Confuzie mare
Vizitator mifantrax
Vizitator mifantrax
Am un amplificator Crown XLS 202Stereo, 4 ohms (per ch.) 300WStereo, 8 ohms (per ch.) 200WBridge-Mono, 8 ohms 600WSi 2 boxeFBT Jolly 8B2-way passive bass-reflex speaker system with 200 mm woofer and 25 mm high frequency unit? Extremely light and sturdy enclosure made of gas injection moulded polypropylene? Integral handle, stand adapter, 2 M6 anchoring points and a comprehensive range of accessories for fixed installations? Custom 90° x 60° dispersion horn? Asymmetrical trapezoidal shape for use as a stage monitor? An ideal choice for live performance applications thanks to the reduced dimensions in relation to the hefty 119dB SPL, along with frequency response that excels in terms of linearity and extension.? Enormous application versatility: band P.A.s, piano-bars, home and live monitors, and fixed installations in live music club venues, pubs, gyms, and all other venues requiring high sound pressure combined with compact dimensions? Custom 200 mm high efficiency high excursion woofer? Custom 25 mm compression tweeter? Internal Crossover with very high quality components and designed for the utmost resistance to vibration? Drivers protected against overload and acoustic feedback? Flat frequency response over the entire dispersion angle? Recommended amplifier 160W/8 Ohm? SPL 114/117 dB? Inputs panel with 2 Neutrik? Speakon NL-4 connectors and links # SpecificationLe-am cumparat la sfatul unui specialista parca. Le-am ascultat si au sunat excelent.Totusi am intalnit un alt specialist si mi-a zis sa nu le pun la CRown ca le ard. :speriat DAca poate cineva sa-mi explice cum stau lucrurile?Si daca se pot arde, in ce conditii si cum se poate evita?Daca puteti cinevas sa-mi explicati .Multumesc mult. :jytuiyu
  • Răspunsuri 5
  • zal
  • djlove
Zile populare
In specificatiile boxelor scrie ca puterea recomandata este de 160W, iar amplificatorul tau poate debita 200W. Ceea ce este foarte bine, deoarece nu vei ataca boxele cu distorsiuni. Risti sa le arzi daca dai amplificatorul la maxim.Este foarte bine ca ai luat un amplificator mai puternic, nu mai lua in seama sfaturile tuturor celor care se cred mari 'specialisti'.
Cam aia e puterea real?, leg?tura cu tensiunea la re?ea e a?a, de ochii lumii, trafo de re?ea are prize ptr toate variantele, e adev?rat c? curentul în secundar ar fi pu?in mai mare la 60Hz (alternan?ele mai dese), dar tensiunea de alimentare, cea care d? puterea unui amplif e cam aceea?i.Trebuie s? în?elegi c? orice firm? în prospecte pune datele favorabile, nimeni nu-?i face antireclam?, cum vezi acolo, la 240V nu mai trece puterea pe canal minim garantat?, la 8 Ohmi.A, acu v?zui ?i boxele, la 8'' diful de bas e o juc?rie, a?a din ochi, mai mult de 100W s? nu bagi în ele, poate s? legi mai multe în serie-paralel...
