Debouncing la butoane
habarnam
Avem aici o functie pentru rezolvare chestiune buton (butoane), inclusiv debounce si autorepeat. Se compileaza cu CCS.
//=====================================================================// The following macro is used by the Button function.#define read_bit_var(x)  bit_test(*(U08 *)(x >> 3), x & 7)//=====================================================================U01 U01_button(      U16 pin,       U08 downstate,       U08 IDBR,      U08 rate,       U08 &Bvar,       U01 action    ){ U08 pin_value; // Read the button pin pin_value = read_bit_var(pin); if( pin_value!=downstate ) {   Bvar = 0;   return( !action );    } if( Bvar==0 ) {   if( IDBR==0 ) Bvar = 255;   else          Bvar = IDBR;   return action; } Bvar--;        if( Bvar==0 ) {   Bvar = rate;   if(  (IDBR!=0) && (IDBR!=255)  )     return( action ); } return( !action ); }
  • Răspunsuri 15
  • MirceaM
    5
  • one
  • habarnam
  • sborkuti
