Probleme rescriere bios MB Via tip M7VIG Pro-D
SHADYYY
awdflash.exe e bun?ai incercat sa-l lasnsezi cu parametru /? sau /helpsa vezi daca e ok?pune in autoexec.bat doar astaawdflash.exe /?si porneste un alt calculator de pe acea discheta vezi daca porneste automat in awdflash daca da editezi iar in loc de /? pui numele fisierului si restul de parametrii.mai incearca sa setezi calea,tot in autoexec.bat pui inainte de awdflashpath=a:\sau incearca asaawdflash.exe a:\VIG1210.bin /py/sn/cp/cd/sb/r dar nu stiu daca o sa merga asa.
  • Răspunsuri 28
  • SHADYYY
    13
  • gabiz_ro
    7
  • junior
    5
  • MifTy
Am scris pe discheta cum mi ai spus si am bagat-o in flopy dupa care restart si mi a aparut ;
AWDFLASH v8.23H (01/17) ©Phoenix Technologies Ltd. 2003 All Rights Reserved
Usage: AWDFLASH [FileName1] [FileName2] [/[/...]]
FileName1 : New BIOS Name For Flash Programming
FileName2 : BIOS File For Backing-up the Original BIOS
?: Show Help Messages
py: Program Flash Memory pn: No Flash Programming
sy: Backup Original BIOS To Disk File sn: No Original BIOS Backup
Sb: Skip BootBlock programming Wb: Always Programming BootBlock
cd: Clear DMI Data After Programming cc: Clear CMOS Data After Programming
cp: Clear PnP(ESCD) Data After Programming
LD: Destroy CMOS Checksum And No System Halt For First Reboot
After Programming Tiny: Occupy lesser memory
QI: Qualify flash part number with source file
E: Return to DOS After Programming R: RESET System After Programming
F: Use Flash Routines in Original BIOS For Flash Programming
cks: Show update Binfile checksum cksXXXX: Compare Binfile CheckSum with XXXX
NVMAC:XXXXXXXXXXXX NVGUID:XXXXXXXXXXXXXX
Support nForce Input MAC,GUID Function,with "/wb" to update MAC and GUID.
Example: AWDFLASH 6A69R000.bin /py/sn/nvmac:xxxxxxxxxxxx/wbTe intreb daca este in regula ca eu nu am lucrat cu acest program.
Da e in regula
Incearca si cu alt awdflash
Nu cred sa fie asta dar versiunea ta e mai veche,uite una de la producatorul placii
ftp://ftp.biostar-usa.com/drivers/utility/AWDFL882.EXE
dar ii schimbi denumirea in awdflash.exe
Iti dau cateva variante de autoexec
prima
path=a:\
awdflash.exe VIG1210.BIN /py /sn /cp /cd /Sb /R
a doua
awdflash.exe VIG1210.BIN /py /sn /cp /cd /Wb /R
A doua iti va rescrie si bootblock din bios,e putin mai riscanta.
Pui discheta in el il lasi sa porneasca,astepti vreo 5-10 min si daca el nu se restarteaza il resetezi tu,eventula poti incerca si un clear cmos din jumper dupa ce il lasi alea 5-10 minute si apoi vezi ce face,daca tot nu vrea incerci si varianta a doua de autoexec
Gabi esti ff amabil dar am incercatsi varianta asta ,cred ca pina la urma trebuie rescris cu un programator extern .
Programatorul si adaptorul pentru circuitul de BIOS (A 290021TL-70) tip 32PLCC le am dar nu am softul , cred ca am sa deschid nu topic nou sa cer ajutor in aceasta directie.
Daca mai ai idei poti sa-mi scri ca le voi aborda cu placere, oricum multumesc inca odata pt sprijinul tau.
ce programator ai?Sunt curios dupa ce il faci daca pui discheta in el ce va face.Vad ca eu am pus spatii intre parametrii dar in exemplul dat de help e fara spatii.Incearca si asa.path=a:\awdflash.exe VIG1210.BIN /py/sn/cp/cd/Sb/Rsauawdflash.exe VIG1210.BIN /py/sn/cp/cd/Wb/R
Gabi am un programator serial de memori (circuite integrate )facut dupa o schema industriala cu care am reusit scrierea PIC-urilor si a altor memori precum si decodarea unor telefoane mobile .Introduc cipul de memorie in soclu iar un soft BIN-ul si apoi envoy.Este foarte curios ca am gasi mai multe bin-uri pentru aceasi placa , cu cel de la tine lucreaza cca 40 sec ,dar am gasit unul tot cu aceasi denumire de 256 kb cu care lucreaza 100 sec. inclin sa cred ca nu am binul care trebuie. Ar fi bine sa-mi spuna cineva care a mai facut aceasta operatie , cam cit trebuie sa lucreze flopy-ul pina termina de scris.
Si aici nu mai sunt idei , eu astept ceva piese sa demarez constructia programatorului paralel Willem dar sunt dispus sa mai incerc si ma refer in special la ce care poseda aceasi placa si bios si pot face o copie pe care sa mi-o trimita , ca binurile de pe internet nu sunt complete.Multumesc. : :cry:
De acolo am luat ,dar unele se scriu 30sec altle 140 ,care sunt bune ,dupa cite am citit prebuie sa scrie aproape 5 minute , am rugat mai sus daca este cineva care a facut aceasta operatie de scriere completa sa confirme ce spun eu.
  • 1 lună mai târziu...
Am rezolvat problema cu un programator WILLEM . asa ca sanse sa ridici un bios sters accidental prin celelalte metode sunt foarte mici.Va multumesc pt sfaturiile bine intentionate si in special lui Gaby. :aplauze
