mufa incarcator motorola
elmar
Salut!am un telefon motorola v620 si nu mai am incarcatorul cu tot cu mufa .si as ruga sa ma ajute cineva sa-l pot incarca, adica sa-mi spuna si mie ce contacte sunt la aceasta mufa .mai exact vreau sa stiu unde vine + si - . am facut si o schita cum vine contactele la aceast telefon.[attachment=0]mufa motorola v 620.JPG[/attachment]
  • Răspunsuri 2
  • elmar
  • cniky
Posted Image
also for ROKR E1, E398,E550,E815,E1000, T280,T720,T730,T722i,T721, 270c, C331t, C343, C353t, C975, C980, 120x, A920, A295, Nextel i205, i305, i530, i730, i830, i930 models. This interface also known as Motorola CE bus.
Mobile phone interface pin Description
1 GND
2 R=25 or 33 KOhm to GND in data or charge cable
3 +6v charge voltage
4 Tx
5 Rx
6 RTS
7 Vbus (connect to pin 3 if not used as IC power)
8 CTS
9 DCD
10 RE
11 DTR
12 DSR
13 Serial Enable (if this pin is not pulled to ground your serial cable will not work)
Pins 6,8; pins 13 and 1 should be shorted in cable.
USB pinout (used at least in Motorola Nextel i205, i305, i530, i730, i830, i930).
1 GND
4 Rx (may be connected to PC USB port, USB D+)
5 Tx (may be connected to PC USB port, USB D-)
6 VBus May be pin 7???
For v600 whith charge, pin 3 and 6 be shorted. USB D+ connect to pin4, USB D- connect to pin5. R=25 KOhm connect to pin1 and pin2. Do not pin 3 and 6 shorted in phone, must be in cable!
MULTUMESC. :aplauze Incercasem si eu conectind un fir la contactul 1(-)si altul la 3(+)dar nu stiam si de rezistenta de 33kohmi dintre masa si contactul 2,si din cauza asta(cred) nu se incarca bateria, numai se pornea tel. si mergea atit timp cit era alimentat.As mai intreba ceva daca nu cumva sint in afara topicului.Cum pot descarca poze sau video de pe tel pe calculator prin bluetooth(daca se poate asa ceva pe acest tel)pentru ca nu am cablu de date.Eu am icercat dar pot numai sa descarc fisiere de pe calculator pe tel. invers nu merge i-mi spune ca se conecteza cu telu si asa ramine .nu se conecteaza.Asa o fi acest tel. ?
