convertire asm in hex
ady_marinescu
  • Răspunsuri 16
  • ady_marinescu
    6
  • Stefan
  • francezu
  • Liviu M
prima data am facut : INCLUDE "p16C5X.inc" in loc de : INCLUDE "c:\pictools\picstarc\p16C5X.inc"dar apoi am vazut mesaje de eroare asta fiind prima buba:ADDWF PC ; Jump to one of 4 look-up entriescare da : Error[113] C:\CEAS\CLK8.ASM 98 : Symbol not previously defined (PC) eu am pus :PC EQU 5 si am reusit sa compilez. Dar daca nu stiu cit sa-l fac pe PC nu va merge programul
ady_marinescu vezi daca iti merge hexul asta.
eu am pus PCL,F
si log-ul cu toate mesajele si atentionarile ( copy paste in notepad)
Warning[205] C:\DOCUMENTS AND SETTINGS\STEFAN\MY DOCUMENTS\CEAS_16C54\SOFT_ASM\CLK8.ASM 22 : Found directive in column 1. (LIST)
Warning[205] C:\DOCUMENTS AND SETTINGS\STEFAN\MY DOCUMENTS\CEAS_16C54\SOFT_ASM\CLK8.ASM 23 : Found directive in column 1. (INCLUDE)
Message[305] C:\DOCUMENTS AND SETTINGS\STEFAN\MY DOCUMENTS\CEAS_16C54\SOFT_ASM\CLK8.ASM 113 : Using default destination of 1 (file).
Message[305] C:\DOCUMENTS AND SETTINGS\STEFAN\MY DOCUMENTS\CEAS_16C54\SOFT_ASM\CLK8.ASM 135 : Using default destination of 1 (file).
Message[305] C:\DOCUMENTS AND SETTINGS\STEFAN\MY DOCUMENTS\CEAS_16C54\SOFT_ASM\CLK8.ASM 136 : Using default destination of 1 (file).
Message[305] C:\DOCUMENTS AND SETTINGS\STEFAN\MY DOCUMENTS\CEAS_16C54\SOFT_ASM\CLK8.ASM 152 : Using default destination of 1 (file).
Message[305] C:\DOCUMENTS AND SETTINGS\STEFAN\MY DOCUMENTS\CEAS_16C54\SOFT_ASM\CLK8.ASM 157 : Using default destination of 1 (file).
Message[305] C:\DOCUMENTS AND SETTINGS\STEFAN\MY DOCUMENTS\CEAS_16C54\SOFT_ASM\CLK8.ASM 162 : Using default destination of 1 (file).
Message[305] C:\DOCUMENTS AND SETTINGS\STEFAN\MY DOCUMENTS\CEAS_16C54\SOFT_ASM\CLK8.ASM 303 : Using default destination of 1 (file).
Message[305] C:\DOCUMENTS AND SETTINGS\STEFAN\MY DOCUMENTS\CEAS_16C54\SOFT_ASM\CLK8.ASM 309 : Using default destination of 1 (file).
Message[305] C:\DOCUMENTS AND SETTINGS\STEFAN\MY DOCUMENTS\CEAS_16C54\SOFT_ASM\CLK8.ASM 310 : Using default destination of 1 (file).
Message[305] C:\DOCUMENTS AND SETTINGS\STEFAN\MY DOCUMENTS\CEAS_16C54\SOFT_ASM\CLK8.ASM 314 : Using default destination of 1 (file).
Message[305] C:\DOCUMENTS AND SETTINGS\STEFAN\MY DOCUMENTS\CEAS_16C54\SOFT_ASM\CLK8.ASM 322 : Using default destination of 1 (file).
Message[305] C:\DOCUMENTS AND SETTINGS\STEFAN\MY DOCUMENTS\CEAS_16C54\SOFT_ASM\CLK8.ASM 323 : Using default destination of 1 (file).
Message[305] C:\DOCUMENTS AND SETTINGS\STEFAN\MY DOCUMENTS\CEAS_16C54\SOFT_ASM\CLK8.ASM 331 : Using default destination of 1 (file).
Message[305] C:\DOCUMENTS AND SETTINGS\STEFAN\MY DOCUMENTS\CEAS_16C54\SOFT_ASM\CLK8.ASM 332 : Using default destination of 1 (file).
Message[305] C:\DOCUMENTS AND SETTINGS\STEFAN\MY DOCUMENTS\CEAS_16C54\SOFT_ASM\CLK8.ASM 336 : Using default destination of 1 (file).
Message[305] C:\DOCUMENTS AND SETTINGS\STEFAN\MY DOCUMENTS\CEAS_16C54\SOFT_ASM\CLK8.ASM 337 : Using default destination of 1 (file).
Message[305] C:\DOCUMENTS AND SETTINGS\STEFAN\MY DOCUMENTS\CEAS_16C54\SOFT_ASM\CLK8.ASM 338 : Using default destination of 1 (file).
Message[305] C:\DOCUMENTS AND SETTINGS\STEFAN\MY DOCUMENTS\CEAS_16C54\SOFT_ASM\CLK8.ASM 346 : Using default destination of 1 (file).
Message[305] C:\DOCUMENTS AND SETTINGS\STEFAN\MY DOCUMENTS\CEAS_16C54\SOFT_ASM\CLK8.ASM 347 : Using default destination of 1 (file).
Message[305] C:\DOCUMENTS AND SETTINGS\STEFAN\MY DOCUMENTS\CEAS_16C54\SOFT_ASM\CLK8.ASM 350 : Using default destination of 1 (file).
Message[305] C:\DOCUMENTS AND SETTINGS\STEFAN\MY DOCUMENTS\CEAS_16C54\SOFT_ASM\CLK8.ASM 362 : Using default destination of 1 (file).
Message[305] C:\DOCUMENTS AND SETTINGS\STEFAN\MY DOCUMENTS\CEAS_16C54\SOFT_ASM\CLK8.ASM 380 : Using default destination of 1 (file).
Message[305] C:\DOCUMENTS AND SETTINGS\STEFAN\MY DOCUMENTS\CEAS_16C54\SOFT_ASM\CLK8.ASM 403 : Using default destination of 1 (file).
Message[305] C:\DOCUMENTS AND SETTINGS\STEFAN\MY DOCUMENTS\CEAS_16C54\SOFT_ASM\CLK8.ASM 411 : Using default destination of 1 (file).
Message[305] C:\DOCUMENTS AND SETTINGS\STEFAN\MY DOCUMENTS\CEAS_16C54\SOFT_ASM\CLK8.ASM 415 : Using default destination of 1 (file).
Message[305] C:\DOCUMENTS AND SETTINGS\STEFAN\MY DOCUMENTS\CEAS_16C54\SOFT_ASM\CLK8.ASM 416 : Using default destination of 1 (file).
Message[305] C:\DOCUMENTS AND SETTINGS\STEFAN\MY DOCUMENTS\CEAS_16C54\SOFT_ASM\CLK8.ASM 425 : Using default destination of 1 (file).
Message[305] C:\DOCUMENTS AND SETTINGS\STEFAN\MY DOCUMENTS\CEAS_16C54\SOFT_ASM\CLK8.ASM 429 : Using default destination of 1 (file).
Message[305] C:\DOCUMENTS AND SETTINGS\STEFAN\MY DOCUMENTS\CEAS_16C54\SOFT_ASM\CLK8.ASM 436 : Using default destination of 1 (file).
Message[305] C:\DOCUMENTS AND SETTINGS\STEFAN\MY DOCUMENTS\CEAS_16C54\SOFT_ASM\CLK8.ASM 442 : Using default destination of 1 (file).
Message[305] C:\DOCUMENTS AND SETTINGS\STEFAN\MY DOCUMENTS\CEAS_16C54\SOFT_ASM\CLK8.ASM 450 : Using default destination of 1 (file).
Message[305] C:\DOCUMENTS AND SETTINGS\STEFAN\MY DOCUMENTS\CEAS_16C54\SOFT_ASM\CLK8.ASM 515 : Using default destination of 1 (file).
Message[305] C:\DOCUMENTS AND SETTINGS\STEFAN\MY DOCUMENTS\CEAS_16C54\SOFT_ASM\CLK8.ASM 529 : Using default destination of 1 (file).
Message[305] C:\DOCUMENTS AND SETTINGS\STEFAN\MY DOCUMENTS\CEAS_16C54\SOFT_ASM\CLK8.ASM 552 : Using default destination of 1 (file).
Message[305] C:\DOCUMENTS AND SETTINGS\STEFAN\MY DOCUMENTS\CEAS_16C54\SOFT_ASM\CLK8.ASM 582 : Using default destination of 1 (file).
Message[305] C:\DOCUMENTS AND SETTINGS\STEFAN\MY DOCUMENTS\CEAS_16C54\SOFT_ASM\CLK8.ASM 623 : Using default destination of 1 (file).
Message[305] C:\DOCUMENTS AND SETTINGS\STEFAN\MY DOCUMENTS\CEAS_16C54\SOFT_ASM\CLK8.ASM 626 : Using default destination of 1 (file).
Message[305] C:\DOCUMENTS AND SETTINGS\STEFAN\MY DOCUMENTS\CEAS_16C54\SOFT_ASM\CLK8.ASM 660 : Using default destination of 1 (file).
Message[305] C:\DOCUMENTS AND SETTINGS\STEFAN\MY DOCUMENTS\CEAS_16C54\SOFT_ASM\CLK8.ASM 670 : Using default destination of 1 (file).
Message[305] C:\DOCUMENTS AND SETTINGS\STEFAN\MY DOCUMENTS\CEAS_16C54\SOFT_ASM\CLK8.ASM 676 : Using default destination of 1 (file).
Message[305] C:\DOCUMENTS AND SETTINGS\STEFAN\MY DOCUMENTS\CEAS_16C54\SOFT_ASM\CLK8.ASM 677 : Using default destination of 1 (file).
Message[305] C:\DOCUMENTS AND SETTINGS\STEFAN\MY DOCUMENTS\CEAS_16C54\SOFT_ASM\CLK8.ASM 684 : Using default destination of 1 (file).
Message[305] C:\DOCUMENTS AND SETTINGS\STEFAN\MY DOCUMENTS\CEAS_16C54\SOFT_ASM\CLK8.ASM 708 : Using default destination of 1 (file).
Message[305] C:\DOCUMENTS AND SETTINGS\STEFAN\MY DOCUMENTS\CEAS_16C54\SOFT_ASM\CLK8.ASM 715 : Using default destination of 1 (file).
am schimbat PC cu PCL si n-a mai dat erori. da' cu ocazia asta am vazut ca in proteus nu exista simulare si pt PIC16C54. deci nu-i pot incarca hex-ul, ca n-am unde.ce alte programe mai stiu de PIC-uri cu tot cu programele pt ele?
  • 3 luni mai târziu...
