Vizitator sorinelll Postat Aprilie 1, 2009 Partajează Postat Aprilie 1, 2009 AJUTOR am si eu o intrebare daca e cineva binevoitor sa ma ajute pentru ca nu ma prea pricep.Am un carkit nokia cark-91 cu functia tel mute si un dvd auto care insa nu are la capat pin pentru tel mute.As vrea sa stiu daca se poate face ceva pentru a lega firul de tel mute de la carkit la dvd ca atunci cand suna telefonul sa se opreasca muzica.In cartea carkitului scrie asa: The car kit offers a feature that can mute the car radio automatically during a conversation. This feature is convenient and provides for safer handsfree operation. The car radio muting feature is based on a grounded line, so it means that in standby, the yellow wire (XCRM) is not grounded and car radio works normally, but during a call, line is grounded and car radio is muted. Note that an auxiliary relay or muting unit must be used when the car radio doesn?t have a mute feature available. When a relay is used, connect of series with the car radio main supply. A 200 mA fuse should be used to protect the XCRM output in event of a short circuit. Some radios have separate supplies for amplifiers and motors, and another for memory backup purposes. Very often these radios also have a secret code system, which activates itself if a break in the memory supply is detected. Be careful when installing the relay not to break the memory supply (usually marked ACC or +MEM), but to install... mai exista si o schema simpla cu un releu care are codul Bosch P/N 0?332?204?150 12 V, 30 A. SPDT dar nu stiu cum sa o anexez aici sau de unde sa il achizitionez Cum pot sa leg acest releu sau unul asemanator la firele dvdului. Majoritatea cd playerelor auto stiu ca au un astfel de pin/fir la care firul de carkit se leaga dar al meu (dvd ) nu are din pacate am vazut asta dupa ce l-am cumparat shov 2810dv. un reviw despre dvd facut de altcineva http://2urbietorbi.wordpress.com/2008/0 ... ov-2810dv/ Link spre comentariu
Felis Postat Aprilie 2, 2009 Partajează Postat Aprilie 2, 2009 salut Acel releu este un releu banal de masina cu 5 picioare (practic poti utiliza orice releu de masina) schema prezentata acolo este pentru intreruperea automata a alimentarii la orice radio-cas-mp3 montat pe masina(daca e din cele noi care necesita mai multe plusuri e bine sa intercalezi schema pe firul de +contact si atunci nici macar nu mai ai nevoie de un releu cu consum si putere de rupere asa de mare.)car kitul iti ofera de fapt la acel pin o tensiune suficienta sa comanzi un releu. uitate la dvd si vezi la mufa de alimentare ca trebuie sa ai macar 2 fire cu + pe ele 1 e +permanent si de fapt duce toata partea de forta a dvd a-l 2 este in mod normal +contact(dar se mai leaga si impreuna cu cel de forta totul la 1 plus de cei care nu vor sa puna mereu contactul treapta1 ca sa poata porni playerul)Acest al 2-lea trebuie intrerupt si trecut prin contactele releului (tot acel releu poate fi utilizat la comanda pentru ridicarea ridicarea automata a antenei .Releul are 2 contacte de lucru 1normal inchis si 2 normal deschis(pe traseul normal inchis va functiona DVDplayerul in cand suna si se activeaza carkitul contactul normal inchis se va deschide oprind DVDplayerul se va stabili contactul pe cel care a fost normal deschis si va putea alimenta un consumator (comanda antenei electrice)(dar atentie in caz ca ai antena electrica trebuie sa mai folosesti 2 diode pentu a separa comanda data de DVD fata de cea data de carkitt) Link spre comentariu
Dr.L Postat Aprilie 2, 2009 Partajează Postat Aprilie 2, 2009 sigur firul de permanent e de forta?la un player de acum cativa ani(>5),care avea cutia cu filtrul si sigurantele pe fir,pe firul de permanent siguranta era de 0,5A iar pe cel de contact era de 5A.acum am un player mai recent(07-08) care are siguranta integrata in aparat,pana la urma o sa masor sa vad cum sta treaba Link spre comentariu
Felis Postat Aprilie 2, 2009 Partajează Postat Aprilie 2, 2009 Dr.L e cazul la cele cu 3 + necesare sa functioneze.Pentru ca au nevoie neaparat de 1 plus permanent pentru mentinerea in memorie a datelor(posturi memorate) Practic respectivele playere au 2 + permanent si un plus contact(StBy)(curentul prin firul de Stand By fiind destul de mic)(Finalii actuali utilizati in playere au pin dedicat pentru StBy de aceea se utilizeaza alimentarea directa.La altii chiar se comanda totul prin linie de date pe 2 sau 3 fire in functie de protocolul utilizat de fabricant)PS da au mai fost si chinezarii care nu aveau finali cu functia de STBy inclusa la alea e normal sa fie firul de forta cel de +contact(Dar eu vorbeam de playerele care respecta normativele impuse de proiectantii de autovehicole) Link spre comentariu
Dr.L Postat Aprilie 2, 2009 Partajează Postat Aprilie 2, 2009 eu intrebam de playere aftemarket,nu de cele stock. astea au 2 fire,unul permanent si unul prin contact. nu cel prin contact este de forta? Link spre comentariu
Vizitator sorinelll Postat Aprilie 2, 2009 Partajează Postat Aprilie 2, 2009 MULTUMESC felis,asa este precum spui tu m-ai lamurit.Dvdul are intr-adevar 2 plusuri(unul pentru memorie galben si unul rosu )pe care le-am impreunat pentru ca nu imi place sa pun mereu contactul cand trebuie sa pornesc.Majoritatea cd playerelor au cate doua plusuri intr-adevar.Da asa e cum spui tu.Totusi nu inteleg de ce nu au prevazut dvdul cu fir la capat de mute.Cd playerul din masina fratelui meu are un astfel de pin si firul de mute l-am legat la el si atunci cand suna casul afiseaza phone si taie sonorul melodiei,dupa apel revine la melodie.Dvdul meu in schimb are pe butonul power functia de mute,astfel cand apas scurt pe el afiseaza mute si cand apas lung se opreste.Ar fi fost bine daca ar fii fost proiectat cu fir pt carkit. oricum multumesc mult de tot. Link spre comentariu
Felis Postat Aprilie 2, 2009 Partajează Postat Aprilie 2, 2009 Dr.L la ele vezi in schema de montaj care e obligatoriu in cutie acolo specifica clar care din fire e cel de forta si care e cel de memorie(nu pot sa generalizez din moment ce piata e plina de diferite marci de playere).Eu daca e nevoie sa leg un player , fie ca o fac pe un autoturism sau un camion identific clar functiile fiecarui fir.Mai ales la camioane unde mai trebuie sa mai si reconfigurezi instalatia si mufele daca vrei sa cuplezi un player.Doar instalatia e de 24 la ele (27,8 in mers )crezi ca acolo rezista un player facut pentru 12 volti daca nu reconfigurez si nu recurg la niste artificii ca sa beneficiez si de functiile speciale?)Mai ales ca la camioane mai trebuie si sa stabilesc daca sursa de 12(sursa in comutatie la camioanele moderne.Sursa liniara la cele mai vechi)Poate suporta curentul necesar pentru player pentru ca din acea sursa se mai alimenteaza si diferite calculatoare si module electronice ale autovehicolului.Si daca nu poate suporta atunci trebuie montata inca o sursa(mai ales cand montez statie CB atunci chiar trebuie)(sunt intradevar si camioane de clasa superioara care au prevazute special linii de alimentare pentru zona de confort si la acele nu trebuie sa-mi fac griji ca nu am de unde sa iau 12V cu puterea necesara.)De exemplu am avut la depanare un volvo FH12 clasa lux care avea prevazute Frigider,filtru automat de cafea,cuptor,plita cu inductie,Televizor, etc.(era echipat cu un invertor de putere cu mai multe etaje si debita tensiuni de 12Vcc,110 Ca sau220 Ca,era configurabil din comutator)sa nu va ganditi ca erau puse. Invertorul era conceput special pentru Volvo si era din configurarea speciala ceruta de beneficiar Link spre comentariu
