Probleme ATMEGA16
Vizitator prigbel
Vizitator prigbel
Salut,Am 2 uC-uri ATMEGA16 si desi sunt aproape noi (am facut cu ele doar cateva teste gen apasat buton si aprins led) am cativa pini care raman pe 1 logic. Asta chiar daca ii spun in program sa ii puna pe 0 sau chiar daca nu are nimic in el (softul sters).De exemplu pinii PORTC5 si 6 sunt pe 1 logic iar restul sunt 0. De mentionat ca nu sunt aceeasi pini cu probleme la ambele uC. Ati mai intalnit asa ceva? Stima.
  • Răspunsuri 2
  • danzup
Salut,
Stima.
Ai citit documentatia , adica pdf-ul lui atmega 16 ?
The alternate pin configuration is as follows:
? TOSC2 ? Port C, Bit 7
TOSC2, Timer Oscillator pin 2: When the AS2 bit in ASSR is set (one) to enable asynchronous
clocking of Timer/Counter2, pin PC7 is disconnected from the port, and becomes the inverting
output of the Oscillator amplifier. In this mode, a Crystal Oscillator is connected to this pin, and
the pin can not be used as an I/O pin.
? TOSC1 ? Port C, Bit 6
TOSC1, Timer Oscillator pin 1: When the AS2 bit in ASSR is set (one) to enable asynchronous
clocking of Timer/Counter2, pin PC6 is disconnected from the port, and becomes the input of the
inverting Oscillator amplifier. In this mode, a Crystal Oscillator is connected to this pin, and the
? TDI ? Port C, Bit 5
TDI, JTAG Test Data In: Serial input data to be shifted in to the Instruction Register or Data Register
(scan chains). When the JTAG interface is enabled, this pin can not be used as an I/O pin.
? TDO ? Port C, Bit 4
TDO, JTAG Test Data Out: Serial output data from Instruction Register or Data Register. When
The TD0 pin is tri-stated unless TAP states that shifts out data are entered.
? TMS ? Port C, Bit 3
TMS, JTAG Test Mode Select: This pin is used for navigating through the TAP-controller state
machine. When the JTAG interface is enabled, this pin can not be used as an I/O pin.
? TCK ? Port C, Bit 2
TCK, JTAG Test Clock: JTAG operation is synchronous to TCK. When the JTAG interface is
Deci cum sunt setati fusebitii ???
