Vizitator MirceaMurar Postat Decembrie 10, 2008 Partajează Postat Decembrie 10, 2008 Salut! Am intampinat o problema la citirea din memoria DDRAM a LCD-ului, va rog daca se poate sa ma ajutati Lucru la un proiect in care folosesc un LCD 4x20 si un Atmega16. In mare problema este urmatoarea: am un sir de caractere pe prima linie a LCD-ului, acest sir eu trebuie sa-l scriu si pe linia 2. Am pus si codul scris, in cazul in care nu intelegeti undeva ce am vrut sa fac, va rog sa ma intrebati #define F_CPU 1000000UL#include <avr/io.h>#include <util/delay.h>#include <string.h>void PortsSet();void Write( char s[] );void GetChar();int first_line = 0x80; // adress of the first line of LCDint second_line = 0xC0; // second line adresschar ddram_info = 0x00; int main(){ PortsSet(); Write("ABCDEFG"); // vreau sa citesc primele 4 caractere while( first_line <= 0x83 ) { GetChar(); first_line++; // next column of first line } return 0;}void PortsSet(){ PORTC = 0x00; DDRC = 0xFF; // PORTC pins are connected to D0....D7 LCD Data pins PORTD = 0x00; DDRD |= ( ( 1 << PD0 ) | ( 1 << PD1 ) | ( 1 << PD2 )); // PD0 is connected to E pin , Enable // PD1 is connected to R/W pin, Read/Write // PD2 is connected to RS pin, Register Select // second LCD line set PORTD |= ( 1 << PD0 ); PORTC = 0x38; PORTD &= ~( 1 << PD0 ); _delay_ms( 10 ); // Cursor ON, Blinling ON PORTD = 0x01; PORTC = 0x0F; PORTD = 0x00; _delay_ms( 10 );}void Write( char s[] ){ short int i = 0; for ( i = 0; i < strlen( s) ; i++ ) { PORTD |= ( ( 1 << PD0 ) | ( 1 << PD2 ) ); PORTC = s[i]; PORTD &= ~( 1 << PD0 ); _delay_ms( 5 ); }}void GetChar(){ PORTD = 0x00; // setting the DDRAM adress at the beggining of the first LCD line, column 0; PORTD |= ( 1 << PD0 ); PORTC = first_line; PORTD &= ~( 1 << PD0 ); _delay_ms( 10 ); // I assumed that in order to receive information I have to set PORTC pins as input DDRC = 0x00; _delay_ms( 100 ); //reading the information from DDRAM PORTD |= ((1<<PD2)|(1<<PD1)|(1<<PD0)); ddram_info = PINC; _delay_ms( 100 ); PORTD &= ~(1<<PD0); _delay_ms( 1000 ); // setting the portC as output DDRC = 0xFF; _delay_ms( 1000 ); PORTD &= ~(1<<PD1); //writing the info readed from ddram from the specified adress, //writing into the second line PORTD = 0x00; PORTC = 0x00; _delay_ms( 1000 ); //moving the cursor at the beggining of the second line, column 0 PORTD |= ( 1 << PD0 ); PORTC = second_line++; PORTD &= ~( 1 << PD0 ); _delay_ms( 100 ); // writing the info PORTD |= (( 1 << PD0 ) | ( 1 << PD2 ) ); PORTC = ddram_info; PORTD &= ~( 1 << PD0 ); _delay_ms( 1000 );} Link spre comentariu
Laci Postat Decembrie 10, 2008 Partajează Postat Decembrie 10, 2008 Se pare ca ai probleme de timing:"//reading the information from DDRAM PORTD |= ((1< Link spre comentariu
Vizitator MirceaMurar Postat Decembrie 11, 2008 Partajează Postat Decembrie 11, 2008 Mersi mult!Am inlocuit asa cum mi-ai spus si a functionat.Am fost incercat si eu ceva asemanator dar tot fara rezultat.Multumesc inca odata! Link spre comentariu
