recuperare poze card
Vizitator farys
  • Răspunsuri 1
  • gabitzu8
poti sa incerci cu Restoration 3.2.13:
Restoration is a free toll which can restore files which are deleted from the recycle bin or deleted while holding down the Shift key by mistake.
Conversely, Restoration, has another function that makes it almost impossible to restore all deleted files.
You can use it after deletion of confidential documents, embarrassing files and so on.
You don't have to install it, so it doesn't leave any garbage in the PC.
(You can also run it from a floppy disk.)
Even if a file seems to be restored, there is no guarantee that the contents are correct.
http://www.softpedia.com/get/System/Bac ... tion.shtml
daca nu merge, uite aici solutia: :sparge:
de fapt ce a patit cardul si ce tip e?
