probleme PIC16F877A-04/P
cosmin_ctin2005
Salutare,am cumparat un PIC16F877A-04/P si am incarcat un program pe care l-am simulat in proteus - montajul nu functioneaza (la simulare mergea)Am si eu nevoie de un program foarte simplu in ASM : cand apas un buton sa se aprinda un led.Multumesc mult
  • Răspunsuri 13
  • cosmin_ctin2005
    8
  • TECH_FUN
  • mdorian
  • Rabulea Sergiu
Unde gresesc?
list p=16f876 ; list directive to define processor
#include ; processor specific variable definitions
__CONFIG _CP_OFF &_WDT_OFF &_PWRTE_ON &_XT_OSC
cblock 0x0C
val1
endc
org 0x0000
goto start
start
bcf STATUS,6
bsf STATUS,5 ;BANK1
movlw 0xff
movwf TRISA
movlw 0x00
movwf TRISB
movlw 0x00
movwf TRISC
movlw 0x00
movwf TRISD
movlw 0xFF
movwf TRISE
bcf STATUS,5 ;BANK0
call start1
start1
clrf PORTA
clrf PORTB
clrf PORTC
clrf PORTD
clrf PORTE
movlw 0x00
movwf val1
call coco
return
coco
btfsc PORTA,0
call coco2
call coco
coco2
incf val1
bsf PORTC,4
call coco
end
ce vreau sa fac:
daca aplic 0V la intrarea PORTA,0 (normal intrarea este legata la 5V) sa se faca iesirea PORTC,4
eu am folosit la PIC16F84 un macro button.inc dar la PIC16F877 nu functioneaza.
loop
Button 0,PORTA,2, .100, por_opr
call loop
por_opr
bsf PORTB,2
call loop
Button macro HiLo, Port, Bit, Delay, Adrress
Local Exit
Local Loop
if HiLo == 0
btfsc Port,Bit
else
btfss Port,Bit
endif
goto Exit
Loop
if HiLo == 0
btfss Port,Bit
else
btfsc Port,Bit
endif
goto Loop
call Adrress
Exit
endm
Unde gresesc?
Incearca asta:
list p=16f877A ; list directive to define processor
cblock 0x20
val1
val2
endc
org 0x0000
goto start
start
; niste initializari
clrf INTCON
banksel CMCON
movlw 0xff
movwf CMCON
banksel PIR1
clrf PIR1
clrf PIR2
;se trec toate perifericele pe power down
clrf T1CON
clrf T2CON
clrf SSPCON
clrf CCP1CON
clrf CCP2CON
clrf ADCON0
banksel PIE1
clrf PIE1
clrf PIE2
movlw 0x07
movwf ADCON1
clrf SSPCON2
banksel TRISA
movlw 0xff
movwf TRISA
movlw 0x00
movwf TRISB
movlw 0x00
movwf TRISC
movlw 0x00
movwf TRISD
movlw 0xFF
movwf TRISE
banksel PORTA
clrf PORTA
clrf PORTB
clrf PORTC
clrf PORTD
clrf PORTE
movlw 0x00
movwf val1
RepetaMereu
; asteapta 0 pe pin PORTA,0
btfsc PORTA,0
goto $-1
; o mica intarziere pentru a elimina impulsurile tranzitorii
clrf val2
incfsz val2,f
goto $-1
comf val1,f; val1 e folosit ca buffer
;pentru a memora starea anterioara , la fiecare apasare
;se schimba starea pinului portc,4
call CopiazaBit
; asteapta 1 pe PORTA,0
btfss PORTA,0
goto $-1
clrf val2
incfsz val2,f
goto $-1
goto RepetaMereu
CopiazaBit
; copiaza val1,0 in PORTC,4
banksel val1; in acelasi banc cu PORTC
btfss val1,0
goto ClearBit
bsf PORTC,4
return
ClearBit
bcf PORTC,4
return
end
Pinul 0 de la portul A nu este intrare digitala implicit , trebuie initializat , probabil acolo e greseala de nu iti merge macroul
Oricum , modul in care folosesti apelurile de subrutine e revoltator , nu reusesc sa inteleg cum un lucru atat de simplu il faci atat de complicat :banghead:
am facut urmatorul program si l-am simulat in PROTEUS si merge foarte bine dar practic nu merge.
list p=16f877 ; list directive to define processor
__CONFIG _CP_OFF &_WDT_OFF &_PWRTE_ON &_XT_OSC &_BODEN_ON &_LVP_ON
;***** Declarare variabile *****
Cblock 0x0C
LCDbuf
LCDtemp
WCYCLE
PRESCwait
doi
te_st
endc
;***** structura prog din memorie *****
ORG 0x0000 ;reset vector
goto Main
#include "bank.inc"
#include "button.inc"
#include "wait.inc"
Main
bcf STATUS,RP0
bcf STATUS,RP1
clrf PORTA
bsf STATUS,RP0
movlw 0x06
movwf ADCON1
movlw 0xCF
movwf TRISA
clrf PORTB
movlw 0x00
movwf TRISB
clrf PORTC
movlw 0x00
movwf TRISC
clrf PORTD
movlw 0x00
movwf TRISD
clrf PORTE
movlw 0x00
movwf TRISE
bcf STATUS,RP0
bcf STATUS,RP1
clrf PORTB
movlw 0x00
movwf te_st
clrf PORTD
Loop
Button 0,PORTE,0, .100, On
goto Loop
On
bsf PORTB,7
bsf PORTB,6
bsf PORTC,3
bsf PORTC,4
bsf PORTD,0
bsf PORTD,1
bsf PORTD,3
bsf PORTD,4
return
End
este prima data cand programez acest tip de PIC si nu stiu ce trebuie bifat in ICPROG
Fusses
WDT
PWRT
BODEN
LVP
CPD
WRT
DEBUGGER
help me!!!!!
:nas:
n-am mai programat de mult in asm, dar mai observ o problema. daca te uiti pe configuratia bank-ului0, blocul de 'general purpose registers' incepe de la 0x20h... daca scrii peste registrii dedicati, nu garanteaza nimeni ca o sa ramana acolo intacta informatia... cel putin adcon vad sigur ca-l scrii chiar tu in program.
Salut.
Dupa parerea mea gresesti aici:
Cblock 0x0CLCDbufLCDtempWCYCLEPRESCwaitdoite_stendc
Memoria RAM (general pourpose register) incepe de la 0x20 la PIC 16F877, nu de la 0x0C ca la PIC16F84
deci codul tau ar trebui sa arate cam asa:
Cblock 0x20LCDbufLCDtempWCYCLEPRESCwaitdoite_stendc
Un sfat:
Filtreaza ce citesti din cartea de pe mikroelectronica, pentru ca acea carte are exemple pentru PIC 16F84 care nu este compatibil cu microcontrolerul tau.
Cu respect, Sergiu.
