10kHz and 50kHz is affected by the type and age of C2 and C3 ? If you have a problem with C2/C3 and wish to keep the amplifier near original then consider a better type of "paper in oil" capacitor but beware of the magic paper in snake oil types sold for more than you should have paid for the amplifiers - HUNTS L45 B406 0.1?F ?20% ? As originally fitted in the QUAD II ? 350V d.c. @ 70°C 200V a.c. @ 70°C capacitance to aluminium case 15pF-25pF (many tested over the years) nom. 22pF. These often go leaky with age - ITT L45/406/T53K 0.1?F ?20% ? A good replacement type ? 500V d.c. @ 70°C ? 250V a.c. @ 70°C ? Capacitance to aluminium case 18pF-27pF note (blue) plastic insulation removed - TCC CP175N 0.1?F ?20% ? Brass case with ceramic end caps ="Super Metalpack" ? 350V d.c. @ 70°C ? 200V a.c. @ 70°C ? Capacitance to case nom. 20pF. Should be better for humid conditions and keep better for longer - ERIE "Duolectric" WF49/AF411K 0.1?F ??% ? 800V d.c. @ 70°C? Capacitance to aluminium case 12pF-15pF. Good low leakage choice of paper capacitor, remove clear plastic insulation - Dubilier Type 470C 0.1?F ?20% ? Very similar to the Hunts L45 ? 350V d.c. @ 70°C ? Often lower capacitance to case 10pF-15pF and just as leaky after a few years in service, remove clear plastic insulation - Plessey "Metalmite" 0.1?F ?20% ? 350V d.c. @ 70°C ? 175V d.c. @ 100°C ? This one only, tested 15pF to case, remove clear plastic insulation - TCC "Metalpack" CP 465 ? 500V d.c. @ 70°C ?350V d.c. @ 100°C ? this one only, tested 30pF, it is longer than the others at 50mm but will fit the QUAD II and is a good replacement, remove clear plastic insulation where fitted - Russian K40Y-9 0.1?F ? 400V d.c ? 10% ? 4 tested and spread from 27pF to 32pF ? Slightly wider than the Hunts L45 at 14.3mm ? Not tested fully by myself but at present I would say it's a good PIO for the QUAD II Note that the capacitance to case is not a feature specified by any manufacturer and neither is the insulation resistance to case although those shown above all had a lower leakage from the outer foil to case than across the capacitor itself ? Outer foil ?? ? Some of the capacitors have a band around one end ? The connection to this end is normally the outside foil of the winding which is nearest to the case and will have a lower insulation to case than the other end ? This is why QUAD placed the band to the grids of the KT66s which are (or should be) near to ground potential but it really makes no difference So if you intend to substitute a metal cased capacitor for C2 and C3 in the original position consider the capacitance and insulation to ground and if possible place the outer foil end to the KT66 grids. If you replace C2 and C3 with insulated body types it may be best to keep them away from the chassis, or even mount them across the tag strip, and provide capacitors of about 27pF to 33pF from the Grids of the KT66s to ground as required Link spre comentariu
zal Postat Decembrie 19, 2009 Partajează Postat Decembrie 19, 2009 Înc? cîteva scheme modificate de Quad ?i altele asem?n?toare. Link spre comentariu
hpavictor Postat Decembrie 20, 2009 Partajează Postat Decembrie 20, 2009 Zal , iti multumesc din suflet pentru contributia ta in special pentru acest subiect , vaduvit as spune , de informatie de calitate ! In ROMANIA aproape nu am cunostiinta sa inteleaga si sa foloseasca reactia in catod , altcineva decat user-ul VALDERAMA , dar o metoda de dimensionare , de calcul oare o exista ? Cu siguranta , orice amplificator SE sau PP , UL sau nu , mai poat obtine un plus in sensul cresterii calitatii redarii , dar trebuie bine dozata reactia din catod ca ordin de marime , amplasata corespunzator intre infasurarile trafo out , iar model sigur , confirmat este doar REVOX , pentru restul ce facem ? Daca se poate as dori sa explice cineva avizat modul de aplicare al reactiei in catod pe un exemplu didactic , gen EL84 SE cum trebuie bobinata infasurarea de catod , daca trebuie modificata infasurarea de anod ( crescuta sau scazuta ) pentru a pastra Ranod , ordinea bobinarii , evident si pentru PP pentru ca altfel devin offtopic , mentionez ca nu agreez cuplajul prin cond electrolitic a infasurarii sarcinii , consider ca este un compromis greu acceptabil singura solutie ramanand infasurare separata ! Va multumesc anticipat si va urez auditii placute si succes in constructii de calitate ! Link spre comentariu
zal Postat Decembrie 21, 2009 Partajează Postat Decembrie 21, 2009 O dat? era de ajuns. S? continu?m: Link spre comentariu
hpavictor Postat Decembrie 21, 2009 Partajează Postat Decembrie 21, 2009 Imi pare rau ca a iesit asa , dar eu intru pe net de pe un tel mobil nokia E51 , nu de pe calculator si atunci cand am trimis mesajul probabil a fost o eroare de retea , rog un moderator sa stearga dublura , multumesc anticipat ! Link spre comentariu
zal Postat Decembrie 22, 2009 Partajează Postat Decembrie 22, 2009 Dup? destul? cazn? am reu?it s? descifrez configura?ia trafo de ie?ire de la Mc275, bazat pe un patent din 1948 al McIntosh. Particularitatea lui e aceea de a fi în acela?i timp traf pilot ?i traf de ie?ire. Sper s? se în?eleag? corect explica?iile. Descrierea cît mai exact? ar fi urm?toarea: Trafo de ie?ire Mc275, model începînd cu 1961. --------------------------------------------------- Bobinarea se realizeaz? cu ajutorul unor fire în paralel, folosindu-se conductori de cupru cu lac special de izolare, acoperi?i cu un strat sub?ire de m?tase ?i din nou înmuia?i în lac electroizolant, astfel se ob?ine un dublu strat izolator. Dou? sau trei astfel de fire sînt unite, împreun? cu un strat sub?ire plastifiant ?i formeaz? o panglic? de fire paralele cu care se bobineaz? transformatorul. Firele au culori diferite pentru identificare. Ele apar exact în desen, în afara firelor de leg?tur? externe ?i a terminalelor. Acest transformator de ie?ire are o impedan?? anodic? în primar de 4kOhmi ?i impedan?a reac?iei catodice de 250 Ohmi. De fapt, exist? un primar bifilar de 1kOhm care atunci cînd înf??ur?rile sînt conectate în serie, cu randamente identice, au 4kOhmi, iar cealalt? înf??urare primar?, identic? ?i format? din al treilea fir, are impedan?a de 250 Ohmi (1/4 din 1k). Reac?ia catodic? este folosit? ?i ca ie?ire cu impedan?a de 600 Ohmi simetric?. Un alt model de traf, are ie?ire de 600 Ohmi simetric? ?i asimetric? de 70,5V. Secundarul, de asemenea, foloseste sîrme bifilare de diametru mai mare ?i are dou? înf??ur?ri cu impedan?a de 5 Ohmi. Primar ptr anodele l?mpilor 6550 ?i 12BH7: 2 înf??ur?ri trifilare de 540 spire cu sîrm? 0,29mm, total 1080 spire. Sîrme de culoare neagr? ?i albastru deschis ptr 6550 ?i maro ptr 12BH7. Primar reac?ie catodic? ptr l?mpile 6550: 1 înf??urare bifilar? de 270 spire cu sîrm? 0,29mm, culoare verde ?i ro?u. Secundar de reac?ie negativ? (16 Ohmi): 67 spire cu sîrm? 1mm ?i priz? la spira 34. Secundar de ie?ire (0, 4, 8 ?i 16 Ohmi): inversat, 67 spire cu sîrm? 1mm ?i prize la 0, 34, 51 ?i 67 spire. Dimensiuni maxime carcas?: 100x100mm. În?l?ime bobinaj în carcas?: 75 mm. Sec?iunea central? a miezului: 50x50mm. Dimensiuni externe miezuri C+C: 150x126mm. L??ime miezuri C: 50mm. Bobinele din anozii tuburilor finale au cîte 2mH. Iat? ?i a?ezarea în carcas? a bobinelor, ultimele secundare (de reac?ie negativ? ?i de ie?ire) nu mai sînt desenate. Link spre comentariu
zal Postat Decembrie 22, 2009 Partajează Postat Decembrie 22, 2009 Trafo de ie?ire la modelul de 50W are aceea?i ideie de baz?, mai pu?in sec?iunile din primar ptr anodele l?mpilor prefinale.Primar ptr anodele l?mpilor 6L6G: 4 înf??ur?ri bifilare de 427 spire cu sîrm? 0,22mm, total 1708 spire.Primar ptr catozii l?mpilor 6L6G: aici lipsesc datele, îns? conform schemei, impedan?a cc e de 600 Ohmi.Secundarele de ie?ire ?i de reac?ie negativ? (impedan?? 5 Ohmi fiecare): inversat, 2x40 spire cu sîrm? 1mm ?i prize la centru.Dimensiuni maxime carcas?: 80x80mm. În?l?ime bobinaj în carcas?: 55 mm.Sec?iunea central? a miezului: 40x40mm.Dimensiuni externe miezuri C+C: 116x96mm.L??ime miezuri C: 40mm. Link spre comentariu
zal Postat Decembrie 23, 2009 Partajează Postat Decembrie 23, 2009 O erat? la textul de mai sus, uH s-a transcris microH, de unde a ajuns mH. Deci e vorba de 2uH, valoare folosit? la multe din amplifurile McIntosh. ...Bobinele din anozii tuburilor finale au cîte 2mH.... Link spre comentariu
zal Postat Decembrie 24, 2009 Partajează Postat Decembrie 24, 2009 S? r?sucim cu?itul în ran?: http://www.turneraudio.com.au/8585-amp-october-2006.htm Link spre comentariu
zal Postat Ianuarie 3, 2010 Partajează Postat Ianuarie 3, 2010 S?-i fac o bucurie lui Victor, am g?sit o schem? în clas? A, o singur? lamp?: Link spre comentariu
zal Postat Ianuarie 4, 2010 Partajează Postat Ianuarie 4, 2010 Trafo pp, realizarea practic?: Link spre comentariu
