hi fi audio pt acasa
Vizitator mrc
va multumesc pentru pareri,am inteles ca un sistem 2.0 sau2.1ar avea mai multa forta si profunzime.ce spuneti de ampliful :BEHRINGER_EP1500 si boxele magnat suprem 1000 sau boxele BEHRINGER EUROLIVE S1530alta nedumerire ar fi care tip de amplificator audio suna mai bine cu finali bipolari sau mos?
Coji.Hotaraste-te ce urmaresti: muzica in casa sau galagizare.Cu 20milioane nu poti cumpara ceva care sa fie bun la ambele.
  • Răspunsuri 33
  • BF37
    7
  • hugo
  • zal
  • Purple
doresc muzica in casa de 2500 lei maximcare din amplificatoare sa aleg ONKYO A-9155 sau NAD C315BEEboxe Magnat Monitor Supreme 1000 sau Pioneer CS-5070sau BEHRINGER TRUTH B3031A +BEHRINGER VMX10va multumesc
asta:
Sherwood AX-5103
Putere RMS 100 Watts x 2 @ 8Ohm
Raspuns in frecventa 10Hz - 60.000Hz (-2dB)
THD 0,03% (1kHz)
Alte caracteristici Tone Control
Balance Control
Tone Defeat & Loudness
Speaker A/B Selector with LED Indicator
Headphone Output Jack
Motorized Volume Control
Full Remote Control with Unified Remote Commander
Digi-Link III Remote Control for Other Sherwood Components
Culoare Negru
Dimensiuni (IxLxA) 440 x 145 x 360mm
Greutate 9 Kg
Garantie 2 ani
si asta:
Boxe Magnat Monitor Supreme 1000
Descriere 3 way bass reflex
Putere RMS 180 W
Putere dinamica 360 W
Raspuns in frecventa 19-38.000 Hz
Difuzoare 2x 6.5" woofer
1x 6.5" midrange
1" dome-tweeter
Impedanta nominala (EN 600065) 4-8 Ohms
Dimensiuni (IxLxA) 950 x 210 x 320 mm
Alte caracteristici Low resonant, stable MDF cabinet
High-quality wood decors, highlighted with a black baffle
Removable cloth grille
Tweeter with 25 mm silk dome and ERA front plate for a balanced reproduction and constant radiation
Woofer and woofer-midrange with low-distortion, coated cellulose cones
High quality crossover with phase correction
Gold-plated screw terminal
Metal- and rubber spikes included
Culoare Negru, Cires, Nuc
Garantie 2 ani
total cu cabluri 2400 RON
eu mai mult nu scriu...
Daca nu mai vrei sa investesti prea mult in boxe si totusi vrei un sunet cat de cat complet ,i-ti recomand Pioneer CS-5070 . Sant convins ca si magnat-urile suna bine dar pioneer-urile au bass de 20cm , sant pe 3 cai => un bass mai scurt dar care coboara mai jos + medii mai bine definite. Eu detin o pereche de jamo S406 , care se aud binisor , in special pe house sau hip-hop , dar pt ca au ceva delay pe bass , tobele sau exploziile se cam aglomereaza , deaceea i-ti recomand pioneer-urile.
Pioneer-urile se aud foarte placut la un volum mai mare, in surdina suna foarte sec si metalic...hm, o fi de la medii. Daca-ti place sunetul mai "cald"(lent) nu sunt o buna alegere, boxele de tip "turn" fiind mult mai potrivite pentru un volum mai mic. Plus ca trebuie sa ai grija ce e prin calea lor... sa nu te intrebi unde au disparut joasele.
Dup? schem?, piese folosite ?i realizare, categoric NAD-ul, de?i e mai urît. E ?i mai for?os, mai greu, oricum nu crede ce se scrie acolo ptr sarcin? de 2 Ohmi, el rezist? pîn? la 4 Ohmi. Pioneerul e firav.
