scheme de VU-METRE
csl1131
ca sa nu mai tot apara o groaza de subiecte in care se cere o schema de vu-metru mai jos sunt prezentate cateva:
http://www.pira.cz/enbar.htm
schema(prezenta si pe site) :
Posted Image
si cablajul:
(tot prezent pe situl de mai sus)
Posted Image
altul:
http://sound.westhost.com/project60.htm
schema:
Posted Image
altul :
http://www.4qdtec.com/avu.html
schema:
Posted Image
altul :
http://www.talkingelectronics.com/Proje ... reoVU.html
schema:
Posted Image
cablaj:
Posted Image
asa arat gata facut:
Posted Image
altul :
http://www.quasarelectronics.com/3089.htm
schema :
http://www.electronic-kits-and-projects ... 0/3089.pdf
poza:
Posted Image
altul :
http://users.otenet.gr/~athsam/vu_meter_3.htm
schema:
Posted Image
altul :
http://users.otenet.gr/~athsam/vu_meter_4.htm
schema:
Posted Image
altul :
http://users.otenet.gr/~athsam/vu_meter_5_UAA180.htm
schema :
Posted Image
altul:
http://users.otenet.gr/~athsam/mini_audio_analyzer.htm
schmea:
Posted Image
altul :
http://users.otenet.gr/~athsam/vu_meter_2.htm
schema:
Posted Image
altul :
http://users.otenet.gr/~athsam/vu_meter_1.htm
schema
Posted Image
alte scheme(se gasesc in datasheet-ul integratului respectiv):
-UAA180 : http://wwww.ges.cz/sheet/u/uaa180.pdf
comanda 12 LED-uri.. costa in jur de 50.000
-LM3915 : http://www1.jaycar.com.au/images_uploaded/LM3915.PDF
-LM3914 : http://www.electronics-tutorials.com/devices/lm3914.htm
acestea comanda 10 LED-uri
LM391x costa in jur de 100-110.000
-AN6884 : http://www.datasheetarchive.com/datashe ... 37755.html
(jos,scrie undeva download..ala e pdf-ul)
-BA6124 : http://radiocomplect.com/download/74.pdf
-LB1403 : http://www.datasheetarchive.com/datashe ... 45874.html
ultimele 3 sunt compatibile una cu alta(se pot inlocui fara probleme)
-LC7565 : http://www.datasheetarchive.com/datashe ... 49070.html
cele de mai sus erau cu leduri....
uite aici cu ac:
http://sound.westhost.com/project55.htm
schema:
Posted Image
altul :
http://www.opamplabs.com/vumtramp.htm
schema:
Posted Image
alta:
http://www.zen22142.zen.co.uk/Circuits/ ... lmeter.htm
schema:
Posted Image
cablaj :
(cablajun NU e pe situl ala)
Posted Image
dupa cum se vede si din ceea ce e mai sus, cele mai folosite la ora actuala sunt UAA180(12 led),LM3925(10 led), si AN6884(sau echivalentii: LB1403 si BA6124), astea au 5 leduri
deci ...spor la treaba!!!!
aaa.... si sa aveti rabdare sa cititii ce scrie prin link-urile de mai sus...!!!....
atat am zis eu, restul mai completati si voi....
  • Răspunsuri 610
  • adicontakt
    34
  • GeoMar
    24
  • albasete
    20
  • xcenik
    18
o intrebare...daca stie cineva...ce rezistenta e aia, si ce dioda zenner..???(ca celalalte sunt 4148)(poate imi dau seama maine,de fapt azi, ca acum e ora 3, si vad cam..dublu...) :shock:
Si aici una simpla :
http://www.zen22142.zen.co.uk/Circuits/ ... umeter.htm
Nu stiu sa pun poze.... :oops:
Posted Image
si parca nu e mai simpla decat altele..... la altele nu mai tre sa te complici cu acatea rezistente...-> cablaj mult mai mic...si mai simplu...
la pret..poate ai dreptate....un lm e vreo 7.000 si vreo rezistenta 500-> cam 22.000, iar la uaa e vroe 40....dar ala are 12 leduri.... si daca mai pui inca un lm, si 8 rez -> inca 11.000 in plus, resulta ca iesi cu 7.000 mai ieftin decat la uaa...
parerea mea ca nu se merita aia 7.000 pt cata munca faci tu ca sa faci cablajul, si sa lipesti toate piesele alea...etc...
(eu personal parca nu m-as apuca de asta..)
  • 2 săptămâni mai târziu...
Imi permit sa intregesc colectia de scheme si cu schema de aplicatie pentru circuitul integrat AN6884.
Posted Image
Iar aici, montajul realizat de mine:
http://tinypic.com/4lo904
LED-urile portocalii se aprind in ritmul semnalului PEAK. Am construit un filtru de frecvente medii care conduc LED-urile portocalii. In rest, VU-Metrul are schema de aplicatie clasica de mai sus.
Am realizat vu-metrul ala cu tranzistoare(trb. sa le folosesc undeva)schema pe fundal galben si ca sa functioneze trebuie inlocuita dioda1n4148 dintre baza si emitor la tr. pnp BC557 cu o rezitenta 5-10K.In rest functioneaza k.Si o mica modificare ce ar trb facuta este sa se puna direct pe alimentare un led care acesta sa fie "prima" treapta a scari de led-uri,altfel da senzatia uneori de bec semnalizator
Posted Image
Posted Image
  • 2 luni mai târziu...
  • 10 luni mai târziu...
Vizitator Andrei.Hrubaru
Intr-adevar sunt multe scheme de VU-metre pe net si asta nu e neaparat un lucru bun :finga: cand ai de unde alege atunci apar problemele si dilemele. Asa ca hai sa va nu va chinui cu un alt model de VU-metru , ci cu unul existent de mult pe net si care-mi place mie mult :d, cel cu LM3915 de la National Semiconductors.
  • 1 lună mai târziu...
salam si eu 6 vu-metre cu AN6884 si vreau sa le montez pe un sistem audio2 sa mearga pe ritmul basului 2 pe medii si sa mai pun 2 pe inalte, si sa mearga ca cel din winampameti vreo idee cu pot sa fac?
Ai nevoie de trei filtre pentru separarea domeniului de frecventa. Uite aici un link cu niste filtre de ordinul 2 http://ourworld.compuserve.com/homepage ... /opamp.htm . Pur si simplu iti alegi frecventele la care vrei sa faci separarea si apoi gasesti combinatii de valori pentru R si C sa obtii acea frecventa folosind formulele prezentate acolo (iei o valoare standard pentru condesatoare si calculezi valoarea pentru o rezistenta si apoi cauti o valoare standard si pentru ea)O zi buna! FiliponePS: Am mai gasit si articolul acesta destul de misto: http://www.elecdesign.com/Articles/Inde ... cleID=4022
