Vizitator seciudany Postat August 7, 2009 Partajează Postat August 7, 2009 Am 2 basi de la kon model LW-1503 si vreau sa fac 2 subwoofere pt sonorizari diverse(nunti,botezuri,majuri..s.a.m.d) ma poate ajuta cineva? Descriere suplimentara: Resonance Fs(Hz) 40, Sd 839 cm2, Xmax 3 mm, Volume Vas (litres) 190, Total Dynamic Mass Mmt (gm) 80, Total Q Qts 0.31, Mechanical Factor Qms 2.63, Electrical Factor Qes 0.35, Rms 7.96 kg/s, BL factor 19.2, Compliance Cms (mm/N) 0.19, Coil Inductance @ 1kHz Le (mH) 1.76, Baffle Cutout Diameter (mm) 355.multumesc Link spre comentariu
Dr4g0n Postat August 7, 2009 Partajează Postat August 7, 2009 Ai primit raspuns in topicul de la Zona Profesionala\Sonorizari Nu mai deschide acelasi topic in mai multe locuri Link spre comentariu
