rog explicatii BASCOM
vasile eugen
doresc, daca este cineva amabil sa-mi eexplice in BASCOM liniile:
1wwrite &HCC
1wwrite &H44
1wwrite &HBE
&HCC,&H44 si &HBE sunt niste adrese din dataschetul integratului DS18B20?
un catalog cu coduri bin si hex am gasit http://www.ascii.cl/conversion.htm , dar aceste coduri nu am gasit.
Vreau sa stiu daca se se scoate din dataschet si atunci cum?
atasez prgramul de unde am scos aceste linii
  • Răspunsuri 8
  • vasile eugen
    5
  • danzup
1wwrite &HCC
1wwrite &H44
1wwrite &HBE
Uite ce scrie in datasheet -ul lui DS18B20
1-Wire Bus Activity
Command Description Protocol After Command is Issued Notes
TEMPERATURE CONVERSION COMMANDS
Convert T Initiates temperature 44h DS18B20 transmits conversion 1
conversion. status to master (not applicable
for parasite-powered
DS18B20s).
MEMORY COMMANDS
Read Scratchpad Reads the entire scratchpad BEh DS18B20 transmits up to 9 data 2
including the CRC byte. bytes to master.
4Eh Master transmits 3 data bytes to 3
Write Scratchpad Writes data into scratchpad
bytes 2, 3, and 4 (TH, TL, DS18B20.
and configuration registers).
Copy Scratchpad Copies TH, TL, and 48h None 1
configuration register data
from the scratchpad to
EEPROM.
Recalls TH, TL, and B8h DS18B20 transmits recall status
Recall E
configuration register data to master.
from EEPROM to the
scratchpad.
Read Power Signals DS18B20 power B4h DS18B20 transmits supply status
Supply supply mode to the master. to master.
To get this information, the master can issue a Skip ROM
[CCh] command followed by a Read Power Supply [b4h] command followed by a ?read time slot?.
During the read time slot, parasite powered DS18B20s will pull the bus low, and externally powered
DS18B20s will let the bus remain high. If the bus is pulled low, the master knows that it must supply the
strong pullup on the 1-Wire bus during temperature conversions.
va multumesc frumos :danzup"eu eram derutat si nu intelegeam ca in dataschet era "h" dupa 44 sau BE si in program chiar invers h44 si hbesi daca tot an deschis acest subiect va rog imi spuneti inca la o aplicatie care ati facut-o la TDA7318 si ATMEGA8515:I2csend &H88 , Vol_meI2csend &H88 , Att_rfI2csend &H88 , Att_lf&H88 cum sa-l iau din dataschet?
din ce mi-ati explicat la TDA7318 codul il iau din partea aceasta a dataschetului:
SOFTWARE SPECIFICATION
Interface Protocol
The interface protocol comprises:
A start condition (s)
A chip address byte, containing the TDA7318
address (the 8th bit of the byte must be 0). The
TDA7318 must always acknowledge at the end
of each transmitted byte.
A sequence of data (N-bytes + acknowledge)
A stop condition (P)
TDA7318 ADDRESS
MSB first byte LSB MSB LSB MSB LSB
S 1 0 0 0 1 0 0 0 ACK DATA ACK DATA ACK Pde aici se da hexul atunci
Data Transferred (N-bytes + Acknowledge)
ACK = Acknowledge
S = Start
P = Stop
MAX CLOCK SPEED 100kbits/s
Chip address
MSB
poate , par cam dificil cu atitea intrebari , dar din exemple invat cel mai usor si asa am invatat pina acum
Tot odata va multumesc mult "DANZUP"
Interface Protocol
TDA7318 ADDRESS
ACK = Acknowledge
S = Start
P = Stop
Chip address
MSB
Da .
Iar informatiile despre i2c bus se dau foarte bine in helpul lui Bascom .
da am inteles acum,am sa ma pun sa studiez mai concret dataschetul cu integratul cu care vrau sa fac aplicatiava multumesc pentru toata rabdarea pe care o averiti in a da explicatii
  • 2 săptămâni mai târziu...
vin din nou cu o alta intebare ,doresc sa incerc sa sa fac o comunicatie i2c cu un Atmega 8 si TDA8421 .La acest TDA8421 am doua sectiuni pentru iesire ,una cu corectie de ton si cealalta fara corectie de ton .Pentru incepuc sa initiez poartea fara corectie de ton este posibil sa fac? Nu are influenta ca nu am comenzi pentru sectiunea cu corectii?Sau in partea cu corectii , pot folosi doar sectiunea volum,intrare si iesire fara corectii?Va multumesc.
