Probleme cu afisarea pe un lcd nokia 6100 (philips)-atmega32
Vizitator ady_ady689
Am folosit softul de aici http://thomaspfeifer.net/ pentru a scrie un driver pentru lcd-ul de nokia 6100 cu driver philips, dar am intampinat niste probleme legate de programare, vreau sa afisez o imagina si niste carcatere dar nu reusesc
-controlerul folosit = atemga32
pentru orice alta functie de ex, draw() , displaiul va function dar cu carcaterele si imaginea nu
codul folosit:
#include "PCF8833U8_lcd.h"
#include
#include
#include "bmp.h"
#define F_CPU 12000000UL //
#define SPIPORT PORTA
#define SPIDDR DDRA
#define CS 4
#define CLK 3
#define SDA 2
#define RESET 1
// Font sizes
#define SMALL 0
#define MEDIUM 1
#define LARGE 2
// 12-bit color definitions
#define WHITE 0xFFF
#define BLACK 0x000
#define RED 0xF00
#define GREEN 0x0F0
#define BLUE 0x00F
#define CYAN 0x0FF
#define MAGENTA 0xF0F
#define YELLOW 0xFF0
#define BROWN 0xB22
#define ORANGE 0xFA0
#define PINK 0xF6A
#define USR UCSRA
#define UCR UCSRB
#define UBRR UBRRL
#define BAUD_RATE 38400
//#define MODE565
#define cbi(reg, bit) (reg&=~(1<
#define sbi(reg, bit) (reg|= (1<
#define CS0 cbi(SPIPORT,CS);
#define CS1 sbi(SPIPORT,CS);
#define CLK0 cbi(SPIPORT,CLK);
#define CLK1 sbi(SPIPORT,CLK);
#define SDA0 cbi(SPIPORT,SDA);
#define SDA1 sbi(SPIPORT,SDA);
#define RESET0 cbi(SPIPORT,RESET);
#define RESET1 sbi(SPIPORT,RESET);
#define byte unsigned char
byte n=0;
byte s1,s2;
byte r,g,b;
void sendCMD(byte cmd);
void sendData(byte cmd);
void shiftBits(byte b);
void setPixel(byte r,byte g,byte b);
const unsigned char FONT6x8[97][8];
const unsigned char FONT8x8[97][8];
const unsigned char FONT8x16[97][16];
int main(void)
InitLCD();
//LCD_Circle(40,30,30,LightGreen);
//LCD_Fill(0,0,132,132,0,255,0);
//LCD_Fill(50,50,90,90,0,0,255);
//LCD_Box(0,10,50,100,0,255,0);
//LCD_Circle(40,30,30,0,255,0);
//draw();
//ShowImage(0,0,bmp[6206]);
LCDPutChar('Eeeeeeee', 20, 20, MEDIUM,0,255,0);
//LCDSetCircle(50,50,100,0,255,0);
void InitLCD(void)
SPIDDR=(1<
CS0
SDA0
CLK1
RESET1
RESET0
RESET1
CLK1
SDA1
CLK1
waitms(10);
sendCMD(SWRESET);
sendCMD(SLEEPOUT);
sendCMD(BSTRON);
waitms(10);
sendCMD(DISON);
sendCMD(NORON);
sendCMD(INVON);
sendCMD(DOR);
sendCMD(MADCTL);
//sendCMD(RGBX);
sendData(RGBY);
//sendCMD(INVOFF);
#ifdef MODE565
sendCMD(COLMOD);
sendData(5); //16-Bit per Pixel
#else
//sendCMD(COLMOD);
//sendData(3); //12-Bit per Pixel (default)
#endif
/* sendCMD(RGBSET); // setup color lookup table
// Setup the color lookup table by choosing evenly spaced color values
// for a nice even spread. Blue only has 2 bits, so the spacing is wider
// but still spans 0x00 - 0x0f
// Bit organisation is RRRGGGBB
sendCMD(RGBSET);
sendData(0x00); // RED
sendData(0x02);
sendData(0x04);
sendData(0x06);
sendData(0x08);
sendData(0x0a);
sendData(0x0c);
sendData(0x0f);
sendData(0x00); // GREEN
sendData(0x02);
sendData(0x04);
sendData(0x06);
sendData(0x08);
sendData(0x0a);
sendData(0x0c);
sendData(0x0f);
sendData(0x00); // BLUE
sendData(0x04);
sendData(0x09);
sendData(0x0f);
sendCMD(NOP); // nop
sendCMD(INVON); // Inverted display mode
int i;;
for (i = 0; i < 160; i++)
{ // this loop adjusts the contrast, change the number of iterations to get
sendCMD(SETCON);
sendData(63); // desired contrast. This might be different for individual LCDs
waitms(2);
void waitms(int ms)
int i;
for (i=0;i
CLK0
if ((b&128)!=0) SDA1 else SDA0
CLK1
CLK0
if ((b&64)!=0) SDA1 else SDA0
CLK1
CLK0
if ((b&32)!=0) SDA1 else SDA0
CLK1
CLK0
if ((b&16)!=0) SDA1 else SDA0
CLK1
CLK0
if ((b&!=0) SDA1 else SDA0
CLK1
CLK0
if ((b&4)!=0) SDA1 else SDA0
CLK1
CLK0
if ((b&2)!=0) SDA1 else SDA0
CLK1
CLK0
if ((b&1)!=0) SDA1 else SDA0
CLK1
//send data
void sendData(byte data)
CLK0
SDA1 //1 for param
CLK1
shiftBits(data);
//send cmd
void sendCMD(byte data)
CLK0
SDA0 //1 for cmd
CLK1
shiftBits(data);
//converts a 3*8Bit-RGB-Pixel to the 2-Byte-RGBRGB Format of the Display
#ifdef MODE565
sendData((r&248)|g>>5);
sendData((g&7)<<5|b>>3);
#else
if (n==0)
s1=(r & 240) | (g>>4);
s2=(b & 240);
n=1;
} else
n=0;
sendData(s1);
sendData(s2|(r>>4));
sendData((g&240) | (b>>4));
#endif
void LCDSetXY(int x, int y)
// Row address set (command 0x2B)
sendCMD(PASET);
sendData(x);
sendData(x);
// Column address set (command 0x2A)
sendCMD(CASET);
sendData(y);
sendData(y);
void LCDSetPixel(int x, int y, int color)
LCDSetXY(x, y);
sendCMD(RAMWR);
sendData((unsigned char)((color >> 4) & 0xFFFF));
sendData((unsigned char)(((color & 0x0F) << 4) | 0x00));
sendCMD(NOP);
void draw()
//Column Adress Set
sendCMD(0x2A);
sendData(0);
sendData(131);
//Page Adress Set
sendCMD(0x2B);
sendData(0);
sendData(131);
//Memory Write
sendCMD(RAMWR);
int i;
//Test-Picture
//red bar
for (i=0;i<132*33;i++)
setPixel(255,0,0);
//green bar
setPixel(0,255,0);
//blue bar
setPixel(0,0,255);
//white bar
setPixel(255,255,255);
// Name: GotoXY(u_char x, u_char y)
// Copyright: Free to use at will & at own risk.
// Author: JCP
// Date: 03.30.06 17:10
// Description: Sets position to x-y location on LCD
// Useage: GotoXY(param 1,param 2)
// param 1: x direction 0-131
// param 2: y direction 0-131
// Example: GotoXY(32,17);
// Notes: No bounds checking
void GotoXY(unsigned char x, unsigned char y)
sendCMD(PASET); // page start/end ram
sendData(y); // Start Page to display to
sendData(131); // End Page to display to
sendCMD(CASET); // column start/end ram
sendData(x); // Start Column to display to
sendData(131);
// Name: LCD_PixelPut(u_char x, u_char y, u_char color)
// Author: JCP
// Description: Put One Pixel on LCD
// Useage: LCD_PixelPut(param 1,param 2,param 3)
// param 3: Color of Pixel, RRRGGGBB format
// Example: LCD_PixelPut(30,30,0x62) // put a purple pixel @ 30,30
void LCD_PixelPut(unsigned char x, unsigned char y, unsigned char color)
GotoXY(x,y);
sendCMD(RAMWR); // Now write the pixel to the display
sendData(color); // Write the data in the specified Color
void pixel(unsigned char x, unsigned char y, byte r, byte g, byte b)
GotoXY(x,y);
sendCMD(RAMWR);
setPixel(r,g,b);
// Name: LCD_Fill (u_char xs,u_char ys,u_char width,u_char height, u_char color)
// Author: JCP
// Description: Fills an area starting @ xs,ys to width @ heighth with color
// Useage: LCD_Fill(param 1,param 2,param 3,param 4,param 5)
// param 1: x start direction: 0-131
// param 2: y start direction: 0-131
// param 3: width: 0-131
// param 4: heighth: 0-131
// param 5: Color of Pixel, RRRGGGBB format
// Example: LCD_Fill(0,0,132,132,Black); // fill entire screen with black color
void LCD_Fill (unsigned char xs,unsigned char ys,unsigned char width,unsigned char height, byte r, byte g, byte b)
unsigned char i,j;
for (i=0;i < height;i++) // Number of horizontal lines
GotoXY(xs,ys+i); // Goto start of fill area (Top Left)
sendCMD(RAMWR); // Write to display
for (j=0;j < width;j++) // pixels per line
setPixel(r,g,b); //
sendCMD(NOP); // End
// Name: LCD_Funct_A(x1, y1, x2, y2, pixel_on_off, ram_or_lcd)
// Author: JCP
// Description: Used with LCD line function
void LCD_Funct_A(unsigned char x1, unsigned char y1, unsigned char x2, unsigned char y2, unsigned char color )
float a,b;
unsigned char x,y; //
b = (float)((y2 - y1) + 1) / (float)((x2-x1) + 1); //
a = y1; //
for(x = x1;x <= x2; x++) //
for(y=(unsigned char)a;y <= (unsigned char)(a + b); y++) //
if(y <= y2) //
GotoXY(x,y); // Goto start of fill area (Top Left)
sendCMD(RAMWR); // write to display
sendData(color); //
a+=b; //
// Name: LCD_Funct_B(x1, y1, x2, y2, pixel_on_off, ram_or_lcd)
// Author: JCP
void LCD_Funct_B(unsigned char x1, unsigned char y1, unsigned char x2, unsigned char y2, unsigned char color )
float a,b;
b = (float)((y2 - y1) + 1) / (float)((x1-x2) + 1); //
a = y1; //
for(x = x1;x >= x2; x--) //
if(y <= y2) //
sendData(color); //
a+=b; //
// Name: LCD_Line(x1, y1, x2, y2, pixel_on_off, ram_or_lcd)
// Author: JCP
// Description: To draw or remove a line from the LCD
void LCD_Line(unsigned char x1, unsigned char y1, unsigned char x2, unsigned char y2, unsigned char color)
if( (x1 <= x2) && (y1 <= y2) ) //
LCD_Funct_A(x1,y1,x2,y2,color); //
else if( (x1 > x2) && (y1 < y2) ) //
LCD_Funct_B(x1,y1,x2,y2,color); //
else if( (x1 >= x2) && (y1 >= y2) ) //
LCD_Funct_A(x2,y2,x1,y1,color); //
else if( (x1 < x2) && (y1 > y2) ) //
LCD_Funct_B(x2,y2,x1,y1,color); //
// Name: LCD_Box(x1, y1, x2, y2, pixel_on_off, ram_or_lcd)
// Author: JCP
// Description: To draw a BOX on the LCD
void LCD_Box(unsigned char x1, unsigned char y1, unsigned char x2, unsigned char y2, byte r, byte g, byte b)
unsigned char x,y;
x = x1; //
y = y1; //
while(x <= x2) //
pixel(x,y1,r,g,b); //
pixel(x,y2,r,g,b); //
x++; //
while(y <= y2) //
pixel(x1,y,r,g,b); //
pixel(x2,y,r,g,b); //
y++; //
// Name: LCD_Circle
// Description: To Draw a Circle on LCD
// Useage: LCD_Circle(param 1,param 2,param 3,param 4)
// param 1: x location on screen, 0 - 127
// param 2: y location on screen, 0 - 63
// param 3: diameter of circle
// param 4: Color of Pixel, RRRGGGBB format
// Example: LCD_Circle(40,30,30,LightGreen);
void LCD_Circle(unsigned char center_x, unsigned char center_y, unsigned int rad, unsigned char color)
unsigned int x;
unsigned int y;
x = 0;
y = rad;
while (x <= y)
// We make use of 8 axes of symmetry in a circle.
// This way we have fewer points to calculate on its circumference.
pixel (center_x + (unsigned char)x, center_y + (unsigned char)y,r,g,b);
pixel (center_x - (unsigned char)x, center_y + (unsigned char)y,r,g,b);
pixel (center_x + (unsigned char)x, center_y - (unsigned char)y,r,g,b);
pixel (center_x - (unsigned char)x, center_y - (unsigned char)y,r,g,b);
pixel (center_x + (unsigned char)y, center_y + (unsigned char)x,r,g,b);
pixel (center_x - (unsigned char)y, center_y + (unsigned char)x,r,g,b);
pixel (center_x + (unsigned char)y, center_y - (unsigned char)x,r,g,b);
pixel (center_x - (unsigned char)y, center_y - (unsigned char)x,r,g,b);
// This is the most important part of the function.
// We go to the right in all cases (x++).
// We need to decide whether to go down (y--).
// This depends on which point is
// closest to the path of the circle.
// Good old Pythagoras will tell us what to do.
x++;
if( abs( (x * x) + (y * y) - (rad * rad) ) > abs( (x * x) + ((y-1)*(y-1)) - (rad * rad)) )
y--;
// Name: LCD_Thick_Circle
// Description: To Draw a Definable Thickness Circle on LCD
// Useage: LCD_Thick_Circle(param 1,param 2,param 3,param 4,param 5)
// param 3: diameter: 0-255
// param 4: Thickness of circle wall in pixels
// Example: LCD_Thick_Circle(66,66,30,2,0x62);
// start @ 66,66, with a diamater of 30, 2 pixels thick in purple
void LCD_Thick_Circle(unsigned char center_x, unsigned char center_y,unsigned char diameter, unsigned char thick,unsigned char color)
unsigned int a;
for(a=0;a < 360;a++)
// LCD_Circle_Line(center_x,center_y,diameter,(diameter + thick),a,color);
/*void ShowImage(unsigned char x, unsigned char y, const unsigned char *location)
unsigned char x_max,y_max;
unsigned char x_logo,y_logo;
x_max = *location;
location++;
y_max = *location;
location++;
for(y_logo=0;y_logo
GotoXY(x,y + y_logo);
for(x_logo=0;x_logo < x_max;x_logo++)
sendData(*location); // Write the data in the specified Color
location++;
// Name: LCD_String
// Description: To print a string of characters to LCD
// Useage: LCD_String(param 1,param 2,param 3,param 4,param 5,param 6)
// param 1: String data
// param 2: pointer to data lookup table (I.E. Font table)
// param 3: x start direction: 0-131
// param 4: y start direction: 0-131
// param 5: Font Color, RRRGGGBB format
// param 5: Background color, RRRGGGBB format
// Example: sprintf(thestring,"Hello World");
// LCD_String(thestring,_FONT6x8,52,25,White,Black);
// print "Hello World" in white text on a black background
void LCD_String (unsigned char *the_string, unsigned char Size,unsigned char x, unsigned char y, unsigned char fcolor, unsigned char bcolor)
unsigned int i,j;
unsigned char Mask,z,xme,yme,mult; //
unsigned char *slave; //
unsigned char *Data; //
unsigned char FONT8x8F; //
if(Size==FONT8x8F) //
slave = FONT8x8F; //
xme = 8; //
yme = 8; //
mult= 8; //
do //
Data = slave + (mult * (int)(*the_string - 32)); //
for (i=0;i < yme;i++) // 10 bytes per char 15
Mask |=0x80; //
for (j=x;j < (x + xme);j++) //
z= y + i; //
if (*Data & Mask) //
pixel (j,z,0,255,0); //
else //
pixel (j,z,0,0,255); //
Mask>>=1; //
Data++; //
x+=xme; //
the_string++; //
}while(*the_string !='\0'); // keep spitting chars until end
sendCMD(NOP); // Recomended to send now and then
void LCDPutChar(char c, int x, int y, int size, byte r, byte g, byte b)
extern const unsigned char FONT6x8[97][8];
extern const unsigned char FONT8x8[97][8];
extern const unsigned char FONT8x16[97][16];
int i,j;
unsigned int fColor ;
unsigned int bColor;
unsigned int nCols;
unsigned int nRows;
unsigned int nBytes;
unsigned char PixelRow;
unsigned char Mask;
unsigned int Word0;
unsigned int Word1;
unsigned char *pFont;
unsigned char *pChar;
unsigned char *FontTable[] = {(unsigned char *)FONT6x8,(unsigned char *)FONT8x8,(unsigned char *)FONT8x16};// get pointer to the beginning of the selected font table
pFont = (unsigned char *)FontTable;// get the nColumns, nRows and nBytes
nCols = *pFont;
nRows = *(pFont + 1);
nBytes = *(pFont + 2);// get pointer to the last byte of the desired character
pChar = pFont + (nBytes * (c - 0x1F)) + nBytes - 1;// Row address set (command 0x2B)
sendCMD(PASET);
sendData(x);
sendData(x + nRows - 1);// Column address set (command 0x2A)
sendCMD(CASET);
sendData(y);
sendData(y + nCols - 1);// WRITE MEMORY
sendCMD(RAMWR);// loop on each row, working backwards from the bottom to the top
for (i = nRows - 1; i >= 0; i--)
// copy pixel row from font table and then decrement row
PixelRow = *pChar--;
// loop on each pixel in the row (left to right)
// Note: we do two pixels each loop
Mask = 0x80;
for (j = 0; j < nCols; j += 2)
// if pixel bit set, use foreground color; else use the background color
// now get the pixel color for two successive pixels
if ((PixelRow & Mask) == 0)
Word0 = bColor;
setPixel(r,g,b);
else
Word0 = fColor;
setPixel(0,255,0);
Mask = Mask >> 1;
Word1 = bColor;
setPixel(r,g,b);
else
Word1 = fColor;
setPixel(r,g,b);
Mask = Mask >> 1;
// use this information to output three data bytes
sendData((Word0 >> 4) & 0xFF);
sendData(((Word0 & 0xF) << 4) | ((Word1 >> & 0xF));
sendData(Word1 & 0xFF);
// terminate the Write Memory command
sendCMD(NOP);
  • Răspunsuri 0
Zile populare
