ghita_cosma Postat Ianuarie 31, 2009 Partajează Postat Ianuarie 31, 2009 as dori modul de intrare in service durabrand p14c procesor lc863532c 24 c08 jungla la76818a [ modificare norma sunet ]am incercat variantele din depanatorul nr.32 si nu am reusit multumesc Link spre comentariu
cristronic Postat Ianuarie 31, 2009 Partajează Postat Ianuarie 31, 2009 Pe procesor mai sunt unul sau doua grupuri de coduri,le puteti spune? Link spre comentariu
ROBEERT Postat Februarie 1, 2009 Partajează Postat Februarie 1, 2009 p14c, asta-i sasiul? Link spre comentariu
maresmircea57 Postat Februarie 1, 2009 Partajează Postat Februarie 1, 2009 Try:1. Power and switch on the Durabrand DVD player.2. Open the DVD disc tray tray or lid.3. Press Stop.4. Press 3 - 5 - 9 - 7 (3597 in sequence). Can be done on remote control.5. Hidden DVD Region menu appears. Select region 0 or 9 using up or down button on remote control.6. Press OK.7. Close the disc tray and press Standby on the DVD player frontIf that doesn't work try:1. Power on the DVD player.2. Open the DVD disc tray or lid.3. Press 8 - 1 - 3 - 2 - 8 (81328 in sequence) on remote control.4. In DVD region code menu, press Enter until come to region 9 (or 0)5. Press Play.6. Close the DVD tray or lid.If that doesn't work try:1. Press Open to open disc tray.2. Press Clear.3. Press 1 - 3 - 6 - 9 - 0 (13690 in sequence).4. Press Standby button. After pressing, the DVD disc tray will close and DVD player will switch off).5. Press Standby button again to power up the DVD player.If that doesn't work try:1. Turn on the DVD player.2. Press Open/Close button to open the disc tray.3. Press Setup.4. Press 8 - 8 - 8 - 8 (8888 continuously).5. Press Next.6. Go to ?Version and select a region code. Select 0 for all region or 9 for region free.7. Press Play.If that doesn't work try:1. Turn on the DVD player.2. Press Setup.3. Go to ?Preferences?.4. Press Play.5. Enter 2 - 5 - 1 - 5 - 3 - 5 (251535 in continuous sequence of keys).6. Press Left, Down.7. The current region code will be displayed.8. Press 0 for region free. Link spre comentariu
ghita_cosma Postat Februarie 2, 2009 Autor Partajează Postat Februarie 2, 2009 procesorul e lc 865335c 57z0 7yn05 Link spre comentariu
cristronic Postat Februarie 2, 2009 Partajează Postat Februarie 2, 2009 Pai in primul post,parca este vorba de alt procesor!? Link spre comentariu
cristronic Postat Februarie 3, 2009 Partajează Postat Februarie 3, 2009 Incearca cu una din variantele acestea:Menu-Menu-Menu-Pminus-2483Menu-Menu-Menu-2483Menu-2483 Link spre comentariu
ghita_cosma Postat Februarie 4, 2009 Autor Partajează Postat Februarie 4, 2009 A mers cu varianta lui cristronic .Multumesc mult. Link spre comentariu
trinetservice Postat Iulie 30, 2009 Partajează Postat Iulie 30, 2009 as dori modul de intrare in service durabrand p14c procesor lc863532c 24 c08 jungla la76818a [ modificare norma sunet ]am incercat variantele din depanatorul nr.32 si nu am reusit multumescVa salut!Revin si eu cu acest chinez si va intreb ce telecomanda merge la el?Nu am sunet bistandard.Multumesc. Link spre comentariu
ghita_cosma Postat Iulie 30, 2009 Autor Partajează Postat Iulie 30, 2009 as dori modul de intrare in service durabrand p14c procesor lc863532c 24 c08 jungla la76818a [ modificare norma sunet ]am incercat variantele din depanatorul nr.32 si nu am reusit multumescVa salut!Revin si eu cu acest chinez si va intreb ce telecomanda merge la el?Nu am sunet bistandard.Multumesc.Am avut telecomanda originala .Nu mai retin exact cum arata..... Link spre comentariu
trinetservice Postat Iulie 31, 2009 Partajează Postat Iulie 31, 2009 Am rezolvat cu o telecomanda programabila made4you cod 1967,intrarea in servic e cu memu,menu,menu,pr -,2483se intra in subpagini si la system bg si sistem d/k se pune 1 in loc de 0. Link spre comentariu
trinetservice Postat Iulie 31, 2009 Partajează Postat Iulie 31, 2009 Am rezolvat cu o telecomanda programabila made4you cod 1967,intrarea in servic e cu memu,menu,menu,pr -,2483se intra in subpagini si la system bg si sistem d/k se pune 1 in loc de 0.atasez si continutul memoriei, poate mai trebuie cuiva Link spre comentariu
