Amplificatoare Omnitronic, nu mă pot decide!
Am g?sit aceeste amplificatoare de la Omnitronic. Eu cum sunt în Italia Roma, îmi este mai greu s? cump?r din afar?, deci:
http://www.soundmix.it/omnitronic-amplificatore-p-500-p29800.html
-cost? 160euro cu tva
-Amplificatore professionale, 2 x 250 watt
* 2 x 250 W/4 ohms
* 2 x 130 W/8 ohms
* 8 Ohms bridged 1 x 500 W
* Enormous power with highest brilliance
* 2 gain-controls on the frontpanel
* All operation-modes controllable via LEDs
* LED-intensity adjustable via brightness control on the rear panel
* Signal-inputs via XLR-female or 1/4"-jack-socket
* Input sensitivity adjustable via selector on the rear panel
* Speaker connection via lockable Speaker-plugs or Banana/screw combination
* With limiter
* Ground Lift-switch against humming
* Bridged-switch for bridging
* Many protection-circuits for optimized equipment-protection
* Very rugged housing
* 19" dimensions
* High power/weight-relation .
http://www.soundmix.it/omnitronic-amplificatore-p-1000-p29801.html
-cost? 195euro cu tva
-Amplificatore professionale, 2 x 500 watt
* 2 x 500 W/4 ohms
* 2 x 245 W/8 ohms
* 8 Ohms bridged 1 x 850 W
* With limiter
* 19" dimensions
..?i ce de?in eu:
A? vrea s? ?tiu dac? pot s? îl folosesc pe al doilea, cel cu putere mai mare... dac? nu o s? r?mân la cel mic ? Wink
Dac? nu ce alt amplificator îmi recomanda?i de pe aceel site?
  • Răspunsuri 7
  • since
  • Lyvyutzu
  • Sharky
  • ari_panterra
poti sa-l folosesti si pe al doilea cu conditia sa nu ''scapi'' volumul peste limita boxelor dar recomandabil e primul,se incadreaza perfect in caracteristicile boxelor,insa daca modifici boxele dupa cum spuneai(introduci medii si faci ceva hi-fi),nu prea o sa''arate bine'' un amplif pro langa boxe hi-fi ''home''(difurile pro au alte caracteristici decat cele home)
Dac? a? vrea s? le modific, ar trebui s? m? uit dup? un amplificator Hi-Fi! :freaza:
